CXA2590-0000-000R0UX20E3
    WOLFSPEED
    LED COB CXA2590 COOL WHT SQUARE
CXA2590-0000-000R0UX20E3 数据手册
PRELIMINARY ® CLD-DS89 Rev 0 Product family data sheet ® Cree XLamp CXA2590 LED Table of Contents Product Description features The • Available in 4-step and 2-step Characteristics............................... 2 Cree’s family of High Density (HD) EasyWhite bins at 2700 K, Operating Limits............................. 2 LED arrays, featuring a 19‑mm 3000 K, 3500 K, 4000 K, Flux Characteristics, EasyWhite optical source and enabling lighting 5000 K, 5700 K and 6500 K Order Codes and Bins..................... 3 manufacturers to create a new CCT Flux Characteristics, ANSI White XLamp CXA2590 expands ® generation of products that delivers • Available in ANSI white bins at Order Codes and Bins..................... 5 the same intensity and light quality 4000 K, 5000 K, 5700 K and Relative Spectral Power Distribution.. 6 as up to 150‑W ceramic metal 6500 K CCT Electrical Characteristics.................. 6 halide (CMH) at up to 50 percent lower power. The new HD class • Available in 70-, 80-, 90- and 93‑minimum CRI options Typical Spatial Distribution............... 8 of CXA arrays provide unrivaled • Forward voltage: 70 V Performance Groups - Brightness...... 8 lumen density that can reduce • 85 °C binning and Performance Groups - Chromaticity... 9 system cost for the next generation characterization • Maximum drive current: of LED spotlights. 1800 mA The CXA LED Design Guide provides basic information on the • 115° viewing angle, uniform chromaticity profile Cree EasyWhite Bins Plotted on the CIE 1931 Color Space....................10 Cree ANSI White Bins Plotted on the CIE 1931 Color Space...............11 Bin and Order Code Formats...........12 Mechanical Dimensions..................12 requirements to use the CXA2590 • Top-side solder connections LED • Thermocouple attach point Thermal Design.............................13 • NEMA SSL-3 2011 standard flux Notes...........................................14 successfully in luminaire designs.1 www.cree.com/Xlamp Relative Luminous Flux.................... 7 bins 1 Packaging.....................................15 Cree XLamp CXA LED Design Guide, Design Guide DG02, www.cree.com/ xlamp_app_notes/cxa_design_guide Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 XLamp CXA2590 LED PRELIMINARY Characteristics Characteristics Unit Viewing angle (FWHM) Minimum Typical degrees ESD withstand voltage (HBM per Mil-Std-883D) Maximum 115 V 8000 DC forward current mA 1800* Reverse current mA 0.1 Forward voltage (@ 1200 mA, Tj = 85 °C) V Forward voltage (@ 1200 mA, Tj = 25 °C) V * 70 84 Refer to the Operating Limits section. Operating Limits The maximum current rating of the CXA2590 is dependent on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. Please refer to the Mechanical Drawings section on page 12 for the location of the Tc measurement point. CXA2590 2000 1800 1600 If (mA) 1400 1200 1000 800 600 400 200 0 0 25 50 75 100 125 150 Case Temperature (°C) Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 