Nuvoton
DDR Termination Regulator
NCT3107S
DATE: NOVEMBER, 2011
Revision: A2
NCT3107S
-Table of Content1.GENERATION DESCRIPTION............................................................................................. 1
2.FEATURES........................................................................................................................... 1
3.BLOCK DIAGRAM ............................................................................................................... 2
4.PIN CONFIGURATION AND TYPICAL APPLICATION CIRCUIT ....................................... 2
5.PIN DESCRIPTION............................................................................................................... 3
6.FUNCTIONAL DESCRIPTION ............................................................................................. 3
7.ELECTRICAL CHARACTERISTIC....................................................................................... 9
8.TYPICAL OPERATING CHARACTERISTICS AND WAFEFORMS .................................. 11
9.PACKAGE DIMENSION ..................................................................................................... 16
10.ORDERING INFORMATION............................................................................................. 17
11.TOP MARKING SPECIFICATION .................................................................................... 17
12.REVISION HISTORY ........................................................................................................ 18
-I-
Publication Date: Nov., 2011
Revision A2
NCT3107S
1. GENERATION DESCRIPTION
The NCT3107S is a sink/source linear regulator for DDR-SDRAM VTT bus termination.
The device contains a high speed operational amplifier to provide excellent response to
load transients and only requires a minimum output capacitance of 10uF. The NCT3107S
also incorporates a remote sensing function (VSEN pin) to provide superior load
regulation and a VREF output as a reference for the chipset and DIMMS. An additional
feature found on the NCT3107S is an active low shutdown (SD# pin) that provides
Suspend to RAM (STR) functionality. When SD# is pilled low, the VTT output voltage will
be discharged to ground but VREF remains active. A power savings advantage can be
obtained in this mode through lower quiescent current. NCT3107S is available in ESOP-8
package. It is specified from -40°C to 85°C.
2. FEATURES
General
z Sink and Source Current
z Thermal Shutdown
z Low Output Voltage Offset
z Remote Sensing (VSEN)
z No External Resistors Required
z ±10mA Buffered Reference Output
(VREF)
z Linear Topology
z Meets DDR2 Specifications; Support
DDR3 VTT Applications
z Suspend to RAM (STR) Functionality
z Low External Component Count
z ESOP-8 150mil with Exposed Pad
Package
z Required Minimum Output
Capacitance of 10uF for Memory
Termination Applications (DDR)
z Green Package (Lead Free and
Halogen Free)
z Built-in Over Current Protection
Applications
z Memory Termination Regulator for DDR2 and DDR3
z Motherboards
z LCD TV/PDP TV, Copier/Printer, Set Top Box
-1-
Revision A2
NCT3107S
3.
BLOCK DIAGRAM
2u
SD#
VDD
AVIN
7
PVIN
8
VTT
3
VSEN
Anti-shoot through Circuit
Current Limit Circuit
Thermal Protection
Shutdown
Logic
2
6
5
50k
50k
VREF
GN
Discharge
VTT
4
1
4. PIN CONFIGURATION AND TYPICAL APPLICATION CIRCUIT
AVIN
GND
1
8
VTT
SD#
2
7
PVIN
CAIN
VDDQ
EP
VSEN
VREF
3
4
6
5
SD#
PVIN
VSEN
VDDQ
CPIN
AVIN
VDDQ
AVIN
VREF=VDDQ/
CREF
VREF
SD#
VTT
GND
VTT= VREF
COU
CAIN=0.1uF, CPIN=10uF, CREF = Reserved
COUT=10uF+100uF for worse case test condition
-2-
Revision A2
NCT3107S
5. PIN DESCRIPTION
PIN NAME
NO
PIN TYPE
GND
1
Ground
SD#
2
I
VSEN
3
AI
Feedback pin for regulating VTT.
VREF
4
AO
Buffered internal reference voltage of ½VDDQ.
VDDQ
5
AI
Input for internal reference equal to ½VDDQ.
AVIN
6
Power
PVIN
7
AI
Analog input pin for internal power MOSFET source.
VTT
8
AO
Output voltage for connection to termination resistors.
EP
DESCRIPTION
Ground
Shutdown VTT output voltage.
Analog input pin for power source.
Exposed pad thermal connection. Connect to ground.
