BXRC-40G2000-C-02
BXRC-40G2000-C-02
    BRIDGELUX
    LEDARRAY2000LMNEUTRALWHITE
BXRC-40G2000-C-02 数据手册
Bridgelux Vero 13 Array Series Product Data Sheet DS31 BXRC-27x2000, 30x2000, 35E2000, 40x2000, 50x2000 Introduction TM Vero represents a revolutionary advancement in chip on board (COB) light source technology and innovation. These new LED light sources simplify luminaire design and manufacturing processes, improve light quality, and define a platform for future functionality integration. Vero is available in four different LES (light emitting surface) configurations and has been engineered to reliably operate over a broad current range, enabling new degrees of flexibility in luminaire design optimization. These new arrays deliver increased lumen density to enable improved beam control and precision lighting with 2 and 3 SDCM color control standard for clean and consistent uniform lighting. Vero includes an on board connector port to enable solder free electrical interconnect and simple easy to use mounting features to enable plug-and-play installation. Features Benefits • Market leading efficacy of 120 lm/W typical and 110 lm/W minimum • Broad application coverage for interior and exterior lighting • Vero 13 lumen output performance ranges from 500 to as much as 4,400 lumens • Flexibility for application driven lighting design requirements • High quality true color reproduction • Broad range of CCT options from 2700K to 5000K • Uniform consistent white light • CRI options include; minimum 70, 80, and 90 • Flexibility in design optimization • 2 and 3 SDCM color control for 2700K-4000K CCT • Improved optical control • Reliable operation at up to 2X nominal drive current • Enhanced ease of use and manufacturability • Radial die pattern and improved lumen density • • Thermally isolated solder pads Solder-less connectivity enables plug & play installation and field upgradability • Onboard connector port • Improved inventory management and quality control • Top side part number markings 101 P ort ol a A v enue, Li v erm ore, C A 94551 • T el : (925 ) 583 -84 0 0 • Fa x: (92 5) 58 3- 8 4 01 • ww w. b ri dgel u x. c om Table of Contents Product Feature Map Product Nomenclature Top Side Part Number Markings Enhanced Connectivity Options Lumen Maintenance Characteristics Environmental Compliance UL Recognition CE Recognition Minor Product Change Policy Case Temperature Measurement Point CAUTION: CONTACT WITH LIGHT EMITTING SURFACE (LES) CAUTION: CHEMICAL EXPOSURE HAZARD CAUTION: EYE SAFETY CAUTION: RISK OF BURN Production Selection Guide Performance at Commonly Used Drive Currents Flux & Electrical Characteristics Absolute Maximum Ratings Drive Current vs. Forward Voltage Characteristics Typical Relative Luminous Flux vs. Drive Current, Tj = 25°C Typical Light Output Characteristics vs. Temperature Typical Chromaticity Characteristics vs. Temperature Typical Radiation Pattern Wavelength Characteristics at Drive Current, Tj = 25°C Mechanical Dimensions Color Binning Information Design Resources About Bridgelux Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 3 3 4 4 4 4 4 5 5 5 5 5 5 5 6 7 8 9 10 10 11 12 13 14 14 15 – 16 17 17 Page 2 of 17 Product Feature Map Vero 13 is the second smallest form factor in the exciting new Vero family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please consult the Bridgelux Vero Array Series Product Brief for more information on the Vero family of products. Thermally isolated solder pads reduce manufacturing cycle time and complexity 2D Bar code provides full manufacturing traceability Polarity indication marks simplify manufacturing operator instructions Tc Measurement point Optics location/mounting features Radial die configuration improves lumen density and beam control Mounting holes Zhaga Book 3 compatible mounting locations Solderless connector port enables simplified manufacturing processes, reduced inventory carrying costs and can enable field upgradability Top side part number marking improves inventory management and outgoing quality control TM Optional Molex Pico-EZmate connector harness (sold separately) Product Nomenclature The part number designation for Bridgelux Vero LED arrays is explained as follows: BXRC – AB C DEFG – H – IJ Where: BXRC – Designates product family AB – Designates the nominal color temperature; 27 = 2700K; 30 = 3000K, etc. C – Designates minimum CRI; C = 70, E = 80, G = 90 DEFG – Designates nominal flux; 1000 = 1,000 lm, 2000 = 2,000 lm, 4000 = 4,000 lm, 10K0 = 10,000 lm, etc. H – Designates array configuration IJ – Designates CCT Bin options 02 = 2 SDCM 03 = 3 SDCM 04 = 4 SDCM Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 3 of 17 Top Side Part Number