CLM-9-30-80-36-AC02-F2-2 数据手册
CLM-9 Product Datasheet
Preliminary
CLM-9 COB Arrays
White LED
Features:
• High lumen output and efficacy typical
Table of Contents
• Over 730 lm, 127 LPW @ 3000K, 25ºC
Technology Overview. . . . . . 2
• Over 800 lm, 139 LPW @ 5000K, 25ºC
Test Specifications . . . . . . . . . 2
• Complete CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K
• 80 or 90 CRI min. up to 95 min. in warm white
Chromaticity Bins. . . . . . . . . . 3
• 2-step and 3-step MacAdam Ellipse color binning accuracy
Product Ordering & Shipping
Part Numbers. . . . . . . . . . . . . . 4
• Excellent optical emission uniformity and color over angle consistency
Product Typical Flux Range. 5
• Superior thermal conductivity for uniform heat spreading
Operating Characteristics . . 7
• Exceptional long term color stability
• Environmentally friendly: RoHS and REACh compliant
Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 8
Spectra. . . . . . . . . . . . . . . . . . . 10
Mechanical Dimensions. . . 11
Packaging Information. . . . 11
Handling Notes. . . . . . . . . . . 12
Applications
• Spotlights/Track Lights
• Hospitality Lighting
• Downlights
• Architectural and Specialty
• Replacement lamps
• Parking Lot and Area Lighting
• Shop Lighting
1
PDS-002436 Rev 03
© 2015 Luminus Devices, Inc. - All Rights Reserved
Preliminary
Technology Overview
Luminus XNova™ Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination
applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can
deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and
designers to develop lighting solutions with maximum efficacy, brightness and overall quality.
Reliability
Designed from the ground up, the XNova™ COB LED is one of
the most reliable light sources in the world today. Having
passed a rigorous suite of environmental and mechanical stress
tests, including mechanical shock, vibration, temperature
cycling and humidity. Only then are the devices qualified for
use in a wide range of lighting application including some of the
most demanding commercial applications. Delivered with fully
qualified LM80 test data and TM21 lifetime results that certify
lumen maintenance at 35,000 hours or more, XNova™ COB LEDs
are ready for the toughest challenges.
UL Recognized Compliance
XNova COB arrays are tested in accordance with ANSI/UL 8750
to ensure safe operation for their intended applications.
REACh & RoHS Compliance
All LED products manufactured by Luminus are REACh and
RoHS compliant and free of hazardous materials, including lead
and mercury.
Understanding XNova™ COB LED Test Specifications
Every XNova™ LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products.
Traceability
Chromaticity Bin Range
Each XNova COB LED is marked with a 2D bar code that contains
a unique serial number. With this serial number, Luminus has
the ability to provide customers with actual test data
measurements for a specific LED. In addition, the 2D bar code is
linked to manufacturing date codes that enables traceability of
production processes and materials.
Chromaticity binning delivers color consistency for every order.
Standard products are delivered with a 3-step MacAdam ellipse.
This ensures color performance matching in the application. For
the most demanding application, Luminus is one of only a few
companies that can provide a 2-step ellipse bin. These tightly
controlled, small distribution bins provide customers
predictable, repeatable colors.
Testing Temperature
XNova™ COB products are measured at temperatures typical for
the LED operating in the fixture. Each device is tested at 85ºC
junction temperature eliminating the need to scale data sheet
specifications to real world situations.
2
PDS-002436 Rev 03
Preliminary
Chromaticity Bin Structure
Chromaticity Bins: 1931 CIE Curve
0.46
ANSI C78.377-2008
2-step Ellipse
3-step Ellipse
5-step Ellipse
0.44
2700K
3000K
3500K
0.42
Black Body
4000K
CIE y
0.4
5000K
0.38
0.36
6500K
0.34
0.32
0.3
0.3
0.32
0.34
0.36
0.38
0.4
0.42
0.44
0.46
0.48
0.5
CIE x
CLM-9 White Chromaticity Bins
The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for
the ellipses. The ANSI Bin is provided for reference.