PIN TYPE
PIN Attribute
AO
Output pin (Analog)
AI
Input pin (Analog)
I
Input pin (Digital)
POWER
GROUND
Positive power supply input
Power supply ground
6. FUNCTIONAL DESCRIPTION
General Description
The NCT3107S is a sink/source linear regulator for DDR-SDRAM VTT bus termination. The
device contains a high speed operational amplifier to provide excellent response to load
transients and only requires a minimum output capacitance of 10uF. The NCT3107S also
incorporates a remote sensing function (VSEN pin) to provide superior load regulation and a
VREF output as a reference for the chipset and DIMMS. An additional feature found on the
NCT3107S is an active low shutdown (SD# pin) that provides Suspend to RAM (STR)
functionality. When SD# is pilled low, the VTT output voltage will be discharged to ground but,
VREF remains active. A power savings advantage can be obtained in this mode through lower
quiescent current.
Series Stub Termination Logic (SSTL) was created to improve signal integrity of the data
transmission across the memory bus. This termination scheme is essential to prevent data error
from signal reflections while transmitting at high frequencies encountered with DDR-SDRAM.
The DDR-SDRAM memory termination structure determines the main characteristics of the VT
rail, which is to be able to sink and source current while maintaining acceptable VTT tolerance.
Fig. 6-1 shows typical characteristics for a single memory cell.
When Q1 is on and Q2 is off:
z Current flows from VDDQ via the termination resistor to VTT
z VTT sinks current
-3-
Revision A2
NCT3107S
When Q1 is off and Q2 is on:
z Current flows from VTT via the termination resistor to GND
z VTT sources current
VDDQ
Q1
Chipset
VTT
RS
RT
Memory
Q2
VREF
GND
Fig. 6-1 DDR Physical Signal System Bi-Directional SSTL Signaling
AVIN and PVIN
AVIN and PVIN are the input supply voltage pins for NCT3107S. AVIN is used to supply the
internal control circuitry and PVIN is used to provide the rail voltage for the output staged used
to create VTT. AVIN has to be greater than or equal to PVIN in any applications. This prevents
the thermal limit from tripping because of excessive internal power dissipation. If the junction
temperature exceeds the thermal shutdown threshold, the part will enter a shutdown state
identical to the manual shutdown where VTT is tri-stated and VREF remains active. A lower rail
can be used but it will reduce the maximum output current.
VDDQ
VDDQ is the input used to create the internal reference voltage for regulating VTT. The
reference voltage is generated from a resistor divider of two internal 50kΩ resistors. This
guarantees that VTT will precisely track VREF. The optimal implementation of VDDQ is as a
remote sense. This can be achieved by connecting VDDQ directly to the power rail at the DIMM
instead of PVIN. This ensures that the reference voltage precisely tracks the DDR memory rails
without a large voltage drop from the power lines.
VREF
VREF provides the buffered output of the internal reference voltage ½VDDQ. This output
should be used to provide the reference voltage for chipset and memory. Typically, there is no
necessary to place output capacitor. But for worse condition, an output bypass capacitor could
be reserved, close to the pin, to secure a suitable phase margin. Insufficient capacitance may
cause an oscillation. A ceramic capacitor in the range 0.01uF to 0.1uF is recommended. The
output remains active during the shutdown state and thermal shutdown events for the Suspend
to RAM functionality.
VTT
VTT is the regulated output that is used to terminate the bus resistors. It is capable of sinking
and sourcing current while regulating the output precisely to VREF. If a transient is expected to
last above the maximum continuous current rating for a significant amount of time, then the bulk
output capacitor should be sized large enough to prevent an excessive voltage drop. If the
NCT3107S is to operate in elevated temperatures for long durations, care should be taken to
ensure the maximum operating junction temperature is not exceeded. Proper thermal de-rating
-4-
Revision A2
NCT3107S
should always be used. If the junction temperature exceeds the thermal shutdown threshold,
VTT will tri-state until the part returns below the temperature hysteresis trip-point.
VSEN
The purpose of the sense pin is to provide improved remote load regulation. In most
motherboard applications, the termination resistors will connect to VTT in a long plane. If the
output voltage was regulated only at the output of the NCT3107S, then the long trace will cause
a significant DC voltage drop resulting in a termination voltage lower at one end of the bus than
the other. The VSEN pin can be used to improve this performance by connecting it to the
middle of the bus. This will provide a better distribution across the entire termination bus. If
remote load regulation is not used, then the VSEN pin must be connected to VTT. Care should
be taken when a long VSEN trace is implemented in close proximity to the memory. Noise pick
up in the VSEN trace can cause problems with precise regulation of VTT. A small 0.1uF
ceramic capacitor placed next to the VSEN pin can help filter any high frequency signals and
prevent errors.
