P0481
P0481
    TERASIC(友晶科技)
    NET-FMCCARD
P0481 数据手册
NET-FMC User Manual -1- www.terasic.com January 16, 2018 目錄 CHAPTER 1 ............................................... NET-FMC DEVELOPMENT KIT -1- 1-1 PACKAGE CONTENTS ......................................................................................... - 1 1-2 NET-FMC SYSTEM CD ..................................................................................... - 1 1-3 GETTING HELP ................................................................................................. - 1 CHAPTER 2 .............................. INTRODUCTION OF THE NET-FMC CARD -2- 2-1 FEATURES ....................................................................................................... - 3 2-2 BLOCK DIAGRAM OF THE NET-FMC BOARD.......................................................... - 3 2-3 CONNECTIVITY ................................................................................................. - 5 2-4 MODE SWITCH X 4 SETTING ............................................................................... - 5 CHAPTER 3 ............................................... USING THE NET-FMC BOARD -8- 3-1 ETHERNET PHY 88E1111 ................................................................................. - 8 3-2 FMC CONNECTOR ............................................................................................ - 9 CHAPTER 4 ................................................................. EXAMPLE CODES - 15 - 4-1 REMOTE UPDATE PORTAL.................................................................................- 15 CHAPTER 5 ........................................................................... APPENDIX NET-FMC User Manual -1- www.terasic.com January 16, 2018 - 24 - Chapter 1 NET-FMC Development Kit 1-1 Package Contents The Terasic NET-FMC is a Gigabit Ethernet transceiver with an FMC interface. It offers network transfers of up to 1 Gbps with the host board using an FMC connector. Also, it provides a fully integrated Ethernet solution enabling fast implementation design, shortening development times, and allows you to focus on the core functions of the system design. Lastly, the NET-FMC can be connected any FMC(HPC) interfaces. The NET-FMC package includes: 1. NET-FMC 2. Screw & Copper Pillar Pakage 3. CD Download Guide Figure 1-1 The NET-FMC package contents 1-2 NET-FMC System CD The NET-FMC System CD contains all the documents and supporting materials associated with NET-FMC, including the user manual, reference designs, and device datasheets. Users can download this system CD from the link: http://net-fmc.terasic.com/cd 1-3 Getting Help Here are the addresses where you can get help if you encounter any problems: Terasic Technologies 9F., No.176, Sec.2, Gongdao 5th Rd, East Dist, Hsinchu City, 30070. Taiwan Email: support@terasic.com Tel.: +886-3-575-0880 Website: http://www.terasic.com NET-FMC User Manual -1- www.terasic.com January 16, 2018 Chapter 2 Introduction of the NET-FMC Card This chapter describes the architecture and configuration of the NET-FMC Board including block diagram and components related. Figure 2-1 The NET-FMC Board PCB and Component Diagram of top side Figure 2-2 The NET-FMC Board PCB and Component Diagram of bottom side The photographs of the NET-FMC are shown in Figure 2-1 and Figure 2-2. They depict the layout of the board and indicates the location of the connectors and the key components on the top and bottom side. The following components are provided on the NET-FMC Board: NET-FMC User Manual -2- www.terasic.com January 16, 2018  Ethernet RJ45 Connector x4.  