2 XLamp CXA2590 LED PRELIMINARY Flux Characteristics, EasyWhite Order Codes and Bins (If = 1200 mA, TJ = 85 °C) The following tables provide order codes for XLamp CXA2590 LEDs. For a complete description of the order code nomenclature, please reference Bin and Order Code Formats (page 12). CRI CCT Range Min Typ 70 75 80 --- 6500 K 70 75 80 --- 70 75 80 --- 90 95 5700 K 5000 K 70 4000 K 80 90 80 75 --- 95 --- 3500 K 93 95 Base Order Codes Min. Luminous Flux @ 1200 mA Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* Z4 7945 8559 AB 8500 9157 Z2 7390 7961 Z4 7945 8559 Z4 7945 8559 AB 8500 9157 Z2 7390 7961 Z4 7945 8559 Z4 7945 8559 AB 8500 9157 Z2 7390 7961 Z4 7945 8559 X2 5590 6022 X4 6010 6575 Z4 7945 8559 AB 8500 9157 Z2 7390 7961 Z4 7945 8559 AB 8500 9157 X2 5590 6022 X4 6010 6475 Y4 6910 7444 Z2 7390 7961 Z4 7945 8559 W4 5225 5629 X2 5590 6022 2-Step Order Code Chromaticity Region 4-Step Order Code Chromaticity Region 65F 65F 57F 57F 50H 50H 50H 40H CXA2590-0000-000R00Z450H CXA2590-0000-000R00AB50H CXA2590-0000-000R0HZ250H CXA2590-0000-000R0HZ450H CXA2590-0000-000R0UX250H CXA2590-0000-000R0UX450H CXA2590-0000-000R00Z440H CXA2590-0000-000R00AB40H 50F 50F 50F 40F CXA2590-0000-000R0HZ240H 40H CXA2590-0000-000R0HZ440H CXA2590-0000-000R0UX240H CXA2590-0000-000R0UX440H 40F CXA2590-0000-000R00Z235H 40F CXA2590-0000-000R0YW435H CXA2590-0000-000R0YX235H CXA2590-0000-000R0HZ465F CXA2590-0000-000R00Z457F CXA2590-0000-000R00AB57F CXA2590-0000-000R0HZ257F CXA2590-0000-000R0HZ457F CXA2590-0000-000R00Z450F CXA2590-0000-000R00AB50F CXA2590-0000-000R0HZ250F CXA2590-0000-000R0HZ450F CXA2590-0000-000R0UX250F CXA2590-0000-000R0UX450F CXA2590-0000-000R00Z440F CXA2590-0000-000R00AB40F CXA2590-0000-000R0HZ440F CXA2590-0000-000R0UX240F CXA2590-0000-000R0UX440F CXA2590-0000-000R00Y435F 35F CXA2590-0000-000R00Z435H 35H CXA2590-0000-000R0HZ265F CXA2590-0000-000R0HAB40F CXA2590-0000-000R00Y435H 35H CXA2590-0000-000R00AB65F CXA2590-0000-000R0HZ240F CXA2590-0000-000R0HAB40H 40H CXA2590-0000-000R00Z465F CXA2590-0000-000R00Z235F CXA2590-0000-000R00Z435F 35F CXA2590-0000-000R0YW435F CXA2590-0000-000R0YX235F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 3 XLamp CXA2590 LED PRELIMINARY Flux Characteristics, EasyWhite Order Codes and Bins (If = 1200 mA, TJ = 85 °C) Continued CRI CCT Range Min 80 Typ --- 3000 K 93 80 95 --- 2700 K 93 95 Base Order Codes Min. Luminous Flux @ 1200 mA Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* Y4 6910 7444 Z2 7390 7961 Z4 7945 8559 W4 5225 5629 X2 5590 6022 Y2 6430 6927 Y4 6910 7444 Z2 7390 7961 W2 4860 5236 W4 5225 5629 2-Step Order Code Chromaticity Region 4-Step Order Code Chromaticity Region CXA2590-0000-000R00Y430H 30H CXA2590-0000-000R00Z230H CXA2590-0000-000R00Y430F 30F CXA2590-0000-000R00Z430H 30H CXA2590-0000-000R0YW430H CXA2590-0000-000R0YX230H CXA2590-0000-000R00Z430F 30F CXA2590-0000-000R00Y227H 27H CXA2590-0000-000R00Y427H CXA2590-0000-000R0YW227H CXA2590-0000-000R0YW427H CXA2590-0000-000R0YW430F CXA2590-0000-000R0YX230F CXA2590-0000-000R00Y227F 27F CXA2590-0000-000R00Z227H 27H CXA2590-0000-000R00Z230F