Center Point
5-step Bin
3-step Bin
2-step Bin
Angle
CCT
CIEx
CIEy
θ (°)
a
b
a
b
a
b
2700K
0.4578
0.4101
53.7
0.0054
0.0028
0.0081
0.0042
0.0135
0.007
3000K
0.4338
0.403
53.2
0.00556
0.00272
0.00834
0.00408
0.0139
0.0068
3500K
0.4073
0.3917
54
0.00618
0.00276
0.00927
0.00414
0.01545
0.0069
4000K
0.3818
0.3797
53.7
0.00626
0.00268
0.00939
0.00402
0.01565
0.0067
5000K
0.3447
0.3553
59.6
0.00548
0.00236
0.00822
0.00354
0.0137
0.0059
6500K
0.3123
0.3282
58.57
0.00446
0.0019
0.00669
0.00285
0.01115
0.00475
*Note:
Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements.
3
PDS-002436 Rev 03
Preliminary
Product Ordering and Shipping Part Number Nomenclature
All CLM-9 products are packaged and labeled with part numbers as outlined in the table on pages 5. Luminus may include any smaller
chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single
flux and chromaticity bin. The part number designation is as follows:
CLM
9
NN
Product Family
Light Emitting
Surface Diameter
Color
Temperature
CLM: Chip on
Board, XNova,
Multi-die
9 : LES
Diameter (mm)
Color
See Note 1
below
CLM-9
XX
36
QQPP
FG
W
Color Rendering Index (CRI)
Voltage
(typical)
Package
Configurator
Flux Bin
Chromaticity
Bin
CRI
Volts
AC00
(Basic package)
Lumens
See page 4 for
bins
Note 1: NN nomenclature corresponds to the following color temperatures:
27 = 2700K
30 = 3000K
35 = 3500K
40 = 4000K
50 = 5000K
65 = 6500K
Color Temperature, CRI and R9 Values
Color Temperatures
XX Value
CRI
R9
2700K, 3000K, 3500K, 4000K, 5000K, 6500K
80
>80
>0
90
>90
>50
95
>95
2700K, 3000K
4000K
Note:
>90
>75
Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released
and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part
number described above will always be included.
4
PDS-002436 Rev 03
Preliminary
CLM-9 Part Numbers (Typical)
The following tables describe products with typical flux and minimum flux measured at 160mA and specified at T = 85ºC. The values at
25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Luminus may
choose to ship a smaller chromaticity bin in an order for a larger.
Reference
Color
Rendering
Index
Typ.
Typ.
Min.
(calculated)
(85ºC) (85ºC)
(25ºC)
CRI (min.)
2-step MacAdam Ellipse
Output Flux
(lm)
CCT
2700K
3000K
3500K
4000K
Ordering Part Number
630
600
690
80
CLM-9-27-80-36-AC00-F2-3
CLM-9-27-80-36-AC00-F2-2
490
465
540
90
CLM-9-27-90-36-AC00-F2-3
CLM-9-27-90-36-AC00-F2-2
460
435
510
95
CLM-9-27-95-36-AC00-F2-3
CLM-9-27-95-36-AC00-F2-2
660
625
730
80
CLM-9-30-80-36-AC00-F2-3
CLM-9-30-80-36-AC00-F2-2
560
530
620
90
CLM-9-30-90-36-AC00-F2-3
CLM-9-30-90-36-AC00-F2-2
520
495
570
95
CLM-9-30-95-36-AC00-F2-3
CLM-9-30-95-36-AC00-F2-2
690
645
760
80
CLM-9-35-80-36-AC00-F2-3
CLM-9-35-80-36-AC00-F2-2
590
550
650
90
CLM-9-35-90-36-AC00-F2-3
CLM-9-35-90-36-AC00-F2-2
710
665
780
80
CLM-9-40-80-36-AC00-F2-3
CLM-9-40-80-36-AC00-F2-2
610
570
670
90
CLM-9-40-90-36-AC00-F2-3
CLM-9-40-90-36-AC00-F2-2
560
530
615
95
CLM-9-40-95-36-AC00-F2-3
CLM-9-40-95-36-AC00-F2-2
Reference
Color
Rendering
Index
Typ.
Min..
(calculated)
(85ºC)
(25ºC)
CRI (min.)
5-step MacAdam Ellipse
Output Flux
(lm)
Part Number
CCT
Typ.
(85ºC)
5000K
720
675
800
80
CLM-9-50-80-36-AC00-F2-5
CLM-9-50-80-36-AC00-F2-3
6500K
720
675
800
80
CLM-9-65-80-36-AC00-F2-5
CLM-9-65-80-36-AC00-F2-3
*Note:
Luminus maintains a +/- 6% tolerance on flux measurements.