Ethernet PHY chip 88E1111 x4.  FMC Connector(HPC).  Mode Switch x4.  Link Status LEDs Group x4. 2-1 Features The NET-FMC board has many features that allow users to implement a wide range of design circuits, from simple circuits to various multimedia projects. The following hardware is provided on the board:  Package Interface: VITA 57.1 FMC, 2.5V I/O-standard.  Ethernet PHY module: Chip P/N: 88E1111. 10/100/1000BASE-T IEEE 802.3 compliant. Support MAC Interface: GMII/MII, RGMII, SGMII.  Ethernet RJ45 Connector x4: Use standard Cat 5 UTP cabling.  Mode Switch: Support GMII/MII, RGMII, SGMII.  Four 25-MHz reference clock driven from dedicated oscillator. 2-2 Block Diagram of the NET-FMC Board Figure 2-3 shows the NET-FMC Block Diagram. Four 25 MHz reference clock driven from dedicated oscillator are required for Ethernet PHY 88E1111. FMC Connector transmit the data between host board and Ethernet PHY 88E1111 through MAC interface. Also, four-port integrated 10/100/1000 Gigabit Ethernet Transceiver supported SGMII/GMII/MII/RGMII MAC interfaces is installed for direct connection to a MAC/Switch port. There are four group LEDs indicting the link status. NET-FMC User Manual -3- www.terasic.com January 16, 2018 Figure 2-3 Block Diagram of NET-FMC Board NET-FMC User Manual -4- www.terasic.com January 16, 2018 2-3 Connectivity Terasic NET-FMC is able to connect to any FPGA development kit equipped with FMC(HPC) connector. The below picture Figure 2-4 shows the connections with TR5 board. Figure 2-4 Connect the NET-FMC to TR5 board’s FMCD port 2-4 Mode Switch x 4 Setting The NET_FMC card provides four Ethernet ports (ETH0 ~ETH3) via four Marvell 88E1111 Ethernet PHY chips. Each switch (SW0~SW3) is corresponding to one Ethernet port to switch Ethernet port work modes from RGMII to GMII/MII or SGMII, SW0 is used for ETH0 port, SW1 is used for ETH1 port, SW2 is used for ETH2 port and SW3 is used for ETH3 port. Table 2-1 describes the working mode switch settings for ENET0 ~ ENET3 port work modes. Table 2-1 Mode Switch x 4 Setting for the Ethernet Mode Mode Switch Setting Ethernet Port Mode 1-ON,4-ON GMII/MII 2-ON,4-ON RGMII (default) 3-ON,5-ON SGMII NET-FMC User Manual -5- www.terasic.com January 16, 2018 The default setting of the Ethernet Port is SGMII mode. Users can change Ethernet mode by using the Mode Switch x4. Take ETH0 as an example. Set ETH0 MODE on the NET_FMC card to RGMII mode (default). The SW0[6:1] on NET-FMC should be set to 001010, as shown in Figure 2-5. Figure 2-5 SW0 setting for ETH0 port RGMII mode Set ETH0 MODE on the NET_FMC card to GMII/MII mode. The SW0[6:1] on NET-FMC should be set to 001001, as shown in Figure 2-6. Figure 2-6 SW0 setting for ETH0 port GMII/MII mode NET-FMC User Manual -6- www.terasic.com January 16, 2018 Set ETH0 MODE on the NET_FMC card to SGMII mode. The SW0[6:1] on NET-FMC should be set to 010100, as shown in Figure 2-7. Figure 2-7 SW0 setting for ETH0 port SGMII mode NET-FMC User Manual -7- www.terasic.com January 16, 2018 Chapter 3 Using the NET-FMC Board This chapter provides instructions on how to use Ethernet PHY 88E1111 and FMC connector on the HDMI-FMC board. 