Markings Vero includes a top side part number marking to help simplify inventory management and increase opportunities for production quality control. Any Vero product can be quickly identified to determine the product configuration, color or CRI by simply looking at its top side markings. Unlike previous product generations where markings were included only on the back side of the array, no longer is it necessary to handle (turnover), uninstall the array in an infield application or guess which product it is by the color of the phosphor area. The Vero line of LED array products also has a 2D bar code which provides additional information and full product traceability for quality control purposes. Enhanced Connectivity Options Vero’s thermally isolated solder pads have been designed to make soldering fast and secure. For those who prefer an even faster solderless installation, Vero has a connector port that can be used to further simplify your manufacturing process, reduce inventory cost and allow for field upgradability. The connector port mates to the Molex Pico-EZmate connector harness, sold separately by Molex and through their distribution network. The Molex connector harnesses come in a variety of wire lengths and wire gauge options and can also be custom engineered to meet your specific design requirements. Please consult your local Molex sales representative or visit www.molex.com for more information. Lumen Maintenance Characteristics Bridgelux projects that the Vero 13 family of LED array products will deliver, on average, greater than 70% lumen maintenance after 50,000 hours of operation at two times the nominal drive current in Table 1. This performance assumes constant current operation at up to 2 times the nominal drive current with case temperature maintained at or below 85°C. Continuous use beyond five years may result in a lower lumen maintenance. For use beyond these operating conditions please consult your Bridgelux sales representative for further assistance. These projections are based on a combination of package test data, semiconductor chip reliability data, a fundamental understanding of package related degradation mechanisms, and performance observed from products installed in the field using Bridgelux die technology. Bridgelux conducts lumen maintenance tests per LM-80. Observation of design limits is required in order to achieve this projected lumen maintenance. Environmental Compliance Bridgelux is committed to providing environmentally friendly products to the solid-state lighting market. Vero LED Arrays comply with the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS directive. Bridgelux does not intentionally add the following restricted materials to any LED array products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE). UL Recognition Bridgelux secures UL Recognition for all of its LED array products. Please refer to the UL file 357031 for the latest list of UL Recognized Bridgelux LED arrays. Bridgelux uses UL Recognized materials with suitable flammability ratings in the Vero LED array products to streamline the process for customers to secure UL listing of the final luminaire product. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 4 of 17 CE Recognition In accordance with the relevant European Union Directives, the BXRC series LED array products conform to the applicable requirements of the IEC/EN 62031:2008 (LED Modules for General Lighting Safety Specifications) and IEC 62471:2006 (Photobiological Safety of Lamps and Lamp Systems). Bridgelux maintains a CE Declaration of Conformity statement on its website and displays the CE mark on product packing labels. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Case Temperature Measurement Point A case temperature measurement point location is included on the top surface of the Vero LED arrays. The location of this measurement point is indicated in the mechanical dimensions section of this data sheet. The purpose of this measurement point is to allow the user access to a measurement point which correlates to the true case temperature on the back surface of the LED array. Once the LED array is installed, it is challenging to measure the back surface of the array, or true case temperature. Consistent and repeatable temperature measurements can be correlated to the data sheet performance specifications and to published LM-80 reliability data. The use of the case temperature measurement point is fully explained in AN30. CAUTION: CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the Vero LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux Vero LED arrays is in accordance with IEC specification EN62471: Photobiological Safety of