Shutdown
The NCT3107S contains an active low shutdown pin that can be used for Suspend to RAM
functionality. In the condition, the VTT output voltage will be discharged to ground while the
VREF output remains active and provides a constant reference signal for the memory and
chipset. During shutdown, VTT should not be exposed to voltages that exceed PVIN. With the
shutdown pin asserted low, the quiescent current of the NCT3107S will drop. However, VDDQ
always maintain its constant impedance of 100kΩ for generating the internal reference.
Therefore, to calculate the total power loss in shutdown, both currents need to be considered.
The shutdown pin also has an internal pull up current. Therefore, to turn the part on, the
shutdown pin can either be connected to AVIN or left open.
Current Limit Protection
The NCT3107S provides a current limit circuitry for short circuit protection, which monitors the
output current and controls internal power MOSFET gate voltage to limit the output current. This
reduction is a non latch protection.
Thermal Shutdown
The NCT3107S has a thermal shutdown circuitry to limit the junction temperature. When the
junction temperature exceeds 150°C, the thermal shutdown circuitry let the output into tri-state,
allowing the device to cool down. The output circuitry is enabled again after the junction
temperature cools down by 30°C, resulting in a pulsed output during continuous thermal
overload conditions. The thermal protection is designed to protect the IC in the event of over
temperature conditions. For reliabile operation, the junction temperature cannot exceed 125°C.
Input Decoupling
To achieve the best results when using the NCT3107S, decouple the power supply for AVIN
with a 0.1uF to 4.7uF capacitor. For PVIN pin, use a 10uF (or greater) capacitor to improve
performance during large load transients to prevent the input rail from dropping. Provide more
input capacitance as more output capacitance is used at VTT. In general, use one-half of the
COUT value for input. Use a high quality ceramic surface mount capacitor if possible. Surface
mount components minimize lead inductance, which improves performance, and ceramic
capacitors tend to have adequate high frequency response for decoupling applications.
-5-
Revision A2
NCT3107S
Output Stability
To maintain circuit stability and improve transient response over temperature and current, the
NCT3107S needs a suitable output capacitor. In order to insure the circuit stability, the suitable
output capacitor should be larger than 10uF. For worse case test condition (from maximum
sinking current to maximum sourcing current), the capacitance has to be large than 100uF. The
choice for output capacitor will be determined solely on the application and the requirements for
load transient response of VTT. The value of ESR should be determined by the maximum
current spikes expected and the extent at which the output voltage is allowed to droop.
Thermal Design
Because the NCT3107S is a linear regulator, the VTT current flows in both source and sink
directions, thereby dissipating power from the device. When the device is sourcing current, the
voltage difference between PVIN and VTT times IOUT current becomes the power dissipation
as shown in below equation.
PDISS_SRC = (PVIN - VTT) × IOUTSRC
In this case, if PVIN is connected to an alternative power supply lower than the VDDQ voltage,
overall power loss can be reduced. For the sink phase, VTT voltage is applied across the
internal LDO regulator, and the power dissipation, PDISS_SNK can be calculated by below
equation.
PDISS_SNK = VTT × IOUTSNK
Since the device does not sink and source at the same time and IOUT varies rapidly with time,
actual power dissipation need to be considered for thermal design is an average of above value
over thermal relaxation duration of the system. Another source of power consumption is the
current used for internal control circuitry from AVIN supply and PVIN supply. This can be
estimated as 5mW or less during normal operating conditions. This power must be effectively
dissipated from the package.
Maximum power dissipation allowed by the package is calculated by below equation.
PPKG = [TJ (MAX) – TA (MAX)] / θJA
where
z TJ (MAX) is +125°C
z TA (MAX) Is the maximum ambient temperature in the system
z θJA Is the thermal resistance from junction to ambient
θJA highly depends on IC package, PCB layout, the aireflow. Thermal resistance θJA can be
improved by adding copper under the exposed pad of ESOP-8 while the IC package is fixed.
The copper under the exposed pad of ESOP-8 is an effective heatsink and is useful for
improving thermal conductivity. Figure show the relationship between thermal resistance θJA vs.
copper area on a standard JEDEC 51-7 (4 layers, 2S2P) thermal test board at TA = 25°C, PCB
copper thickness = 2oz. The 70mm2 copper plane reduce θJA from 75°C/W to 45°C/W and
increases maximum power disspation from 1.33W to 2.22W.
