Daburn Electronics & Cable
44 Richboynton Road
Dover, NJ 07849
Daburn SM278 Shrinkable Polyolefin Tubing - Flexible, Dual Wall
Description: DAFLEX SM278 is a flexible, large ratio, heat shrinkable tubing with a meltable adhesive
liner. When 120°C is applied, the tubing will shrink to 25% of its supplied size (4:1). Longitudinal
shrinkage is 10% maximum. As the outer wall shrinks, the inner adhesive liner melts and flows. When
cooled, it offers protection for a variety of electrical applications as well as "sealed-in" protection from
chemicals and oils. Because of its large shrink ratio and adhesive liner, it offers excellent protection for
cable repairs and retrofitting.
Operating Temperature: -55°C to +135°C.
Meets or exceeds MIL-I-23053/4 Class 3.
UL VW-1, CSA OFT (outer wall only).
This series is RoHS II, EU Directive 2011/65/EU compliant.
Shelf Life is 3 years.
Daburn
Cat. No.
Nom.
Size
Expanded ID
Recovered ID
Min. Rec. Wall
IN.
mm
IN.
mm
IN.
mm
Standard
Put-Up
SM278-3/16
3/16
.157
4
.039
1
.0354
.90
200ft Spl*
SM278-5/16
5/16
.315
8
.079
2
.0354
.90
200ft Spl**
SM278-1/2
1/2
.472
12
.118
3
.0512
1.30
400ft 4ft lgths
SM278-3/4
3/4
.630
16
.157
4
.0630
1.60
200ft 4ft lgths
SM278-1"
1"
.945
24
.236
6
.0827
2.10
100ft 4ft lgths
SM278-1 1/4"
1 1/4"
1.260
32
.315
8
.0906
2.30
80ft 4ft lgths
Standard Color: Black. Clear and other colors are available to order (Please Call).
Standard Package Shown: *Available in 1000FT, **Available in 600FT.
Specification Values:
Property
Physical
Electrical
Chemical
Unaged
Tensile strength
Elongation
Fluid
Tensile strength
Dielectric strength
Resist.
Heat shock
Low temperature flex
Secant Modulus
Dielectric strength
Volume resistivity
Copper corrosion
Fungus resistance
Water Absorption
Flammability
Tel: 973-328-3200 Fax: 973-328-3130
Test Method
ASTM D 638
ASTM D 638
ASTM D2671
250°C/4 hrs
ASTM D746
ASTM 882
ASTM D2671
ASTM D876
121C/16hrs
ASTM G21
ASTM D570
ASTM D2671
www.daburn.com
Value
Min. 1300 psi
Min. 250%
Min. 900 psi
Min. 200 Volts/mil
No cracks, flowing, or dripping
No crack @-55C
Max. 25,000 psi
Min. 300 Volts/mil
Min. 1x1012- cm
No corrosion
No growth
Max. 1.0%
Pass
很抱歉,暂时无法提供与“SM278-11/4"”相匹配的价格&库存,您可以联系我们找货