Luminus maintains a +/- 2% tolerance on CRI measurements.
5
PDS-002436 Rev 03
(Part
CLM-9
#) Product
Product
Datasheet
Datasheet
Preliminary
The following tables describe products with typical flux and minimum flux measured at 480mA and specified at T = 85ºC. The values at
Reference
Color
Rendering
Index
Typ.
Typ.
Min.
(calculated)
(85ºC) (85ºC)
(25ºC)
CRI (min.)
Output Flux
(lm)
CCT
2700K
3000K
3500K
4000K
630
600
690
80
CLM-9-27-80-12-AC00-F2-3
CLM-9-27-80-12-AC00-F2-2
490
465
540
90
CLM-9-27-90-12-AC00-F2-3
CLM-9-27-90-12-AC00-F2-2
460
435
510
95
CLM-9-27-95-12-AC00-F2-3
CLM-9-27-95-12-AC00-F2-2
660
625
730
80
CLM-9-30-80-12-AC00-F2-3
CLM-9-30-80-12-AC00-F2-2
560
530
620
90
CLM-9-30-90-12-AC00-F2-3
CLM-9-30-90-12-AC00-F2-2
520
495
570
95
CLM-9-30-95-12-AC00-F2-3
CLM-9-30-95-12-AC00-F2-2
690
645
760
80
CLM-9-35-80-12-AC00-F2-3
CLM-9-35-80-12-AC00-F2-2
590
550
650
90
CLM-9-35-90-12-AC00-F2-3
CLM-9-35-90-12-AC00-F2-2
710
665
780
80
CLM-9-40-80-12-AC00-F2-3
CLM-9-40-80-12-AC00-F2-2
610
570
670
90
CLM-9-40-90-12-AC00-F2-3
CLM-9-40-90-12-AC00-F2-2
560
530
615
95
CLM-9-40-95-12-AC00-F2-3
CLM-9-40-95-12-AC00-F2-2
Reference
Color
Rendering
Index
Typ.
Min..
(calculated)
(85ºC)
(25ºC)
CRI (min.)
Output Flux
(lm)
Part Number
CCT
Typ.
(85ºC)
5000K
720
675
800
80
CLM-9-50-80-12-AC00-F2-5
CLM-9-50-80-12-AC00-F2-3
6500K
720
675
800
80
CLM-9-65-80-12-AC00-F2-5
CLM-9-65-80-12-AC00-F2-3
*Note:
6
PDS-002436 Rev 03
Preliminary
CLM-9 Operating Characteristics1
Parameter
Symbol
Forward Current (35V)
If
Forward Voltage3
Vf
Forward Current (12V)2
If
Forward Voltage3
Vf
2
Minimum
33.5
11.2
Power
Operating Case Temperature4
Light Emitting Surface Diameter
Typical
Maximum
Unit
160
350
mA
35
37.5
V
480
1050
mA
11.7
12.5
V
5.6
14
W
105
ºC
Tc
LES
9
mm
Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC.
Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions
Note 3: Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs.
Note 4: CLM-9 COB LEDs are designed for operation up to an absolute maximum forward drive current as specified above. Refer to the current vs. case
temperature derating curves for further information.
Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye.