-6-
Revision A2
NCT3107S
70mm2 copper area
30mm2 copper area
Minimum copper area
Fig. 6-2 Power Dissipation vs. Ambient Temperature
Fig. 6-3 Thermal Resistance θJA vs. Copper Area of
ESOP Packages
Layout Consideration
Consider the following points before starting the NCT3107S layout design.
z
The input bypass capacitors for AVIN, PVIN and VSEN should be placed as close as
possible to the pin with short and wide connections.
z
The output capacitors for VTT and VREF should be placed close to the pin with short and
wide connection in order to avoid ESR and/or ESL trace inductance.
z
VSEN should be connected to the positive node of VTT output capacitor(s) as a separate
trace from the high current power line. The configuration is strongly recommended to avoid
additional ESR and/or ESL. If sensing the voltage at the point of the load is required, it is
recommended to attach the output capacitor(s) at that point. Also, it is recommended to
minimized any additional ESR and/or ESL of ground trace between the GND pin and the
output capacitor(s).
z
VDDQ can be connected separately from PVIN. Remember that this sensing potential is the
reference voltage of VREF. Avoid any noise generative lines.
z
The negative nose of the VTT output capacitor(s) and the VREF capacitor should be tied
together by avoiding common impedance to the high current path of the VTT source/sink
current. Also, place bulk caps close to the DIMM load point, route the VSEN to the DIMM
load sense point.
z
In order to effectively remove heat from the package, properly prepare the thermal land.
Apply solder directly to the package’s thermal pad. The wide traces of component and the
side copper connected to the thermal land pad help to dissipate heat. The thermal land
connected to the ground plane could also be used to help dissipation. Numerous vias
connected from the thermal land to the internal/solder side ground plane(s) should also be
-7-
Revision A2
NCT3107S
75
90
219
90
Unit: mil
(Not to scale)
50
24
Fig. 6-4 Recommended Land Pattern
Ground Layer (Top Layer)
for Heat Dissipating
COUT
Connection to
Internal Ground
Layer
GND
VTT
SD#
PVIN
VSEN
AVIN
VREF
CREF
CPIN
CAIN
VDDQ
Ground Layer
nd
(2 Layer)
CDDQ
Fig. 6-5 PCB Layout Guideline
-8-
Revision A2
NCT3107S
7. ELECTRICAL CHARACTERISTIC
Absolute Maximum Ratings
PARAMETER
RATING
UNIT
Power Pins AVIN, PVIN, VDDQ
-0.3 to 6V
V
Voltage on Other Pins
-0.3 to 6V
V
Junction Temperature
150
°C
Storage Temperature
-50 to 150
°C
Soldering Temperature
Refer to IPC/JEDEC J-STD-020 Specification
Human Body Mode
2
kV
Machine Mode
200
V
Latch-up
100
mA
ESD Protection
Note1. No pin should exceed AVIN.
Note2. Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device.
These are stress ratings only and functional operation of the device at these or any other conditions beyond
those indicated under recommended operating conditions is not implied. Exposure to absolute maximum rated
conditions for extended periods may affect device reliability.
Note3. Devices are ESD sensitive. Handling precaution recommended.
Thermal Information
ITEM
Power Dissipation, PD @ TA=25℃
Package Thermal Resistance, ESOP8, θJA
RATING
UNIT
1.33
W
75
℃/W
Note1. At elevated temperatures, devices must be de-rated based on thermal resistance. The device in the ESOP-8
package must be de-rated at θJA=75˚C/W junction to ambient with minimum PCB footprint.
Recommended Operating Conditions
PARAMETER
RATING
UNIT
Operating Temperature
-40 to 85
°C
-40 to 125
°C
Supply Voltage, AVIN
2.2 to 5.5
V
Capacitance of AVIN Decoupling Capacitor
0.1 to 4.7
uF
Capacitance of PVIN Decoupling Capacitor
10 to 270
uF
Capacitance of VDDQ Decoupling Capacitor
0.1 to 270
uF
Capacitance of VREF Regulation Capacitor
0.01 to 0.1
uF
Capacitance of VTT Regulation Capacitor
10 to 470
uF
-9-
Revision A2
NCT3107S
Electrical Characteristics
AVIN=2.5V, PVIN=VDDQ=1.8V, COUT=10uF and all outputs are unload (unless otherwise noted). Typical value are at
Ta=25°C and limits apply over the full operating temperature, Ta= -40~85°C.
PARAMETER
SYM.
MIN.
TYP.
MAX.