3-1 Ethernet PHY 88E1111 Terasic NET-FMC Board equips with four Ethernet PHY named 88E1111, which is an integrated 10/100/1000 ultra gigabit Ethernet transceiver device for Ethernet 10BASE-T, 100BASE-TX and 1000BASE-T applications. It contains all the active circuitry required to implement the physical layer functions to transmit and receive data on standard CAT 5 unshielded twisted pair. The 88E1111 device supports the Gigabit Media Independent Interface (GMII/MII), Reduced GMII (RGMII), and Serial Gigabit Media Independent Interface (SGMII) for direct connection to a MAC/Switch port. Figure 3-1 System Overview with 88E1111 device NET-FMC User Manual -8- www.terasic.com January 16, 2018 Figure 3-1 shows the connections between the FMC (HPC), the 88E1111 Ethernet PHY, and RJ-45 connector. Ethernet PHY 88E1111 function are controlled by the management interface via NETx_MDC and NETx_MDIO. There is a LED used to indicate the status of 1000BASE-T link via NETx_LED_LINK1000. The 88E1111 device incorporates the Marvell Virtual Cable Tester(VCT) feature, which uses Time Domain Reflectometry(TDR) technology for the remote identification of potential cable malfunctions, thus reducing equipment returns and service calls. Using VCT, the 88E1111 device detects and reports potential cabling issues such as pair swaps, pair polarity and excessive pair skew. The 88E1111 device uses advanced mixed-signal processing to perform equalization, echo and crosstalk cancellation, data recovery, and error correction at a gigabit per second data rate. The device achieves robust performance in noisy environments with very low power dissipation. 3-2 FMC Connector Table 3-1 shows the pin out and pin definitions of NET-FMC board. Table 3-1 Pin Assignment of NET-FMC FMC interface Pin Direction Description I/O Standard NET0_GTX_CLK LA01_P_CC/D8 Output Ethernet-0 GMII/TBI Transmit Clock 2.5V NET0_TX_CLK HA11_P/J12 Input Ethernet-0 MII Transmit Clock, TBI 62.5 MHz Receive Clock 1 2.5V NET0_TX_EN LA08_P/G12 Output Ethernet-0 GMII/MII Transmit Enable, TBI Transmit Data 8 2.5V NET0_TX_ER HA14_P/J15 Output Ethernet-0 GMII/MII Transmit Error, TBI Transmit Data 9 2.5V NET0_TX_D[0] LA08_N/G13 Output Ethernet-0 GMII/MII/TBI Transmit Data 0 2.5V NET0_TX_D[1] LA04_P/H10 Output Ethernet-0 GMII/MII/TBI Transmit Data 1 2.5V NET0_TX_D[2] LA03_N/G10 Output Ethernet-0 GMII/MII/TBI Transmit Data 2 2.5V NET0_TX_D[3] LA13_P/D17 Output Ethernet-0 GMII/MII/TBI Transmit Data 3 2.5V NET0_TX_D[4] HA20_N/E19 Output Ethernet-0 GMII/TBI Transmit Data 4 2.5V NET0_TX_D[5] HB03_N/E22 Output Ethernet-0 GMII/TBI Transmit Data 5 2.5V NET0_TX_D[6] HB03_P/E21 Output Ethernet-0 GMII/TBI Transmit Data 6 2.5V NET0_TX_D[7] HB05_P/E24 Output Ethernet-0 GMII/TBI Transmit Data 7 2.5V NET0_RX_CLK LA13_N/D18 Input Ethernet-0 GMII/MII Receive Clock, TBI 62.5 MHz Receive Clock 0 2.5V Signal Name FMC Pin Name/Number NET-FMC User Manual -9- www.terasic.com January 16, 2018 NET0_RX_DV LA05_N/D12 Input Ethernet-0 GMII/MII Receive Valid, TBI Transmit Data 8 2.5V NET0_RX_ER HA20_P/E18 Input Ethernet-0 GMII/MII Receive Error, TBI Transmit Data 9 2.5V NET0_RX_D[0] LA06_N/C11 Input Ethernet-0 GMII/MII/TBI Receive Data 0 2.5V NET0_RX_D[1] LA05_P/D11 Input Ethernet-0 GMII/MII/TBI Receive Data 1 2.5V NET0_RX_D[2] LA04_N/H11 Input Ethernet-0 GMII/MII/TBI Receive Data 2 