CXA2590-0000-000R00Y427F CXA2590-0000-000R00Z227F 27F CXA2590-0000-000R0YW227F CXA2590-0000-000R0YW427F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 4 XLamp CXA2590 LED PRELIMINARY Flux Characteristics, ANSI White Order Codes and Bins (If = 1200 mA, TJ = 85 °C) The following tables provide order codes for XLamp CXA2590 LEDs. For a complete description of the order code nomenclature, please reference Bin and Order Code Formats (page 12). Base Order Codes Min Luminous Flux @ 1200 mA CRI CCT Range Min Typ 70 75 80 --- 70 75 80 --- 70 75 80 --- 90 95 70 75 6500 K 5700 K 5000 K 4000 K 80 90 --- 95 Chromaticity Regions Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* Z4 7945 8559 AB 8500 9157 Z2 7390 7961 Z4 7945 8559 Z4 7945 8559 AB 8500 9157 Z2 7390 7961 Z4 7945 8559 Z4 7945 8559 AB 8500 9157 Z2 7390 7961 Z4 7945 8559 X2 5590 6022 X4 6010 6575 Z4 7945 8559 AB 8500 9157 Z2 7390 7961 Z4 7945 8559 AB 8500 9157 X2 5590 6022 X4 6010 6475 1A0, 1B0, 1C0, 1D0 1A0, 1B0, 1C0, 1D0 2A0, 2B0, 2C0, 2D0 2A0, 2B0, 2C0, 2D0 3A0, 3B0, 3C0, 3D0 3A0, 3B0, 3C0, 3D0 3A0, 3B0, 3C0, 3D0 5A0, 5B0, 5C0, 5D0 Order Code CXA2590-0000-000R00Z40E1 CXA2590-0000-000R00AB0E1 CXA2590-0000-000R00Z20E1 CXA2590-0000-000R00Z40E1 CXA2590-0000-000R00Z40E2 CXA2590-0000-000R00AB0E2 CXA2590-0000-000R00Z20E2 CXA2590-0000-000R00Z40E2 CXA2590-0000-000R00Z40E3 CXA2590-0000-000R00AB0E3 CXA2590-0000-000R0HZ20E3 CXA2590-0000-000R0HZ40E3 CXA2590-0000-000R0UX20E3 CXA2590-0000-000R0UX40E3 CXA2590-0000-000R00Z40E5 CXA2590-0000-000R00AB0E5 CXA2590-0000-000R0HZ20E5 5A0, 5B0, 5C0, 5D0 CXA2590-0000-000R0HZ40E5 CXA2590-0000-000R0HAB0E5 5A0, 5B0, 5C0, 5D0 CXA2590-0000-000R0UX20E5 CXA2590-0000-000R0UX40E5 Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 5 XLamp CXA2590 LED Relative Spectral Power Distribution PRELIMINARY Relative Spectral Power Distribution (If = 1200 ma, Tj = 85 °C) The following graph is the result of a series of pulsed measurements at 1200 mA and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 60% 5000K, 70 CRI 50% 4000K, 70 CRI 40% 3000K, 80 CRI 30% 3000K, 93 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Electrical Characteristics The following graph is the result of a series of steady-state measurements. 75 Voltage (V) 73 71 Tc = 25 °C Tc = 55 °C 69 Tc = 85 °C Tc = 105 °C 67 65 63 200 400 600 800 1000 1200 1400 1600 1800 Current (mA) Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 6 XLamp CXA2590 LED PRELIMINARY Relative Luminous Flux The relative luminous flux values provided below are the ratio of: • Measurements of CXA2590 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 1200 mA at TJ = 85 °C. For example, at steady-state operation of Tc = 105 °C, IF = 1200 mA, the relative luminous flux ratio is 90% in the chart below. A CXA2590 LED that measures 11,000 lm during binning will deliver 9,900 lm (11,000 * 0.9) at steady-state operation of Tc = 105 °C, IF = 1200 mA. Relative Luminous Flux 150% 120% Tc = 25 °C Tc = 55 °C 90% Tc = 85 °C Tc = 105 °C 60% 30% 0% 200 400 600 800 1000 1200 1400 1600 1800 Current (mA) Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 