SSR-80-W35M-R91-LA600 数据手册
SSM-80 Product Datasheet
SSM-80 LEDs
Features:
• 3000K Efficacy over 100 lm/W, Flux over 1,600 lumens
Table of Contents
Technology Overview. . . . . . 2
• High density small form-factor light source ideal for spot and directional applications
• ANSI compatible flux binning
• Low thermal resistance: 1.0 °C/W
Test Specifications . . . . . . . . . 2
• Lumen maintenance of greater than 70% after 60,000 hours
White Binning Structure. . . . 3
• RoHS compliant
Chromaticity Bins. . . . . . . . . . 4
Product Shipping &
Labeling Information. . . . . . . 6
• High reliability
• Electrically isolated thermal path
• 13V typical input voltage
• Narrow beam focus, MR-16 form factor
Electrical Characteristics. . . 7
Spectral Characteristics. . . . .8
Radiation Patterns . . . . . . . . . 8
Thermal Resistance . . . . . . . . 9
Mechanical Dimensions . . . 10
Solder Profile . . . . . . . . . . . . . 12
Applications
• Indoor Lighting
• Track Lighting
• Directional spot
• High-Output Area Lighting
• MR-16 light engine
Tape & Reel Drawing . . . . . . 13
Ordering Information . . . . . 14
1
PDS-001674 Rev 08
© 2011 Luminus Devices, Inc. - All Rights Reserved
Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com
1100 Technology Park Drive • Billerica, MA 01821
Technology Overview
Luminus Big Chip LEDs™ benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These
breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency.
Photonic Lattice Technology
Luminus’ photonic lattice technology enables large area LED
chips with uniform brightness over the entire LED chip surface.
The optical power and brightness produced by these large
monolithic chips enable solutions which replace arc and
halogen lamps where arrays of traditional high power LEDs
cannot.
For red, green and blue LEDs, the photonic lattice structures
extract more light and create radiation patterns that are more
collimated than traditional LEDs. Having higher collimation
from the source increases optical collection efficiencies and
simplifies optical designs.
Packaging Technology
Thermal management is critical in high power LED applications.
With a thermal resistance from junction to case of
1.0º C/W. Luminus SSM-80 package is designed with high
quality materials to provide customers with industry leading
package thermal conductivity. This allows the LED to be driven
at higher current densities while maintaining a low junction
temperature, thereby resulting in brighter solutions and longer
lifetimes. The package is easy to use, and ready to be mounted
in the lighting system.
Reliability
Designed from the ground up, Luminus Big Chip LEDs are one of
the most reliable light sources in the world today. Big Chip LEDs
have passed a rigorous suite of environmental and mechanical
stress tests, including mechanical shock, vibration, temperature
cycling and humidity, and have been fully qualified for use in
extreme high power and high current applications. With very
low failure rates and median lifetimes that typically exceed
60,000 hours, Luminus Big Chip LEDs are ready for even the
most demanding applications.
Environmental Benefits
Luminus LEDs help reduce power consumption and the amount
of hazardous waste entering the environment. All Big Chip LED
products manufactured by Luminus are RoHS compliant and
free of hazardous materials, including lead and mercury.
Understanding Big Chip LED Test Specifications
Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products.
Testing Temperature
Multiple Operating Points (0.7A, 1.4A, 2.0 A)
Luminus core board products are typically measured in such a
way that the characteristics reported agree with how the
devices will actually perform when incorporated into a system.
This measurement is accomplished by mounting the devices on
a 40ºC heat sink and allowing the device to reach thermal
equilibrium while fully powered. Only after the device reaches
equilibrium are the measurements taken. This method of
measurement ensures that Luminus Big Chip LEDs perform in
the field just as they are specified.
The tables on the following pages provide typical optical and
electrical characteristics. Since the LEDs can be operated over a
wide range of drive conditions (currents from less than 350mA
to 2.0 A, and duty cycle from
SSR-80-W35M-R91-LA600 价格&库存
很抱歉,暂时无法提供与“SSR-80-W35M-R91-LA600”相匹配的价格&库存,您可以联系我们找货