UNIT
0.49×VDDQ
0.5×VDDQ
0.51×VDDQ
V
CONDITIONS
Reference Voltage
VREF
Source Current
IREF+
Sink Current
IREF-
VREF Voltage Tolerance
10
mA
-15
VDDQ Input Impedance
IREF=0mA
-10
mA
+15
mV
ZVDDQ
100
IQ
320
500
IREF=±10mA
kΩ
Input / Output Current
Quiescent Current
(1)
Shutdown Quiescent Current
(1)
uA
IOUT=0A
ISD
115
150
uA
SD#=0V
Shutdown Leakage Current
IQ_SD
2
5
uA
SD#=0V
VSEN Input Current
IVSEN
1
uA
VTT Discharge Current in
Shutdown
-1
IVTT_Dis
mA
SD#=0V, VTT=0.4V
Output Voltage Offset (VREF-VTT)
DDR2, PVIN=VDDQ=1.8V
-20
mV
IOUT=0A
DDR3, PVIN=VDDQ=1.5V
-20
mV
IOUT=0A
-30
30
mV
IOUT =±1.5A
(2)
-30
30
mV
IOUT =±1.2A
(2)
VOS
Logic Input Level
Minimum Shutdown High Level
VIH
Maximum Shutdwon Low Level
VIL
1.9
V
0.8
V
AVIN=2.2V~5.5V
Output Current Limit
ILIM
2.5
A
PVIN=VDDQ=1.8V
1.5
A
PVIN=VDDQ=1.5V
Over Temperature Protection
(3)
Thermal Shutdown Temperature
145
150
160
°C
Thermal Shutdown Hysteresis
40
°C
Note1. Quiescent is defined as the current flow into AVIN.
Note2. VTT load regulation is tested by using a 10ms current pulse and measuring VTT.
Note3. The maximum allowable power dissipation is a function of the maximum junction temperature, TJ (MAX), the
junction to ambient thermal resistance, θJA, and the ambient temperature, TA exceeding the maximum allowable
power dissipation will cause excessive die temperature and the regulator will go into thermal shutdown. Ensured
by design, no production tested.
Note4. Limits are 100% production tested at 25˚C. Limits over operating temperature range are guaranteed through
correlation using Statistical Quality Control (SQC) methods. The limits are used to calculate average outgoing
quality level.
-10-
Revision A2
NCT3107S
8. TYPICAL OPERATING CHARACTERISTICS AND WAFEFORMS
AVIN Operating Current vs AVIN
AIVIN Shutdown Current vs AVIN
400
180
390
170
160
370
Current (uA)
360
350
340
150
140
130
120
330
110
320
100
310
2.5
3.0
3.5
4.0
4.5
5.0
2.5
5.5
3.0
3.5
4.0
5.0
5.5
4.0
5.0
6.0
VTT vs VDDQ
3000
3000
2500
2500
2000
2000
VTT (mV)
VTT (mV)
VREF vs VDDQ
1500
1500
1000
1000
500
500
1.0
2.0
3.0
4.0
5.0
6.0
0.0
1.0
2.0
VDDQ (V)
VTT_VREF_VOS vs AVIN
8.9
8.4
758
8.8
8.3
VOS
904
760
8.2
902
8.1
900
8.0
VTT
898
7.9
756
7.7
742
4.5
5.0
8.3
VTT
746
894
4.0
8.4
748
744
3.5
8.5
750
7.8
3.0
8.6
VOS
752
896
2.5
8.7
VREF
754
VTT (mV)
VREF
8.5
Offset Voltage (mV)
908
906
3.0
VDDQ (V)
910
VTT (mV)
4.5
Voltage (V)
Voltage (V)
5.5
8.1
8.0
2.5
AVIN (V)
8.2
Offset Voltage (mV)
Current (uA)
380
3.0
3.5
4.0
4.5
5.0
5.5
AVIN (V)
-11-
Revision A2
NCT3107S
VREF vs IREF
0.918
0.770
0.916
0.914
0.768
0.765
0.912
VREF (V)
VREF (V)
VREF vs IREF
0.910
0.908
0.906
Continuous Load
0.904
0.902
0.763
0.760
0.758
Continuous Load
0.755
0.753
0.900
0.750
-20 -16 -12 -8
-4
8
12 16 20
-20 -16 -12 -8
IREF (mA)
4
8
12 16 20
VREF Sinking Current Limit vs AVIN
140
120
120
100
Curent (mA)
100
Curent (mA)
IREF (mA)
VREF Sourcing Current Limit vs AVIN
80
60
40
80
60
40
3.0
3.5
4.0
4.5
5.0
5.5
3.0
3.5
4.0
4.5
5.0
5.5
AVIN (V)
AVIN (V)
VTT vs IVTT