7 XLamp CXA2590 LED Far Field PRELIMINARY Typical Spatial Distribution Relative Luminous Intensity 100% 80% 60% 40% 20% -90 -70 -50 -30 0% -10 10 30 50 70 90 Angle (º) Performance Groups - Brightness (If = 1200 mA, Tj = 85 °C) XLamp CXA2590 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Min. Luminous Flux @ 1200 mA Max. Luminous Flux @ 1200 mA W2 4,860 5,225 W4 5,225 5,590 X2 5,590 6,010 X4 6,010 6,430 Y2 6,430 6,910 Y4 6,910 7,390 Z2 7,390 7,945 Z4 7,945 8,500 AB 8,500 9,000 AD 9,000 9,500 BB 9,500 10,000 BD 10,000 11,000 CB 11,000 12,000 Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 8 XLamp CXA2590 LED PRELIMINARY Performance Groups - Chromaticity (Tj = 85 °C) XLamp CXA2590 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 4-Step EasyWhite Color Temperatures – 2-Step Code Code 50F 40F 35F 30F 27F CCT 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3407 0.3415 0.3499 0.3654 x y 0.3459 0.3429 0.3507 0.3586 0.3434 0.3571 0.3475 0.3604 0.3484 0.3744 0.3521 0.3469 0.3539 0.3685 0.3784 0.3741 0.3782 0.3837 0.3804 0.3818 0.3912 0.3917 0.3867 0.3857 0.3863 0.3758 0.3844 0.3778 0.3981 0.3800 0.4030 0.3857 0.4040 0.3966 0.4061 0.3941 0.4186 0.4037 0.4132 0.3976 0.4116 0.3865 0.4099 0.3890 0.4242 0.3919 0.4291 0.3973 0.4322 0.4096 0.4333 0.4062 0.4449 0.4141 0.4395 0.4084 0.4359 0.3960 0.4351 0.3994 0.4475 0.3994 0.4528 0.4046 0.4573 0.4178 0.4578 0.4138 0.4695 0.4207 0.4638 0.4152 0.4589 0.4021 0.4586 0.4060 50H 40H 35H 30H 27H ANSI White Bins Code CCT Bin Code 3A0 3B0 0E3 5000 K 3C0 3D0 CCT 5000 K 4000 K 3500 K 3000 K 2700 K ANSI White Bins x y .3371 .3490 .3451 .3554 .3440 .3427 .3366 Code CCT Bin Code x y .3670 .3578 .3702 .3722 .3825 .3798 .3369 .3783 .3646 .3376 .3616 .3702 .3722 .3463 .3687 .3736 .3874 .3451 .3554 .3869 .3958 .3371 .3490 .3825 .3798 .3463 .3687 .3825 .3798 .3551 .3760 .3869 .3958 .3533 .3620 .4006 .4044 .3451 .3554 .3950 .3875 .3451 .3554 .3783 .3646 .3533 .3620 .3825 .3798 .3515 .3487 .3950 .3875 .3440 .3427 .3898 .3716 5A0 5B0 0E5 4000 K 5C0 5D0 Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 9 XLamp CXA2590 LED PRELIMINARY Cree EasyWhite Bins Plotted on the CIE 1931 Color Space (Tj = 85 °C) 0.45 ANSI C78.377 Quadrangle EasyWhite 4-step EasyWhite 2-step 0.44 2700K 3000K 0.43 3500K 0.42 4000K 0.41 4500K 0.40 5000K CCy 0.39 5700K 0.38 0.37 0.36 0.35 0.34 0.33 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.32 CCx Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 10 XLamp CXA2590 LED PRELIMINARY Cree ANSI White Bins Plotted on the CIE 1931 Color Space (Tj = 85 °C) 0.42 3500K 0.41 4000K 0.40 4500K 5C 0.39 5B 5000K CCy 0.38 5D 0.37 5A 5700K 0.36 3C 3B 3D 0.35 3A 0.34 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.33 CCx Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 11 XLamp CXA2590 LED PRELIMINARY Bin and Order Code Formats Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA25 Series = CXA25 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 min CRI U = 90 min CRI Y = 93 min CRI Vf class: R0 = 70-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA