BXRC-40A2001-C-03
BXRC-40A2001-C-03
    BRIDGELUX
    MOD LED ARRAY NEU WHITE 4000K
BXRC-40A2001-C-03 数据手册
Bridgelux Décor Series™ Class A LED Array ® Preliminary Product Data Sheet BXRC-30A2001 | 30A4001 | 40A2001 | 40A4001 Vero Introduction Bridgelux Décor Series™ Class A products are a revolutionary advancement in lighting designed to match how humans ® perceive and prefer light. The Class A specification was created by the Lighting Research Center (LRC) behavior studies in conjunction with Bridgelux and other ASSIST members. Based on human factor response testing, the Décor Series Class A products provide vibrant, natural and brilliant looking light, evoking an emotional attraction and response. The Décor Series Class A products were developed for high-end retail, museum, architectural, premium building and hospitality applications. Bridgelux Décor Series Class A products are available on the Vero 13 and 18 platforms. The Vero platform has been engineered with advanced connectivity options and can operate over a broad current range, enabling multiple degrees of flexibility in luminaire design optimization. Features • Light quality based on how humans perceive light and most preferred characteristics • White point targeted below Black Body Curve to match preferred light quality defined in studies of human perception of light Benefits • Evokes a positive emotional response • Intuitively ‘feels right’ for users of the space • Bright white light • Creates comfortable ambience • High Gamut Area Index and full spectrum color rendering • Vibrant and vivid colors • Excellent light quality, matched to human preference encourages use of space • Creates stunning visual experience • No IR, UV or blue light peaks in spectrum • Class A – has substantially better (broader) GAI color spectrum than Halogen • Bright, clean and natural looking light • Increases visits, use of services, customer purchases and revenue generated in lighted space • Enhances prestige of premium locations • 3000K and 4000K white color points • Does not damage artwork and fixture interiors • Based on Bridgelux Vero CoB LED array platform • Light does not discolor or age products • Energy efficient lighting with long lifetime • Minimizes loss and wastage • Better light quality matched to human preference • Ideal for CDM and CMH replacement • Industry leading light source design • Reduces electricity, AC cooling and operating costs Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Flux & Electrical Characteristics 4 Absolute Maximum Ratings 5 Performance Curves 6 Mechanical Dimensions 8 Design Resources 10 Precautions 10 Disclaimers 10 About Bridgelux 11 1 Product Feature Map In addition to delivering the performance and light quality required for many lighting applications, Décor Series Class A LED arrays incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. 2D Bar code provides full manufacturing traceability Thermally isolated solder pads reduce manufacturing cycle time and complexity Polarity indication marks simplify manufacturing operator instructions Tc Measurement point Optics location/mounting features Correlates to the true case temperature on the back surface of the LED array Mounting holes Radial die configuration improves lumen density and beam control Zhaga Book 3 compatible mounting locations Soderless connector port enables simplified manufacturing processes, reduced inventory carrying costs and can enable field upgradability Top side part number marking improves inventory management and outgoing quality control Optional Molex Pico-EZmate™ connector harness (sold separately) Simplifies manufacturing processes, reduces inventory costs, and allows for field upgradability Product Nomenclature The part number designation for Bridgelux Vero LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRC – 30 E 2001 – X – 03 Product Family CCT Bin Options 03 = 3 SDCM Nominal CCT 30 = 3,000K 40 = 4,000K Array Configuration A = Class A Nominal Flux 2001 = 2,000lm 4001 = 4,000lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Nominal CCT (K) CRI GAI Nominal Drive Current1 (mA) Typical Pulsed Flux2 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30A2001-C-03 3000 80 >80 500 1360 32.3 16.2 81 BXRC-30A4001-F-03 3000 80 >80 1050 2527 29.5 31.3 82 BXRC-40A2001-C-03 4000 80 >80 500 1747 32.3 16.2 108 BXRC-40A4001-F-03 4000 80 >80 1050 3354 29.5 31.0 108 Part Number Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 3,4 Nominal CCT (K) CRI GAI Nominal Drive Current1 (mA) Typical Pulsed Flux2 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30A2001-C-03 3000 80 >80 500 1171 31.5 15.7 74 BXRC-30A4001-F-03 3000 80 >80 1050 2249 28.8 30.2 74 BXRC-40A2001-C-03 4000 80 >80 500 1537 31.5 15.7 98 BXRC-40A4001-F-03 4000 80 >80 1050 2952 28.8 30.2 98 Part Number Notes for Tables 1 & 2: 1. Drive current is referred to as nominal drive current. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 4. Typical performance is estimated based on operation under DC (direct current) with the LED array mounted to a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 Flux & Electrical Characteristics Table 3: Electrical Characteristics and Driver Selection Voltages Forward Voltage Pulsed, Tc = 25°C (V) 1, 2, 3 Form Factor Nominal Drive Current (mA)1 Minimum Typical Maximum Typical Coefficient of Forward Voltage ∆Vf/∆T (mV/ºC) Typical Thermal Resistance Junction to Case Rj-c (ºC/W) Driver Selection Voltages (V) Vf Min. Hot4 Tc = 105ºC (V) Vf Max. Cold4 Tc = 40ºC (V) BXRC-xxA2001-C-03 500 29.9 32.3 34.7 -14 0.78 28.8 35.6 BXRC-xxA2001-C-03 1050 32.0 35.1 37.9 -14 0.93 30.9 38.8 BXRC-xxA4001-F-03 1050 27.3 29.5 31.7 -12 0.29 26.3 32.5 BXRC-xxA4001-F-03 2100 29.2 31.6 34.2 -12 0.38 28.2 35.0 Notes for Table 3: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10 ms. 2. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. 3. Forward voltage minimum and maximum values at the nominal drive current (indicated in bold font) are guaranteed by 100% test. Values provided at other drive currents are provided for reference only and are not guaranteed by test. 4. Vf min hot and Vf max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 5. Thermal resistance values are based on testing data from a 3000K 80 CRI product. 4 Absolute Maximum Ratings Table 4: Maximum Drive Current and Reverse Voltage Ratings Part Number Drive Current for LM-80 (mA)1 Maximum Peak Pulsed Drive Current (mA)2 Maximum Reverse Voltage (Vr)3 BXRC-xxA2001-C-03 1050 1500 -55 BXRC-xxA4001-F-03 2100 3000 -50 Notes for Table 4: 1. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for these products. 2. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where the LED array can be driven without catastrophic failures. 3. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 5 Performance Curves Figure 1: Figure 2: Drive Current vs. Forward Voltage (Tj = Tc = 25°C) – BXRC-xxA2001-C-03 Drive Current vs. Forward Voltage (Tj = Tc = 25°C) – BXRC-xxA4001-F-03 Figure 3: Figure 4: Typical Relative Intensity vs. Drive Current BXRC-xxA2001-C-03 Typical Relative Intensity vs. Drive Current BXRC-xxA4001-F-03 6 Performance Curves Figure 5: Figure 6: Typical Flux vs. Case Temperature Typical ccx Shift vs. Case Temperature Figure 7: Typical ccy Shift vs. Case Temperature 7 Mechanical Dimensions Figure 8: Drawing for Vero 13 LED Array 8 Mechanical Dimensions Figure 9: Drawing for Vero 18 LED Array Notes for Figure 8-9: 1. Mounting holes (2X) are for M2.5 screws. 2. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 3. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 4. Solder pads and connector port are labeled “+” and “-“ to denote positive and negative, respectively. 5. It is not necessary to provide electrical connections to both the solder pads and the connector port. Either set may be used depending on application specific design requirements. 6. Drawings are not to scale. 7. Drawing dimensions are in millimeters. 8. Unless otherwise specified, tolerances are ± 0.10mm. 9. Refer to Application Notes AN30 and AN31 for product handling, mounting and heat sink recommendations. 10. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 11. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 9 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For a list of of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both SAT and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www. bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux Vero LED arrays is in accordance with IEC specification EN62471: Photobiological Safety of Lamps and Lamp Systems. Vero LED arrays are classified as Risk Group 1 (Low Risk) when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the Vero LED array or yellow resin area during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers MINOR PRODUCT CHANGE POLICY The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. 10 About Bridgelux Bridgelux is a leading developer and manufacturer of technologies and solutions transforming the $40 billion global lighting industry into a $100 billion market opportunity. Based in Livermore, California, Bridgelux is a pioneer in solid state lighting (SSL), expanding the market for light emitting diode (LED) technologies by driving down the cost of LED lighting systems. Bridgelux’s patented light source technology replaces traditional technologies (such as incandescent, halogen, fluorescent and high intensity discharge lighting) with integrated, solid state lighting solutions that enable lamp and luminaire manufacturers to provide high performance and energy efficient white light for the rapidly growing interior and exterior lighting markets, including street lights, commercial lighting and consumer applications. For more information about the company, please visit www.bridgelux.com. 101 Portola Avenue Livermore, CA 94551 Tel (925) 583-8400 Fax (925) 583-8410 www.bridgelux.com © 2014 Bridgelux, Inc. All rights reserved 2014. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vero are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Decor Series Class A Product Data Sheet (10/2014 r1) 11
BXRC-40A2001-C-03 价格&库存
很抱歉,暂时无法提供与“BXRC-40A2001-C-03”相匹配的价格&库存,您可以联系我们找货