VTT vs IVTT
0.950
0.790
0.940
0.780
0.930
0.770
0.920
VTT (V)
VTT (V)
-4
0.910
0.900
0.760
0.750
0.740
0.890
0.880
Continuous Load
-2.0
-1.5
-1.0
-0.5
0.0
0.5
1.0
1.5
Continuous Load
0.730
0.870
2.0
IVTT (A)
-12-
0.720
-2.0
-1.5
-1.0
-0.5
0.0
0.5
IVTT (A)
1.0
1.5
2.0
Revision A2
NCT3107S
AVIN Shutdown Current vs AVIN
430
190
410
-40°C
0°C
180
-40°C
170
370
Current (uA)
Current (uA)
390
25°C
350
330
85°C
310
160
150
140
120
270
110
3.0
3.5
4.0
4.5
5.0
5.5
25°C
130
290
250
2.5
0°C
85°C
100
2.5
3.0
3.5
4.0
Voltage (V)
VTT vs IVTT
5.0
5.5
VTT vs IVTT
0.775
0.930
85°C
0.925
0.765
0°C
VTT (V)
0.915
25°C
0.910
85°C
0.770
0.920
VTT (V)
4.5
Voltage (V)
0.905
0°C
0.760
25°C
0.755
0.750
0.900
-40°C
0.745
0.895
-40°C
0.740
0.890
-100 -75
-50
-25
50
75
-100 -75
100
-50
-25
50
75
100
IVTT (mA)
IVTT (mA)
SD# Threshold vs AVIN
1.8
1.6
1.4
VIH
SD# (V)
1.2
1.0
0.8
VIL
0.6
0.4
0.2
0.0
2.5
3.0
3.5
4.0
4.5
5.0
5.5
AVIN (V)
-13-
Revision A2
NCT3107S
Operating Waveforms
AVIN=2.5V, PVIN=VDDQ=1.8V, COUT=10uF MLCC
Sourcing
DDR2
Sinking
IOUT=10mA -> 1.5A
DDR2
Sourcing
DDR3
IOUT=-10mA -> -1.5A
Sinking
IOUT=10mA -> 1.2A
DDR3
Sourcing
IOUT=-10mA -> -1.2A
Sinking
-14-
Revision A2
NCT3107S
DDR2
DDR3
COUT=10uF, MLCC
COUT=10uF, MLCC
IOUT=-1.5A -> 1.5A
IOUT=-1.2A -> 1.2A
Sourcing
Sourcing
Sinking
Sinking
DDR2
DDR3
COUT=220uF, electrolytic cap.
IOUT=-1.5A -> 1.5A
IOUT=-1.2A -> 1.2A
Sourcing
Sinking
Sourcing
Sinking
-15-
Revision A2
NCT3107S
9. PACKAGE DIMENSION
Taping Specification
-16-
Revision A2
NCT3107S
8 Pin ESOP Package
10. ORDERING INFORMATION
Part Number
Supplied as
Production Flow
T Shape: 2,500 units/T&R
Commercial, -40°C to + 85°C
Package Type
8PIN ESOP (Green
Package)
NCT3107S
11. TOP MARKING SPECIFICATION
3 1 0 7 S
046AX
Pin 1 index
1st Line: Nuvoton logo
2nd Line: 3107S (NCT3107S)
3rd line: Tracking code
z
046: packages assembled in Year 2010, week 46
z
A: assembly house ID.
z
X: IC version. (A means A; B means B and C means C…etc.
-17-
Revision A2
NCT3107S
12. REVISION HISTORY
VERSION
DATE
PAGE
DESCRIPTION
A0
2010/12/17
All
First Published
A1
2011/1/17
8
Add PCB Layout Guideline
1. Modified Recommended Land Pattern
A2
2011/11/10
8, 16, 17 & 19
2. Modified Thermal Pad Dimension
3. Modified Ordering Information
4. Modified Importance Notice
-18-
Revision A2
NCT3107S
Important Notice
Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any
malfunction or failure of which may cause loss of human life, bodily injury or severe property
damage. Such applications are deemed, “Insecure Usage”.
Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic
energy control instruments, airplane or spaceship instruments, the control or operation of
dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all
types of safety devices, and other applications intended to support or sustain life.
All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay
claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the
damages and liabilities thus incurred by Nuvoton.
-19-
Revision A2