Vf class: R0 = 70-V class CRI Specification B = 70 min CRI H = 80 min CRI U = 90 min CRI Y = 93 min CRI Performance class Flux bin SSSSSCC-HHHH-HHHGGRNNNNN Kit code Performance class Mechanical Dimensions Dimensions are in mm. 23.85 ±0.2 Tolerances unless otherwise 1.2 specified: 3.4 .x + .10 1.00±.15 7.3 Tc 1.2 .xx + .03 3.4 .xxx + .010 x° + 1° 9.5 23.85 ±0.2 19.000 ±0.2 21.00 ±0.2 3.4 1.2 1.2 3.4 0.55 ± 0.1 Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 12 XLamp CXA2590 LED PRELIMINARY Thermal Design The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure the CXA LED is being operated within its designed limits. Please refer to page 2 for the Operating Limit specification. Cree has measured the temperature at the bottom of the package, commonly referred to as the solder point (TSP), and found this value to be equivalent to the temperature at the Tc location at the top of the package once the LED has reached thermal equilibrium. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient (Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please refer to the XLamp Thermal Management application note at www.cree.com/xlamp_app_notes/thermal_management. For CXA soldering recommendations and more information on thermal interface materials (TIM) and connection methods, please refer to the Cree XLamp CXA Family LEDs soldering and handling document at www.cree.com/xlamp_app_notes/CXA_SH. To keep the CXA2590 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a R_j-c R_j-c Tc Tc value shown on the following graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic scale. As the figure at right shows, the R_c-a value is the sum of the thermal resistance of R_tim R_c-a the TIM (R_tim) plus the thermal resistance of the heat sink (R_hs). R_hs CXA2590 Ta Ta 100.00 Maximum R_c-a 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 200 400 600 800 1000 1200 1400 1600 1800 Current (mA) Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 13 XLamp CXA2590 LED PRELIMINARY Notes Lumen Maintenance Projections Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document at www.cree.com/xlamp_app_notes/LM80_results. Please read the XLamp Long-Term Lumen Maintenance application note at www.cree.com/xlamp_app_notes/lumen_ maintenance for more details on Cree’s lumen maintenance testing and forecasting. Please read the XLamp Thermal Management application note at www.cree.com/xlamp_app_notes/thermal_management for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Vision Advisory Claim Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye. Copyright © 2014 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. 14 XLamp CXA2590 LED PRELIMINARY Packaging Cree CXA2590 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100 LEDs per carton. Each carton contains 100 LEDs from the same performance bin. 6 5 5 NOTICE IAL. AND THE INFORMATION LOTTHIS AND PLOT THE INFORMATION ARE THE PROPRIETARY AND ENPROPRIETARY AND FORMATION OF INC. THIS PLOT N OF CREE, INC. THIS PLOT 6 CREE, ED, REPRODUCED OR DISCLOSED TO ANY ODUCED OR DISCLOSED TO ANY NOTICE ERSONTHE WITHOUT THECONSENT WRITTEN CONSENT ITHOUT WRITTEN 5 NFIDENTIAL. THIS PLOT AND THE INFORMATION ED WITHIN ARE THE PROPRIETARY AND NTIAL INFORMATION OF CREE, INC. THIS PLOT NFORMATION BE COPIED, REPRODUCED OR DISCLOSED TO ANY 7.125 AND PERSON WITHOUTTHE WRITTEN CONSENT .RIZED THIS PLOT INC. CLOSED TO ANY 4 4 2 2 Dimensions are in inches. 