7
PDS-002436 Rev 03
Preliminary
CLM-9 Optical & Electrical Characteristics (35V)
Relative Output Flux vs. Forward Current @ 85ºC
Forward Current vs. Forward Voltage @ 85ºC
350
220%
200%
300
160%
Forward Current (mA)
Relative Luminous Flux
180%
140%
120%
100%
80%
60%
40%
250
200
150
100
20%
50
0%
50
100
150
200
250
300
32
350
33
34
35
Relative Output Flux vs. Junction Temperature
38
39
40
40
1
38
Forward Voltage (V)
37
Change in Voltage vs. Junction Temperature
1.2
0.8
0.6
0.4
36
34
32
0.2
5
15
25
35
45
55
65
75
85
95
5
105
15
25
35
45
Junction Temperature (ºC)
55
65
75
85
95
105
Change CIEx vs. Junction Temperature (3000K, 80CRI)
Change CIEy vs. Junction Temperature (3000K, 80CRI)
0.02
0.02
0.01
0.01
Δ CIEy
Δ CIEx
36
Forward Voltage (V)
-0.02
-0.02
5
15
25
35
45
55
65
75
8
PDS-002436 Rev 03
85
95
105
5
15
25
35
45
55
65
75
85
95
105
Preliminary
CLM-9 Optical & Electrical Characteristics (12V)
1100
250.0%
1000
900
200.0%
150.0%
100.0%
800
700
600
500
400
50.0%
300
0.0%
200
300
400
500
600
700
800
900
200
1000
10.5
11
11.5
12
12.5
13
Forward Voltage (V)
14
1.2
Forward Voltage (V)
1
0.8
0.6
0.4
12
0.2
10
15
25
35
45
55
65
75
85
95
5
105
15
25
35
45
65
75
85
95
105
0.02
0.02
0.01
0.01
Δ CIEy
Δ CIEx
55
-0.02
-0.02
5
15
25
35
45
55
65
75
9
PDS-002436 Rev 03
85
95
105
5
15
25
35
45
55
65
75
85
95
105
Preliminary
Typical Spectrum
120.00%
100.00%
Relative Intensity
80.00%
Warm White
60.00%
Neutral White
Cool White
40.00%
3000K-90CRI
3000K-97CRI
20.00%
0.00%
400
450
500
-20.00%
550
600
650
700
750
800
Wavelength (nm)
Typical Polar Radiation Pattern
Typical Angular Radiation Pattern
120%
100%
Relative Intensity (%)
80%
60%
40%
20%
0%
-80
-60
-40
-20
Anglular Displacement (Degrees)
10
PDS-002436 Rev 03
40
60
80
Preliminary
Shipping Container
Each bag is boxed for
easier storage/stacking
Trays are sealed in an
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
11
PDS-002436 Rev 03
5 trays are stacked together
with one tray as a cover
Handling Notes for XNova COBs
Preliminary
XNova products are designed for robust performance in general lighting application. However, care must be taken when handling and
assembling the LEDs into their fixtures. To avoid damaging XNova COBs please follow these guide lines.
The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More
detailed information is available on the Luminus web site at www.luminus.com.
General Handling
Electrical Contact
Devices are made to be lifted or carried with tweezers on two
adjacent corners opposite the contact pads. At no time should
the devices be handled by or should anything come in contact
with the light emitting surface (LES) area. This area includes the
yellow colored circular area and the ring surrounding it. There
are electrical connections under the LES which if damaged will
cause the device to fail.
XNova COBs are designed with contact pads on their top
surface. These pads are clearly marked with + and – polarity.
Wires can be soldered to the contact pads for electrical
connections or other solderless connector products are
available.
In addition, the ring frame itself should not be used for moving,
lifting or carrying the device. Also do not attach any optics or
mechanical holders to the ring as it is not capable to handle the
mechanical stress.
If wires are being soldered to the COB product, we recommend
attaching these wires prior to mounting the devices to a heat
sink. Please contact Luminus for specific recommendations on
how to solder wires if not familiar with the standard practice.
Luminus can also offer design recommendations for jigs to
allow easily soldering multiple products in rapid succession.
Static Electricity
Chemical Compatibility
XNova COBs are electronic devices which can be damaged by
electrostatic discharge (ESD). Please use appropriate measures
to assure the devices do not experience ESD during their
handling and or storage. ESD protection guidelines should be
used at all times when working with XNova COBs.
The resin material used to form the LES can getter hydrocarbons
from the surrounding environment. As a results, certain
chemical compounds are not recommended for use with the
XNova products. Use of these compounds can cause damage to
the light output of the device and may permanently damage
the device. Please refer to www.luminus.com for a list of the
compounds not recommended for use with the XNova COB
products.
Storage: XNova products are delivered in ESD shielded bags
and should be stored in these bags until used.
Assembly: Individuals handling XNova COBs during assembly
should be trained in ESD protection practices. Assemblers
should maintain constant conductive contact with a path to
ground by means of a wrist strap, ankle straps, mat or other ESD
protection system.
Transporting: When transporting the devices from one
assembly area to another, ESD shielded carts and carriers should
be used.
12
PDS-002436 Rev 03
Thermal Interface Material (TIM)
Proper thermal management is critical for successful operation
of any LED system. Excess operating temperature can reduce
the light output of the device. And excessive heating can cause
permanent damage to the device. Proper TIM material is a
crucial component for effective heat transfer away from the LED
during normal operation. Please refer to www.luminus.com for
specific recommendations for TIM solutions.
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Luminus Devices:
CLM-9-35-95-18-AC00-F2-3