2.5V NET0_RX_D[3] LA06_P/C10 Input Ethernet-0 GMII/MII/TBI Receive Data 3 2.5V NET0_RX_D[4] HA00_N_CC/F5 Input Ethernet-0 GMII/TBI Receive Data 4 2.5V NET0_RX_D[5] HA07_P/J9 Input Ethernet-0 GMII/TBI Receive Data 5 2.5V NET0_RX_D[6] HA03_P/J6 Input Ethernet-0 GMII/TBI Receive Data 6 2.5V NET0_RX_D[7] HA00_P_CC/F4 Input Ethernet-0 GMII/TBI Receive Data 7 2.5V NET0_RX_CRS CLK3_BIDIR_P/J 2 Input Ethernet-0 GMII/MII Carrier Sense, TBI Valid Comma Detect 2.5V NET0_RX_COL CLK3_BIDIR_N/J 3 Input Ethernet-0 GMII/MII Collision, TBI Mode Loopback 2.5V NET0_S_CLKp LA00_P_CC/G6 Input NET0_S_CLKn LA00_N_CC/G7 Input Ethernet-0 SGMII 625 MHz Receive Clock 2.5V NET0_S_TX_p HA04_P/F7 Output NET0_S_TX_n HA04_N/F8 Output Ethernet-0 SGMII Transmit Data 2.5V NET0_S_RX_p HA05_P/E6 Input NET0_S_RX_n HA05_N/E7 Input Ethernet-0 SGMII Receive Data 2.5V NET0_MDC LA03_P/G9 Output Ethernet-0 Management Reference Clock 2.5V NET0_MDIO LA02_N/H8 Inout Ethernet-0 Management Data 2.5V NET0_INT_n CLK0_M2C_P Input Ethernet-0 Interrupt 2.5V NET0_LED_LIN K1000 HA02_P/K7 Input Ethernet-0 Parallel LED output for 1000BASE-T link/speed or link indicator 2.5V NET0_RST_n LA02_P/H7 Output Ethernet-0 Hardware Reset, active low 2.5V NET1_GTX_CLK LA01_N_CC/D9 Output Ethernet-1 GMII/TBI Transmit Clock 2.5V NET1_TX_CLK HA19_N/F20 Input Ethernet-1 MII Transmit Clock, TBI 62.5 MHz Receive Clock 1 2.5V NET1_TX_EN LA14_P/C18 Output Ethernet-1 GMII/MII Transmit Enable, TBI Transmit Data 8 2.5V NET1_TX_ER HB02_P/F22 Output Ethernet-1 GMII/MII Transmit Error, TBI Transmit Data 9 2.5V NET1_TX_D[0] LA14_N/C19 Output Ethernet-1 GMII/MII/TBI Transmit Data 0 2.5V NET-FMC User Manual - 10 - www.terasic.com January 16, 2018 NET1_TX_D[1] LA17_P_CC/D20 Output Ethernet-1 GMII/MII/TBI Transmit Data 1 2.5V NET1_TX_D[2] LA17_N_CC/D21 Output Ethernet-1 GMII/MII/TBI Transmit Data 2 2.5V NET1_TX_D[3] LA18_P_CC/C22 Output Ethernet-1 GMII/MII/TBI Transmit Data 3 2.5V NET1_TX_D[4] HB08_P/F28 Output Ethernet-1 GMII/TBI Transmit Data 4 2.5V NET1_TX_D[5] HB07_P/J27 Output Ethernet-1 GMII/TBI Transmit Data 5 2.5V NET1_TX_D[6] HB08_N/F29 Output Ethernet-1 GMII/TBI Transmit Data 6 2.5V NET1_TX_D[7] HB11_P/J30 Output Ethernet-1 GMII/TBI Transmit Data 7 2.5V NET1_RX_CLK LA12_N/G15 Input Ethernet-1 GMII/MII Receive Clock, TBI 62.5 MHz Receive Clock 0 2.5V NET1_RX_DV LA11_N/H17 Input Ethernet-1 GMII/MII Receive Valid, TBI Transmit Data 8 2.5V NET1_RX_ER HA22_P/J21 Input Ethernet-1 GMII/MII Receive Error, TBI Transmit Data 9 2.5V NET1_RX_D[0] LA12_P/G15 Input Ethernet-1 GMII/MII/TBI Receive Data 0 2.5V NET1_RX_D[1] LA11_P/H16 Input Ethernet-1 GMII/MII/TBI Receive Data 1 2.5V NET1_RX_D[2] LA07_N/H14 Input Ethernet-1 GMII/MII/TBI Receive Data 2 2.5V NET1_RX_D[3] LA07_P/H13 Input Ethernet-1 GMII/MII/TBI Receive Data 3 2.5V NET1_RX_D[4] HB04_P/F25 Input Ethernet-1 GMII/TBI Receive Data 4 2.5V NET1_RX_D[5] HB13_P/E30 Input Ethernet-1 GMII/TBI Receive Data 5 2.5V NET1_RX_D[6] HB04_N/F26 Input Ethernet-1 GMII/TBI Receive Data 6 2.5V NET1_RX_D[7] HB09_N/E28 Input Ethernet-1 GMII/TBI Receive Data 7 2.5V NET1_RX_CRS HB05_N/E25 Input Ethernet-1 GMII/MII Carrier Sense, TBI Valid Comma Detect 2.5V NET1_RX_COL HB09_P/E27 Input Ethernet-1 GMII/MII Collision, TBI Mode Loopback 2.5V NET1_S_CLKp CLK1_M2C_P/G 2 Input Ethernet-1 SGMII 625 MHz Receive Clock 2.5V Ethernet-1 SGMII Transmit Data 2.5V Ethernet-1 SGMII