3 3 REVISONS REVISONS REV 5 4 3 4 3 2 REV 7.125 R.375 TTEN CONSENT Tolerances: REV DESCRIPTION DESCRIPTION .x + .1 REVISONS 1 REV .xx + .05 REVISONS DESCRIPTION BY DESCRIPTION .xxx + .005 R.375 BY 2 DATE APP'D x° + 1° 7.125 R.375 7.125 R.375 1.188 1.188 1.188 7.625 1.188 7.625 7.625 .38 .38 1.188 1.188 LABEL WITH CREE LABEL WITH CREE BINQTY, CODE, QTY, LOT# BIN CODE, LOT# .38 1.188 LABEL WITH CREE PATENT PATENT LABEL LABEL BIN CODE, QTY,1.188 LOT# ABEL WITH CREE ATED ON UNDERSIDE OF UNDERSIDE OF ODE, QTY,CARTON LOT# CARTON PATENT LABEL S LOCATED ON UNDERSIDE OF ABEL CARTON E OF RTON .38 BAG BAG BAG BAG LABEL WITH CREE LABEL WITH CREE BINQTY, CODE, QTY, LOT# BIN CODE, LOT# LABEL WITH CREE ABEL WITH CREE BINQTY, CODE, QTY, LOT# ODE, LOT# LABEL WITH CREE BIN CODE, QTY, LOT# LABEL WITH CREE BIN CODE, QTY, LOT# REE OT# LABEL WITH CREE BIN CODE, QTY, LOT# DRAWN BY DATE DRAWN BY DATE UNLESSSPECIFIED OTHERWISE SPECIFIED UNLESS OTHERWISE 46 DIMENSIONS ARE IN INCHES DIMENSIONS ARE IN INCHES Du CHECK DATE CHECK DATE AND AFTER FINISH. AND AFTER FINISH. Ph TOLERANCE UNLESS SPECIFIED: TOLERANCE UNLESS SPECIFIED: Fa .01 .XX ± .01.XX ± APPROVED DATE APPROVED DATE DRAWN DATE BY UNLESS SPECIFIED TITLE .XXX ± OTHERWISE .005 TITLE .XXX ± .005 ± .5 °ARE IN INCHES X° ± .5 X° ° DIMENSIONS DATE DRAWN BY THIRD ANGLE PROJECTION THIRD ANGLE PROJECTION DATE MATERIAL ANDPARTS AFTER FINISH.MATERIAL CHECK UNLESS OTHERWISEFOR SPECIFIED FOR SHEET ONLY SHEET METAL PARTSMETAL ONLY 4600 Silicon Drive TOLERANCE UNLESS SPECIFIED: DIMENSIONS ARE IN INCHES .X ± .06 Durham, N.C 27703 ± .06.X CHECK DATE .XX ± .01 DRAWING NO. SIZE DRAWING NO. DATE APPROVED SIZE AND AFTER FINISH. .03 .XX ± .03.XX ± Phone (919) 313-5300 TITLE .XXX ± .005 TOLERANCE UNLESS SPECIFIED: .XXX ± FINAL .010PROTECTIVE FINISH FINAL PROTECTIVE FINISH .XXX ± .010 Fax (919) 313-5558 X° ± .5 ° .XX ± .01 X° ± .5 ° X° ± .5 ° DATE APPROVED THIRD ANGLE PROJECTION TITLE SCALE .XXX ± .005 FOR SHEET METAL PARTS ONLY MATERIAL SCALE SH 63 FINISH: 63 SURFACE 6.000 SURFACE FINISH: 6.000 X° ± .5 ° .X ± .06 THIRD ANGLE PROJECTION D SIZE 4 3 2 .XX ± .03 3 METAL PARTS 2 FOR SHEET ONLY MATERIAL ® ® ® .XXX ± and .010 EasyWhite FINAL PROTECTIVE FINISH document is subject to change without .Xnotice. Cree , the Cree logo, XLamp are registered ± .06 REV. X° ± SIZE .5 ° DRAWING NO. .XX ± .03 LE2401 MAR LE2401 MARKETING C 6 5 5 4 Copyright © 2014 Cree, Inc. All rights reserved. The information in this trademarks of Cree, Inc. 6 5 5 C CXA2590 LE2401 LE2401 MARKETING SPEC .XXX ± X° ± 4 4 C SURFACE FINISH: 3 .010 .5 ° 63 SURFACE FINISH: FINAL PROTECTIVE FINISH 3 63 SCALE 2 C 6.000 CXA2590 2 C SCALE 15 SHEET 1 6.000 OF A 2 /4
CXA2590-0000-000R0UX20E3 价格&库存
很抱歉,暂时无法提供与“CXA2590-0000-000R0UX20E3”相匹配的价格&库存,您可以联系我们找货
