SPECIFICATION
Part No.
FW.45.B.SMA.M
Description
Meteor
450-470MHz Flexible Whip Monopole
Antenna SMA(M) Straight
Features
Monopole Antenna
Designed for Outdoor Use
Over 70% high efficiency*
Over 1 dBi peak gain*
Robust Inner Steel Core
Antenna Length: 290mm
SMA Type(M) Straight Connector
IP65 dust and water-resistant
*Tested on 30cm*30cm Ground Plane
RoHS Compliant
SP-15-8 SPE-16-8-005/C/WY
Page 1 of 13
1. Introduction
The FW.45 is a flexible 450-470MHz whip antenna with a SMA type (M) connector
for outdoor use. It features excellent efficiency (>70%) and peak gain (>1 dBi)
at 450-470MHz on a 30x30 cm ground plane. Common applications are smart
metering, gateways, wireless monitoring, and mesh networks.
The FW.45 has an excellent omnidirectional radiation pattern, ensuring wide
coverage. The antennas high efficiency means that it allows your radio to
consume less power than with a lower efficiency antenna when transferring data.
It also means a better signal strength and better sensitivity in areas of low signal
levels. The antenna performs at its best while attached to a ground plane with
dimensions of at least 30x30 cm. For an environment where there is no
ground-plane available we recommend to use the fiberglass omni OMB.450
antenna.
The FW.45 whip is made of a flexible inner steel core covered by PE so it is
extremely resistant to abrasion and maintains its original shape and RF
performance even after shock. This rugged design and IP67 rating on the housing
ensure high reliability.
This antenna comes with SMA(M) connector as standard. Other custom variants
can be provided subject to NRE and MOQ. Contact your regional Taoglas office for
details.
Page 2 of 13
2. Specification
CDMA450 450-470MHz
Center Frequency
450-470 MHz
Design Environment
On 30x30cm ground
Efficiency
73.66 %
Peak Gain
1.10 dBi
Return loss
< -10 dB
VSWR
≤ 2:1
Impedance
50 Ω
Polarization
Linear
Radiation Pattern
Omnidirectional
Input Power
2W
MECHANICAL
Dimensions
Length
290 ± 9 mm
Base Diameter
16 ± 0.6 mm
Whip Diameter
6.2 ± 0.6 mm
Casing
ABS
Connector
Weight
Dust and Water
Resistance
63.5 g
IP65
ENVIRONMENTAL
Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
Page 3 of 13
3. Antenna Characteristics
3.1.
Return Loss
3.2.
Antenna Efficiency
Page 4 of 13
3.3.
Peak Gain
3.4.
Average Gain
Page 5 of 13
4. Antenna Radiation Pattern
4.1.
Antenna Setup
On 30*30 cm ground plane
Y
X
Z
Page 6 of 13
4.2.
2-D Radiation Pattern
On 30*30cm Ground Plane
XY Plane
X
Y
XZ Plane
Z
X
Page 7 of 13
YZ Plane
Z
Y
Page 8 of 13
4.3.
3-D Radiation Pattern
@ 450MHz
@ 460MHz
Page 9 of 13
@ 470MHz
Page 10 of 13
5. Antenna Drawing (Unit: mm)
Page 11 of 13
6. Packaging
Page 12 of 13
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves all rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
Page 13 of 13
很抱歉,暂时无法提供与“FW.45.B.SMA.M”相匹配的价格&库存,您可以联系我们找货