Receive Data 2.5V NET1_S_CLKn CLK1_M2C_N/G 3 Input NET1_S_TX_p HA08_P/F10 Output NET1_S_TX_n HA08_N/F11 Output NET1_S_RX_p HA09_P/E9 Input NET1_S_RX_n HA09_N/E10 Input NET1_MDC LA10_N/C15 Output Ethernet-1 Management Reference Clock 2.5V NET1_MDIO LA09_N/D15 Inout Ethernet-1 Management Data 2.5V NET1_INT_n LA10_P/C14 Input Ethernet-1 Interrupt 2.5V NET-FMC User Manual - 11 - www.terasic.com January 16, 2018 NET1_LED_LIN K1000 HA02_N/K8 Input Ethernet-1 Parallel LED output for 1000BASE-T link/speed or link indicator 2.5V NET1_RST_n LA09_P/D14 Output Ethernet-1 Hardware Reset, active low 2.5V NET2_GTX_CLK LA16_P/G18 Output Ethernet-2 GMII/TBI Transmit Clock 2.5V NET2_TX_CLK HA18_P/J18 Input Ethernet-2 MII Transmit Clock, TBI 62.5 MHz Receive Clock 1 2.5V NET2_TX_EN LA15_N/H20 Output Ethernet-2 GMII/MII Transmit Enable, TBI Transmit Data 8 2.5V NET2_TX_ER HA19_P/F19 Output Ethernet-2 GMII/MII Transmit Error, TBI Transmit Data 9 2.5V NET2_TX_D[0] LA16_N/G19 Output Ethernet-2 GMII/MII/TBI Transmit Data 0 2.5V NET2_TX_D[1] LA15_P/H19 Output Ethernet-2 GMII/MII/TBI Transmit Data 1 2.5V NET2_TX_D[2] LA20_P/G21 Output Ethernet-2 GMII/MII/TBI Transmit Data 2 2.5V NET2_TX_D[3] LA20_N/G22 Output Ethernet-2 GMII/MII/TBI Transmit Data 3 2.5V NET2_TX_D[4] LA19_P/H22 Output Ethernet-2 GMII/TBI Transmit Data 4 2.5V NET2_TX_D[5] LA19_N/H23 Output Ethernet-2 GMII/TBI Transmit Data 5 2.5V NET2_TX_D[6] HB02_N/F23 Output Ethernet-2 GMII/TBI Transmit Data 6 2.5V NET2_TX_D[7] HB01_P/J24 Output Ethernet-2 GMII/TBI Transmit Data 7 2.5V NET2_RX_CLK LA30_P/H34 Input NET2_RX_DV LA31_P/G33 Input Ethernet-2 GMII/MII Receive Valid, TBI Transmit Data 8 2.5V NET2_RX_ER HB15_P/J33 Input Ethernet-2 GMII/MII Receive Error, TBI Transmit Data 9 2.5V NET2_RX_D[0] LA29_N/G31 Input Ethernet-2 GMII/MII/TBI Receive Data 0 2.5V NET2_RX_D[1] LA28_N/H32 Input Ethernet-2 GMII/MII/TBI Receive Data 1 2.5V NET2_RX_D[2] LA28_P/H31 Input Ethernet-2 GMII/MII/TBI Receive Data 2 2.5V NET2_RX_D[3] LA29_P/G30 Input Ethernet-2 GMII/MII/TBI Receive Data 3 2.5V NET2_RX_D[4] HB12_P/F31 Input Ethernet-2 GMII/TBI Receive Data 4 2.5V NET2_RX_D[5] HB16_P/F34 Input Ethernet-2 GMII/TBI Receive Data 5 2.5V NET2_RX_D[6] HB12_N/F32 Input Ethernet-2 GMII/TBI Receive Data 6 2.5V NET2_RX_D[7] HB19_N/E34 Input Ethernet-2 GMII/TBI Receive Data 7 2.5V NET2_RX_CRS HB13_N/E31 Input Ethernet-2 GMII/MII Carrier Sense, TBI Valid Comma Detect 2.5V NET2_RX_COL HB19_P/E33 Input Ethernet-2 GMII/MII Collision, TBI Mode Loopback 2.5V NET2_S_CLKp HA01_P_CC/E2 Input Ethernet-2 SGMII 625 MHz Receive 2.5V NET-FMC User Manual Ethernet-2 GMII/MII Receive Clock, TBI 62.5 MHz Receive Clock 0 - 12 - 2.5V www.terasic.com January 16, 2018 NET2_S_CLKn HA01_N_CC/E3 Input NET2_S_TX_p HA12_P/F13 Output NET2_S_TX_n HA12_N/F14 Output NET2_S_RX_p HA13_P/E12 Input NET2_S_RX_n HA13_N/E13 Input NET2_MDC LA21_N/H26 NET2_MDIO Clock Ethernet-2 SGMII Transmit Data 2.5V Ethernet-2 SGMII Receive Data 2.5V Output Ethernet-2 Management Reference Clock 2.5V LA22_N/G25 Inout Ethernet-2 Management Data 2.5V NET2_INT_n LA21_P/H25 Output Ethernet-2 Interrupt 2.5V NET2_LED_LIN K1000 HA06_P/K10 Input Ethernet-2 Parallel LED output for 1000BASE-T link/speed or link indicator 2.5V NET2_RST_n LA22_P/G24 Input Ethernet-2 Hardware Reset, active low 2.5V NET3_GTX_CLK LA30_N/H35 Output Ethernet-3 GMII/TBI Transmit Clock 2.5V NET3_TX_CLK