REV.
DESCRIPTION
A Engineering Release
B Added R/Y & A/G LED Specs
C Added LED Specs
D Updated per EOL
DATE
APPROVED
01/15/09
05/06/10
02/10/15
T. Y.
T. Y.
J. C.
A.V.
09/04/19
0.209 [5.3mm]
Flat Edge ID
1.00 [25.4mm]
MIN.
Ø.150 [Ø3.8mm]
Flange Dia.
0.04 [1.0mm]
MIN.
0.100 [2.5mm]
0.020 [0.5mm] SQ.
Ø.118 [Ø3.0mm]
MIN.
Flanged "3BCC-XX-F"LED
0.032 [0.8mm]
Recommended Mounting
Hole Size = Ø.032+.003
-.002
ABSOLUTE MAXIMUM RATINGS (Ta=25°C)
REVERSE VOLTAGE
5V
REVERSE CURRENT
100uA
OPERATING TEMPERATURE RANGE
-25°C - 85°C
STORAGE TEMPERATURE
-30°C - 100°C
SHORT
LEAD
CATHODE
PART NO.
LONG
LEAD
CATHODE
RED
3BCC-X
GREEN
STANDARD TOLERANCE
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
Raffy Paje
CHECKED:
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
260°C FOR 5 SECONDS
â
( UNLESS OTHERWISE SPECIFIED )
F. Jensen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
T1 (3mm) BI-COLOR LED
DATE:
01/15/09
DATE:
01/15/09
PART NO:
REVISION:
3BCC-XX-X
CAGE CODE : 32559
D
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
SEE SHEET #1
STANDARD TOLERANCE
â
DECIMALS
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
Raffy Paje
CHECKED:
F. Jensen
DATE:
01/15/09
DATE:
01/15/09
PART NO:
3BCC-XX-X
REVISION:
D
CAGE CODE : 32559 SHEET # 2 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAW ING.
很抱歉,暂时无法提供与“3BCC-F”相匹配的价格&库存,您可以联系我们找货
