FXUB65.07.0180C
FXUB65.07.0180C
    TAOGLASLIMITED
    WIDEBANDFLEXANTENNA700MHZTO
FXUB65.07.0180C 数据手册
SPECIFICATION PATENT PENDING Part No: FXUB65.07.0180C Product Name: Minima Embedded Flexible 4G LTE Wide Band Antenna 700-960MHz, 1700-2700MHz Features: Flexible Wideband Antenna Covers worldwide 2G/3G/4G Bands Isotropic Radiation Pattern Highest efficiency in smallest size 67.0x58.0x0.2 mm IPEX 1.37 coaxial cable RoHS Compliant SPE-16-08-023/B/WY Page 1 of 16 1. Introduction The patent pending Minima FXUB65 flexible antenna has been designed to cover 4G bands in the 700-2700 MHz spectrum, but also optimally covers 2G and 3G. The antenna has a compact, flexible, modern design, with excellent efficiencies on all target bands. The Minima comes standard with 180mm IPEX cable and connector for easy installation and can also be configured for different cable lengths and terminations. The 67x58x0.2mm FXUB65 is made from flexible polymer material, which is ultra-thin, compact and highly efficient across the 3G and 4G bands. It is installed by a simple “peel and stick” process, attaching securely to non-metal surfaces via adhesive backing. The Minima has been designed with excess bandwidth so that performance is not affected by thicker or thinner plastic surfaces to which it is adhered. It enables designers to use only one antenna that covers all cellular communication frequencies in the IoT market. The Minima antenna has a unique compact geometric design, which has excellent efficiency for its size and isotropic pattern at both low and high bands. This antenna if integrated optimally with enough clearance, can in most cases pass US operator requirements. The antenna performs well at a reasonable distance, typically 20mm, from a ground and has demonstrated ease of integration into complex end user equipment. The FXUB65 Minima antenna has a typical efficiency of more than 50% across the low bands and 64% across the high bands. The Minima is designed to be mounted directly onto a plastic or glass cover. It is an ideal choice for any device maker that desires ease of integration and needs to keep manufacturing costs down over the lifetime of a product. Cable and connector can be customized, contact your regional Taoglas sales office for support. SPE-16-8-023/B/WY Page 2 of 16 2. Specification ELECTRICAL GSM DCS 900 Standard LTE 700 GSM 850 PCS UMTS1 WiFi LTE 2600 Frequency (MHz) 698~ 803 824~ 894 880~ 960 1710~ 1880 1850~ 1990 1920~ 2170 2400~ 2480 2490~ 2690 Max Return Loss (dB) -9 -8 -7 -9 -17 -13 -13 -12 Max VSWR 2.5 2.5 3 2.5 1.5 1.5 1.5 2 Efficiency (%) 45 45 45 60 65 65 65 55 Peak Gain (dBi) 2 2 2 2 2.5 2.5 3 2 Average Gain (dB) -3.5 -3.5 -3.5 -2.2 -2 -2 -2 -2.6 Radiation Properties Omni-directional Max Input Power (Watts) 5 Polarization Linear Impedance (Ohms) 50 Ohms MECHANICAL Dimensions (mm) 67x58x0.2 mm Material Flexible Polymer Connector and Cable IPEX and 1.37 mm ENVIRONMENTAL Operation Temperature -40°C to 85°C Storage Temperature -40°C to 85°C Relative Humidity 40% to 95% RoHs Compliant Yes *Antenna measured on plastic sheet with 1.5mm thickness in “full wrap” configuration. SPE-16-8-023/B/WY Page 3 of 16 LTE BANDS LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Band Number Uplink Downlink Covered 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 (LTE only) 18 UL: 815 to 830 DL: 860 to 875 (LET only) 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 (LTE only) 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 (LTE only) 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 (LTE only) 28 UL: 703 to 748 DL: 758 to 803 (LTE only) 29 UL: - DL: 717 to 728 (LTE only) 30 UL: 2305 to 2315 DL: 2350 to 2360 (LTE only) 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 (LTE only) 32 UL: - DL: 1452 - 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓   SPE-16-8-023/B/WY Page 4 of 16 3. Antenna Parameters 3.1. Return Loss 3.2. VSWR SPE-16-8-023/B/WY Page 5 of 16 3.3. Efficiency 3.4. Peak Gain SPE-16-8-023/B/WY Page 6 of 16 3.5. Average Gain SPE-16-8-023/B/WY Page 7 of 16 4. Radiation Pattern 700 MHz SPE-16-8-023/B/WY Page 8 of 16 850 MHz 950 MHz SPE-16-8-023/B/WY Page 9 of 16 1750 MHz 1850 MHz SPE-16-8-023/B/WY Page 10 of 16 2000 MHz 2150 MHz SPE-16-8-023/B/WY Page 11 of 16 2450 MHz 2600 MHz SPE-16-8-023/B/WY Page 12 of 16 5. Mechanical Drawing (Unit: mm) SPE-16-8-023/B/WY Page 13 of 16 6. Packaging SPE-16-8-023/B/WY Page 14 of 16 7. Application Note Like all flex antennas, the FXUB65 Minima antenna performance is somewhat sensitive to the routing of the cable during integration. The preferred routing is a “full wrap” or “half wrap”, as shown below where the cable is routed around the long side of the device. Routing over the lower part of the device as shown will also work well. An integration where the cable runs straight off will work, but the performance in the 900MHz band may not be optimal. Avoid running the cable up along the short side or wrapping it around the short side, as these will not work. If a longer cable is needed to wrap around the long side and still reach the module, this is ok, and a longer cable can be easily built. Keep the antenna at least 20mm away from conductors in the end user device. The FXUB65 can be integrated into assemblies over a small ground plane such as a PCB. The efficiency in these cases can sometimes be higher than the antenna alone. SPE-16-8-023/B/WY Page 15 of 16 SPE-16-8-023/B/WY Page 16 of 16
FXUB65.07.0180C 价格&库存
很抱歉,暂时无法提供与“FXUB65.07.0180C”相匹配的价格&库存,您可以联系我们找货
FXUB65.07.0180C
    • 1+68.74700
    库存:3