HB16_N/F35 Input Ethernet-3 MII Transmit Clock, TBI 62.5 MHz Receive Clock 1 2.5V NET3_TX_EN LA33_P/G36 Output Ethernet-3 GMII/MII Transmit Enable, TBI Transmit Data 8 2.5V NET3_TX_ER HB18_P/J36 Output Ethernet-3 GMII/MII Transmit Error, TBI Transmit Data 9 2.5V NET3_TX_D[0] LA32_P/H37 Output Ethernet-3 GMII/MII/TBI Transmit Data 0 2.5V NET3_TX_D[1] LA31_N/G34 Output Ethernet-3 GMII/MII/TBI Transmit Data 1 2.5V NET3_TX_D[2] LA33_N/G37 Output Ethernet-3 GMII/MII/TBI Transmit Data 2 2.5V NET3_TX_D[3] LA32_N/H38 Output Ethernet-3 GMII/MII/TBI Transmit Data 3 2.5V NET3_TX_D[4] HA18_N/J19 Output Ethernet-3 GMII/TBI Transmit Data 4 2.5V NET3_TX_D[5] HB01_N/J25 Output Ethernet-3 GMII/TBI Transmit Data 5 2.5V NET3_TX_D[6] HA22_N/J22 Output Ethernet-3 GMII/TBI Transmit Data 6 2.5V NET3_TX_D[7] HB11_N/J31 Output Ethernet-3 GMII/TBI Transmit Data 7 2.5V NET3_RX_CLK LA18_N_CC/C23 Input NET3_RX_DV LA23_N/D24 Input Ethernet-3 GMII/MII Receive Valid, TBI Transmit Data 8 2.5V NET3_RX_ER LA23_P/D23 Input Ethernet-3 GMII/MII Receive Error, TBI Transmit Data 9 2.5V NET3_RX_D[0] LA27_N/C27 Input Ethernet-3 GMII/MII/TBI Receive Data 0 2.5V NET3_RX_D[1] LA27_P/C26 Input Ethernet-3 GMII/MII/TBI Receive Data 1 2.5V NET3_RX_D[2] LA26_P/D26 Input Ethernet-3 GMII/MII/TBI Receive Data 2 2.5V NET3_RX_D[3] LA26_N/D27 Input Ethernet-3 GMII/MII/TBI Receive Data 3 2.5V NET-FMC User Manual Ethernet-3 GMII/MII Receive Clock, TBI 62.5 MHz Receive Clock 0 - 13 - 2.5V www.terasic.com January 16, 2018 NET3_RX_D[4] HA07_N/J10 Input Ethernet-3 GMII/TBI Receive Data 4 2.5V NET3_RX_D[5] HA14_N/J16 Input Ethernet-3 GMII/TBI Receive Data 5 2.5V NET3_RX_D[6] HA11_N/J13 Input Ethernet-3 GMII/TBI Receive Data 6 2.5V NET3_RX_D[7] HA03_N/J7 Input Ethernet-3 GMII/TBI Receive Data 7 2.5V NET3_RX_CRS HB20_P/F37 Input Ethernet-3 GMII/MII Carrier Sense, TBI Valid Comma Detect 2.5V NET3_RX_COL HB20_N/F38 Input Ethernet-3 GMII/MII Collision, TBI Mode Loopback 2.5V NET3_S_CLKp HB21_P/E36 Input NET3_S_CLKn HB21_N/E37 Input Ethernet-3 SGMII 625 MHz Receive Clock 2.5V NET3_S_TX_p HA15_P/F16 Output NET3_S_TX_n HA15_N/F17 Output Ethernet-3 SGMII Transmit Data 2.5V NET3_S_RX_p HA16_P/E15 Input NET3_S_RX_n HA16_N/E16 Input Ethernet-3 SGMII Receive Data 2.5V NET3_MDC LA24_N/H29 Output Ethernet-3 Management Reference Clock 2.5V NET3_MDIO LA24_P/H28 Inout Ethernet-3 Management Data 2.5V NET3_INT_n LA25_P/G27 Input Ethernet-3 Interrupt 2.5V HA06_N/K11 Input LA25_N/G28 Output NET3_LED_LIN K1000 NET3_RST_n NET-FMC User Manual Ethernet-3 Parallel LED output for 1000BASE-T link/speed or link indicator Ethernet-3 Hardware Reset, active low - 14 - 2.5V 2.5V www.terasic.com January 16, 2018 Chapter 4 Example Codes This chapter provides Nios based examples for users to get started using the NET-FMC board. 4-1 Remote Update Portal A web server is implemented based on the socket’s application program interface (API) provided by the NicheStack TCP/IP Stack Nios II Edition running on a MicroC/OS-II RTOS to serve web content from the TR5 development board. Using DHCP protocol, the web server is able to request a valid IP from the Gateway. The server can process basic requests to serve HTML, JPEG, GIF, PNG, JS, CSS, SWF, ICO files from a single zip file stored onto the flash memory on the TR5 board. User can remote update the web server by rewrting the design files to the flash on the TR5 board. Figure 