PRODUCT BRIEF: GPS
Part No. 1001011
PresttaTM Standard GPS
Embedded Antenna
1575 MHz
KEY BENEFITS
DESIGN ADVANTAGES
ethertronics
1001011
11 5
P522304
Ethertronics’ Prestta series of Isolated Magnetic Dipole™ (IMD) embedded antennas address the challenges facing today’s product designers. IMD’s high
performance and isolation characteristics offer better connectivity and minimal interference. Prestta
antennas can be used in a variety of applications including:
Handsets
Tablets
Femtocells
M2M
Automatic Meter Reading
Healthcare
Point of Sale
Tracking
TECHNOLOGY ADVANTAGES
Stays in Tune
IMD antenna technology
provides superior RF field
containment, resulting in
less interaction with
surrounding components.
Ethertronics IMD antennas
resist de-tuning;
providing a robust radio
link regardless of the
usage position.
Prestta antennas use patented IMD technology in a
stamped metal configuration to provide high
performance. IMD antennas requires a smaller design
keep-out area, carry lower program development risk
which yields a quicker time-to-market, without
sacrificing RF performance.
Reduced Costs and Time-to-Market
Standard antenna eliminates design fees and cycle
time associated with a custom solution; getting products to market faster.
Greater Flexibility with Unique Form Factors
Ethertronics’ IMD technology helps you deliver more
advanced ergonomic designs without adverse impact
on product performance.
SMD mountable design enables faster and lower cost
manufacturing.
RoHS Compliant
Ethertronics’ antennas are fully compliant with the
European RoHS Directive 2002/95/EC.
END USER ADVANTAGES
Unique Form Factors Support Advanced
Industrial Designs
Smaller, more efficient IMD embedded antennas break
through restrictive design rules and provide new freedom in component placement.
Superior Range
Better antenna function means longer range and greater sensitivity to critically precise signals—delivering
greater customer satisfaction while building brand loyalty.
SERVICE AND SUPPORT
Extensive RF Experience
Our Prestta antennas are supported by documentation,
and when needed, by the expertise of RF engineers
who have integrated hundreds of antenna designs into
wireless devices.
Global Operations & Design Support
Ethertronics’ global operations supports an integrated
network of design centers that can take projects from
concept to production.
ETHERTRONICS
9605 Scranton Road, Suite 300 | San Diego, CA 92121 - USA | www.ethertronics.com
tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com
PRELIMINARY PRODUCT BRIEF: GPS ANTENNA ON GROUND
Ethertronics’ GPS (Embedded) Antenna Specifications.
Below are the typical specs for a GPS antenna (subject to change).
Electrical Specifications
Typical Characteristics
GPS Antenna (MHz)
Peak Gain
Measurements taken on a 50 x 100
mm ground plane.
Average Efficiency
VSWR Match
Feed Point Impedance
Power Handling
Polarization
Mechanical Specifications
-1.8 dBi
26%
2:1 max
50 ohms unbalanced (other if required)
2 Watt CW
Linear
Maximum Dimensions
22.0x3.2x3.3 mm
Mechanical Mounting
Antenna is Surface Mounted to main PCB.
RF Mounting
Typical Efficiency & Peak Gain
Typical Return Loss & VSWR
1570-1580
RF and Ground pads are Surface Mounted to main PCB. No Ground
Clearance required under the antenna.
PRODUCT: GPS ANTENNA ON GROUND
Antenna Radiation Patterns
Typical Performance (1575 MHz)
Ethertronics’ Test Board
PCB: 50x100mm
Tests performed in Satimo Starlab
Z
X
Y
X
Z
Y
Z
Y
X
© 2011 Ethertronics. All rights reserved. Ethertronics, the Ethertronics logo, shaping antenna technology, Prestta, Isolated Magnetic Dipole and the
iMD logo are trademarks of Ethertronics. All other trademarks are the property of their respective owners.
Specifications subject to change and are dependent upon actual implementation.
GPS 08-31-11
很抱歉,暂时无法提供与“1001011”相匹配的价格&库存,您可以联系我们找货
