CBT-140-WDH-C15-RA220 数据手册
CBT-140 Product Datasheet
Preliminary
CBT-140 WhiteLEDs
Features:
• Extremely high optical output from a14 mm2 circular source: Up to 3,700 white
lumens
Table of Contents
Technology Overview. . . . . . 2
Test Specifications . . . . . . . . . 2
Binning Structure. . . . . . . . . . 3
Chromaticity Bins. . . . . . . . . . 4
Product Shipping &
Labeling Information. . . . . . . 6
• Round emitting aperture provides most efficient match to circular optical systems and
narrow beam projectors
• Unencapsulated package preserves small etendue facilitating narrow beam optical
system design
• Chip on board package assures straightforward system assembly with the best
possible thermal performance for high power devices.
• Integrated thermistor enables consistent temperature monitoring during operation
for high system reliability
• High thermal conductivity package - junction to heat sink thermal resistance less than
0.6°C/W
Electrical
Characteristics. . . . . . . . . . . . . 7
• Variable drive current: 1 A to 28A for white
Lifetime & Lumen
Maintenance. . . . . . . . . . . . . . . 9
• Environmentally friendly: RoHS compliant
Radiation Patterns . . . . . . . . . 9
Thermal Resistance . . . . . . . 10
Mechanical Dimensions . . . 11
Ordering Information . . . . . 12
• High CRI in Tungsten and Daylight color temperatures for natural lighting
Applications
• Architectural and Entertainment
Lighting
• Microscopy
• Spot Lighting
• Fiber-coupled Illumination
• Medical Lighting
• Machine Vision
1
PDS-002013 Rev 0X
© 2012Luminus Devices, Inc. - All Rights Reserved
Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com
1100 Technology Park Drive • Billerica, MA 01821
Preliminary
Technology Overview
Luminus Big Chip LEDs™ benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These
breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency.
Photonic Lattice Technology
Luminus’ photonic lattice technology enables large area LED
chips with uniform brightness over the entire LED chip
surface. The optical power and brightness produced by these
large monolithic chips enable solutions which replace arc
and halogen lamps where arrays of traditional high power
LEDs cannot.
have passed a rigorous suite of environmental and mechanical
stress tests, including mechanical shock, vibration, temperature
cycling and humidity, and have been fully qualified for use in
extreme high power and high current applications. With very
low failure rates and median lifetimes that typically exceed
60,000 hours, Luminus Big Chip LEDs are ready for even the
most demanding applications.
Packaging Technology
Environmental Benefits
Thermal management is critical in high power LED applications.
With a thermal resistance from junction to heat sink of 0.59º
C/W, Luminus CBT-140 LEDs have the lowest thermal resistance
of any LED on the market. This allows the LED to be driven at
higher current densities while maintaining a low junction
temperature, thereby resulting in brighter solutions and longer
lifetimes.
Luminus LEDs help reduce power consumption and the amount
of hazardous waste entering the environment. All Big Chip LED
products manufactured by Luminus are RoHS compliant and
free of hazardous materials, including lead and mercury.
Reliability
Designed from the ground up, Luminus Big Chip LEDs are one of
the most reliable light sources in the world today. Big Chip LEDs
Understanding Big Chip LED Test Specifications
Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products.
Testing Temperature
Multiple Operating Points (14.0 A, 21.0 A, 28.0 A)
Luminus core board products are typically measured in such a
way that the characteristics reported agree with how the
devices will actually perform when incorporated into a system.
This measurement is accomplished by mounting the devices on
a 40ºC heat sink and allowing the device to reach thermal
equilibrium while fully powered. Only after the device reaches
equilibrium are the measurements taken. This method of
measurement ensures that Luminus Big Chip LEDs perform in
the field just as they are specified.
The tables on the following pages provide typical optical and
electrical characteristics. Since the LEDs can be operated over a
wide range of drive conditions (currents from 1A to 28.0A, and
duty cycles from
CBT-140-WDH-C15-RA220 价格&库存
很抱歉,暂时无法提供与“CBT-140-WDH-C15-RA220”相匹配的价格&库存,您可以联系我们找货