4-1 shows the hardware setup of demonstration. Figure 4-1 hardware setup of remote-update portal demonstration  Function block diagram Figure 4-2 shows the function block diagram of remote-update portal demonstration. Altera Triple Speed Ethernet is configured as 10/100/1000Mb Ethernet MAC with 1000BASE-X/SGMII PCS. A Generic Tri-state Controller(Flash Controller) is configured as a 1Gb Flash controller to connect the off-chip Flash chip. The SGDMA-RX and SGDMA-TX NET-FMC User Manual - 15 - www.terasic.com January 16, 2018 are used to transmit data between memory and Ethernet. The QSYS system requires one 50MHz clock resource and the Nios II program is reseting from Flash. Figure 4-2 Function block diagram of remote-update portal demonstration Design Tools   Quartus Prime 16.1 Nios II Eclipse 16.1 Demonstration Source Code   Quartus Prime project directory: TR5_RevC_NET_FMCA_SGMII_update_portal_net0_161 Nios II Eclipse: TR5_RevC_NET_FMCA_SGMII_update_portal_net0_161\software Nios Project Compilation Before you attempt to compile the reference design under Nios II Eclipse, make sure the project is cleaned first by clicking “Clean” from the “Project” menu of Nios II Eclipse. Demonstration Batch File Demo Batch File Folder: TR5_RevC_NET_FMCA_SGMII_update_portal_net0_161\demo_batch The demo batch file includes following files: NET-FMC User Manual - 16 - www.terasic.com January 16, 2018   Batch file for USB-Blaster II: test.bat, test.sh FPGA configure file: TR5_golden_top.sof  Nios II program: web_server.elf Demonstration Setup Please follow below procedures to setup the demonstrations. Generate factory_web_server.pof file  Make sure Quartus Prime and Nios II are installed on your PC.  Execute the add_path.bat file in factory_pof directory to add your file location to the .cof file. Or you will meet the error that hex files can not open.  Open the TR5_RevC_NET_FMCA_SGMII_update_portal_net0_161 project with   Quartus software. Open the Convert Programming Files window. Click the Open Conversion Setup Data button and choose the flash_web_server.cof file in factory_pof directory as shown in Figure 4-3. Figure 4-3 Selecting Conversion Setup Data  Add Sof and Hex Files. The files are added to the convert programmer defalt when NET-FMC User Manual - 17 - www.terasic.com January 16, 2018 the .cof file openned as shown in Figure 4-4. Figure 4-4 adding sof and hex files  Press Generate button to generate the new factory_web_server.pof in factory_pof directory. Write the factory_web_server.pof into Flash  Open Quartus Prime Programmer.  Connect a Mini USB Cable between the TR5 Board(J6) and the PC.  Open Hardware Setup window and choose DE5[USB-1] as shown in Figure 4-5. NET-FMC User Manual - 18 - www.terasic.com January 16, 2018 Figure 4-5 Hardware Setup on TR5     Press add file and choose the TR5_PFL.sof in factory_pof directory. Configure the FPGA by pressing Start button. Press Auto Detect button after the FPGA configured successfully. You will see a CFI_1Gb Flash detected on the JTAG chain. Press Yes to update the device list as shown in Figure 4-6. Figure 4-6 Updating the device   Use the mouse choose the CFI_1Gb device and press Change File button, browse to the factory_pof directory and choose factory_web_server.pof file. Check all the files Program and Verify option as in Figure 4-7 and press Start button to write the Flash. NET-FMC User Manual - 19 - www.terasic.com January 16, 2018 Figure 4-7 Program and Verify Options  Wait about 10 minutes until the pof file written to the flash successfully, then close the software. Get the IP address  Power down the TR5 board.  