HIGH DENSITY DOUBLE ROW
LED FLEX RIBBON
Features
VOLTAGE: 12V DC
CURRENT: 4.3 Amps
LED VIEWING ANGLE (2 0 1/2): 120 0
STANDARD PACKAGING:
5 METER REEL (1200 LED'S)
OPTIONAL PACKAGING:
INDIVIDUAL 500mm Sections (120 LED's)
Order as ZFS-155000-CW/SEC
NOTE: Individual sections ARE NOT supplied
with insulated wire connection.
5000mm
(196.85")
25mm
(.98")
16AWG
WIRES
15mm
(.59")
Accessories
ZPS-1235
ZPS-1260
ZDM-01
Absolute MaximumRating at Ta = 25°C
Parameter
Symbol
Rating
Units
Forward Current
IF
4.3
A
Power Dissipation
PD
57.25
W
Electrostatic Discharge
ESD
800
V
Operating Temperature
Topr
-20~+50
ºC
Storage Temperature
Tstg
-30~+80
ºC
12V, 35 Watt Power Supply
12V, 60 Watt Power Supply
PWM LED Dimmer
Note: ZPS-1235 and ZPS-1260 require
use of wire nuts for connections.
DC 12V
R1
R2
R199
R200
Electro-Optical Characteristics (Ta = 25°C)
JKL
Part
Number
Color
ZFS-155000-CW
Cool White
Input
Number Voltage Power Current
of LED's (V DC)
(W)
(A)
1200
12
57.25
Radiance CCT (K)
Angle
4.3
120º
ATTENTION
Please refer to JKL Application Sheet JKL-AS-ZFS-LED FLEX
for Installation and Power Recommendations.
OBSERVE PRECAUTION
FOR HANDLING ELECTROSTATIC
DISCHARGE SENSITIVE DEVICES
DIMENSIONS ARE
IN mm (INCHES)
TOLERANCE UNLESS
OTHERWISE SPECIFIED TITLE
THIRD ANGLE
PROJECTION
REV.
NO.
6925
Note
METRIC
A
6500ºK
Lumen
Flux
(lm)
CHANGE SOLDER PADS TO 3
8/7/18
RELEASED
3/21/16
DESCRIPTION/ECO
NUMBER
APPV'D
DATE
DRAWN BY
L. WENGSTROM
1 PL +/2 PL +/ANGLE +/-
APPV'D BY
S.C.
- CAD DRAWING -
REF.
REF.
DATE
8/7/18
MANUAL REVISIONS NOT PERMITTED
SIZE
A
SCALE
COMPONENTS CORPORATION
12V HIGH DENSITY DOUBLE ROW
LED FLEX RIBBON
FSCM NO.
55335
NONE
DRAWING
NO.
RELEASED
DATE
ZFS-155000-CW
3/21/16
REVISION
DATE
8/7/18
A
SHEET
1
OF
1
很抱歉,暂时无法提供与“ZFS-155000-CW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1120.38308
- 2+1105.83495
- 5+1091.65130