Set ETH0 MODE on the NET_FMC card to SGMII mode.The SW0[6:1] on NET-FMC should be set to 010100.  Connect the RJ45 Ethernet cable to the ETHERNET-0 on NET_FMC daughter card.  Make sure the VDDJ for FMCA port on TR5 board is 2.5V. The 7&8 Pin of JP5 on TR5 board should be shorted.  Connect the NET_FMC card on FMCA (J11) port on TR5 mainboard. Please note the demonstration is in FMCA, not in FMCD.    Set SW4(FACTORY_LOAD) on TR5 mainboard to 0. Repower the board. Open the nios2-terminal in Nios II Command Shell as shown in Figure 4-8. The command shell is located in the Nios II EDS Installation dircetory, such as D:\intelFPGA\16.1\nios2eds. NET-FMC User Manual - 20 - www.terasic.com January 16, 2018 Figure 4-8 Open nios2 terminal in Nios II Command Shell  The first time you open the terminal, the system will request you to type four digital number to generate the MAC address. You can type any 4 digital numbers as shown in Figure 4-9. Figure 4-9 type 4 digital numbers  Repower the Board again and use the nios2-terminal get the IP address as shown in Figure 4-10. We use the ip address 192.168.21.102 for example. NET-FMC User Manual - 21 - www.terasic.com January 16, 2018 Figure 4-10 get the ip address  Type the IP address in your web browser as shown in Figure 4-11, then you can access the web content. Figure 4-11 access the web content in browser NET-FMC User Manual - 22 - www.terasic.com January 16, 2018 Remote update your design  Create your custom Quartus project. If your project contains a nios II system with a  software, you should add a CFI_Flash device on address map 0x00000000 and set the nios2 reset vector to the Flash device. The offset should be 0x071c0000. In Nios II Command Shell, convert your custom sof and elf file to flash file with the below commands. For sof files: sof2flash --input=xxxx.sof --output=xxx.flash --offset=0x02940000 --pfl --optionbit=0x00030000 --programmingmode=FPP (the sof file name should be changed according to your quartus project name) For elf file: elf2flash --base=0x00000000 --end=0x07FFFFFF --reset=0x071c0000 --input=xxx.elf --output=xxx.flash --boot=$SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srec (the elf file name should be changed according to your nios2 software project name)     you can use the batch file in flash_convert directory to convert your sof and elf to flash In the web page, choose your hardware and software flash files, then press the Upload button to starting write your design files to the Flash on TR5 board. The browser will goto the reset_system page when the write process finished. Set the FACTORY_LOAD switch (SW4) to 1 and the BOOT_PAGE LED(D24) light on. Press the MAX_RST(BUTTON5), the FPGA will be configured with your design. NET-FMC User Manual - 23 - www.terasic.com January 16, 2018 Chapter 5 Appendix Revision History Version Change Log V1.0 Initial Version V1.1 Add Section 2.4 Mode Switch x 4 Setting Copyright Statement Copyright © 2017 Terasic Inc. All rights reserved. NET-FMC User Manual - 24 - www.terasic.com January 16, 2018
P0481 价格&库存
很抱歉,暂时无法提供与“P0481”相匹配的价格&库存,您可以联系我们找货