Lamps and Lamp Systems. Vero LED arrays are classified as Risk Group 1 (Low Risk) when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN Do not touch the Vero LED array or yellow resin area during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 5 of 17 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) CRI Nominal Drive [5] Current (mA) Typical Pulsed [4] Flux Tj = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 2700 80 500 1880 32.5 16.3 116 2700 90 500 1510 32.5 16.3 93 2700 97 500 1210 32.5 16.3 74 BXRC-30E2000-C-xx 3000 80 500 1950 32.5 16.3 120 BXRC-30G2000-C-xx 3000 90 500 1600 32.5 16.3 98 3000 97 500 1310 32.5 16.3 81 BXRC-35E2000-C-xx 3500 80 500 2020 32.5 16.3 124 BXRC-40E2000-C-xx 4000 80 500 2060 32.5 16.3 127 BXRC-40G2000-C-03 4000 90 500 1810 32.5 16.3 111 BXRC-50C2000-C-04 5000 70 500 2270 32.5 16.3 140 BXRC-50E2000-C-04 5000 80 500 2090 32.5 16.3 128 BXRC-50G2000-C-04 5000 90 500 1890 32.5 16.3 116 Nominal CCT (K) BXRC-27E2000-C-xx BXRC-27G2000-C-xx Part Number [1] [6] BXRC-27H2000-C-xx [6] BXRC-30H2000-C-xx Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) [2] [3] CRI Nominal Drive [5] Current (mA) Typical DC Flux Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 2700 80 500 1640 30.8 15.4 107 BXRC-27G2000-C-xx 2700 90 500 1310 30.8 15.4 85 BXRC-30E2000-C-xx 3000 80 500 1700 30.8 15.4 111 BXRC-30G2000-C-xx 3000 90 500 1390 30.8 15.4 90 BXRC-35E2000-C-xx 3500 80 500 1760 30.8 15.4 114 BXRC-40E2000-C-xx 4000 80 500 1790 30.8 15.4 116 BXRC-40G2000-C-03 4000 90 500 1580 30.8 15.4 103 BXRC-50C2000-C-04 5000 70 500 1970 30.8 15.4 128 BXRC-50E2000-C-04 5000 80 500 1820 30.8 15.4 118 BXRC-50G2000-C-04 5000 90 500 1650 30.8 15.4 107 Nominal CCT (K) BXRC-27E2000-C-xx Part Number [1] Notes for Tables 1 & 2: 1. The “-xx” suffix refers to color control, “-02” for 2SDCM, “-03” for 3SDCM or “-04” for 4SDCM. 2. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 3. Typical performance is estimated based on operation under DC (direct current) with the LED array mounted to a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 4. Bridgelux maintains a ± 7% tolerance on flux measurements. 5. Drive current is referred to as nominal drive current. 6. Please refer to DS34 for complete information regarding the Bridgelux Décor products. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 6 of 17 Performance at Commonly Used Drive Currents Vero LED arrays are tested to the specifications shown in Tables 4 and 5. Vero may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figure 1 and the flux vs. current characteristics shown in Figure 2. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-27E2000-C-xx 80 BXRC-27G2000-C-xx 90 BXRC-30E2000-C-xx 80 BXRC-30G2000-C-xx 90 BXRC-35E2000-C-xx 80 BXRC-40E2000-C-xx 80 BXRC-40G2000-C-03 90 BXRC-50C2000-C-04 70 BXRC-50E2000-C-04 80 BXRC-50G2000-C-04 90 Drive Current [1] (mA) Typical Vf Tj = 25ºC (V) Typical Watt Tj = 25ºC (W) Typical Flux Tj = 25ºC [2] (lm) Typical DC Flux Tc = 85ºC [3] (lm) Typical Efficacy Tj = 25ºC (lm/W) 500 700 1050 500 700 1050 500 700 1050 500 700 1050 500 700 1050 500 700 1050 500 700 1050 500 700 1050 500 700 1050 500 700 1050 32.5 33.7 35.0 32.5 33.7 35.0 32.5 33.7 35.0 32.5 33.7 35.0 32.5 33.7 35.0 32.5 33.7 35.0 32.5 33.7 35.0 32.5 33.7 35.0 32.5 33.7 35.0 32.5 33.7 35.0 16.3 23.6 36.7 16.3 23.6 36.7 16.3 23.6 36.7 16.3 23.6 36.7 16.3 23.6 36.7 16.3 23.6 36.7 16.3 23.6 36.7 16.3 23.6 36.7 16.3 23.6 36.7 16.3 23.6 36.7 1880 2540 3640 1510 2040 2920 1950 2630 3770 1600 2150 3090 2020 2730 3910 2060 2780 3980 1810 2450 3510 2270 3060 4390 2090 2810 4030 1890 2550 3660 1640 2170 3020 1310 1740 2420 1700 2260 3130 1390 1850 2570 1760 2340 3250 1790 2380 3310 1580 2100 2910 1970 2620 3650 1820 2420 3350 1650 2190 3040 116 108 99 93 87 80 120 112 103 98 91 84 124 116 106 127 118 108 111 104 96 140 130 120 128 119 110 116 108 100 Notes for Table 3: 1. Values in bold correspond to performance at nominal drive current listed in Table 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 7 of 17 Flux & Electrical Characteristics Table 4: Flux Characteristics CCT (K) 2700 3000 3500 4000 5000 Nominal Drive Current [1] (mA) Typical Pulsed Flux Tj = 25ºC [1][2] (lm) Minimum Pulsed Flux Tj = 25ºC [1],[2],[8] (lm) Typical Center Beam Candle Power Tj = 25ºC [4] (cd) Typical DC Flux Tc = 85ºC [5],[6] (lm) Minimum DC Flux Tc = 85ºC (5],[7) (lm) Part Number CRI (min) BXRC-27E2000-C-xx 80 500 1880 1730 600 1640 1510 BXRC-27G2000-C-xx 90 500 1510 1390 480 1310 1210 BXRC-30E2000-C-xx 80 500 1950 1790 620 1700 1560 BXRC-30G2000-C-xx 90 500 1600 1470 510 1390 1280 BXRC-35E2000-C-xx 80 500 2020 1860 640 1760 1620 BXRC-40E2000-C-xx 80 500 2060 1890 650 1790 1650 BXRC-40G2000-C-03 90 500 1810 1660 580 1580 1450 BXRC-50C2000-C-04 70 500 2270 2090 720 1970 1820 BXRC-50E2000-C-04 80 500 2090 1920 660 1820 1670 BXRC-50G2000-C-04 90 500 1890 1740 600 1650 1510 [3][9] Notes for Table 4: 1. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at nominal drive current. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical R9 value for 90 CRI product options is 70. 4. Center beam candle power is a calculated value based on Lambertian radiation pattern at nominal drive current. 5. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 6. Typical performance is estimated based on operation under DC (direct current) with the LED array mounted to a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Minimum DC Flux values are provided for reference only and are not a parameter guaranteed by production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 8. Refer to Table 3 for typical performance at other driver currents. 9. Décor 97 CRI products available. Please refer to DS34. Table 5: Electrical Characteristics and Driver Selection Voltages Forward Voltage [1],[2] Pulsed, Tj = 25ºC (V) Nominal Drive Current [1] (mA) Minimum Typical 165 26.9 350 Maximum Typical Coefficient of Forward Voltage ΔVf / ΔTj (mV/°C) Typical Thermal Resistance Junction to Case RƟ j-c (C/W) 29.9 32.9 -24.0 28.3 31.4 34.6 500 29.3 32.5 700 30.3 1050 31.5 Driver Selection Voltages (V) [4] [3] [4] Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = - 40ºC (V) 0.81 24.9 34.3 -24.0 0.84 26.2 35.9 35.8 -24.0 0.87 27.0 37.0 33.7 37.0 -24.0 0.91 27.9 38.1 35.0 38.5 -24.0 0.99 28.8 39.2 Notes for Table 5: 1. Parts are tested in pulsed conditions at the nominal drive current (indicated in bold font), Tj = 25°C. Pulse width is 10 ms. 2. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. 3. Forward voltage minimum and maximum values at the nominal drive current (indicated in bold font) are guaranteed by 100% test. Values provided at other drive currents are provided for reference only and are not guaranteed by test. 4. Vf Min hot and Vf max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 8 of 17 Absolute Maximum Ratings Table 6: Maximum Drive Current and Reverse Voltage Ratings Part Number Drive Current for LM-80 [3] (mA) Maximum Peak Pulsed Drive Current [1] (mA) Maximum Reverse Voltage [2] (Vr) BXRC-xxx2000-C-xx 1050 1500 -55 Notes for Table 6: 1. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where the LED array can be driven without catastrophic failures. 2. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 3. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for these products. Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 150°C Storage Temperature -40°C to +105°C Operating Case Temperature 105°C Soldering Temperature[1] 350°C for a maximum of 10 seconds [2] Notes for Table 7: 1. See Bridgelux Application Note AN31, Assembly Considerations for Vero LED arrays, for more information. 2. For IEC 62717 requirement, please contact Bridgelux Sales Support. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 9 of 17 Drive Current versus Forward Voltage Characteristics Figure 1: Typical Drive Current vs. Voltage Typical Relative Luminous Flux vs. Drive Current, Tj=25°C Figure 2: Typical Flux vs. Current, Tj = 25°C 200% 180% 160% Relative Intensity 140% 120% 100% 80% 60% 40% 20% 0% 0 200 400 600 800 1000 1200 Current (mA) Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 10 of 17 Typical Light Output Characteristics vs. Temperature Figure 3: Typical Flux vs. Junction Temperature 110% Normalized Luminous Flux 100% 90% 80% 70% -10 0 10 20 30 40 50 60 70 80 Junction Temperature, °C 90 100 110 120 130 Notes for Figure 3: 1. Characteristics shown for warm white reflect 3000K 80 CRI. 2. Characteristics shown for neutral white reflect 4000K 80 CRI. 3. Characteristics shown for cool white reflect 5000K 70 CRI. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 11 of 17 Typical Chromaticity Characteristics vs. Temperature Figure 4: Typical ccy Shift vs. Junction Temperature Warm White 0.02 Cool White Neutral White Δy 0.01 0.00 -0.01 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, °C 90 100 110 120 130 Figure 5: Typical ccx Shift vs. Junction Temperature Warm White 0.02 Cool White Neutral White Δx 0.01 0.00 -0.01 -0.02 -10 0 10 20 30 40 50 60 70 80 90 100 110 120 130 Junction Temperature, °C Notes for Figures 4 and 5: 1. Characteristics shown for warm white reflect 3000K 80 CRI. 2. Characteristics shown for neutral white reflect 4000K 80 CRI. 3. Characteristics shown for cool white reflect 5000K 70 CRI. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 12 of 17 Typical Radiation Pattern Figure 6: Typical Spatial Radiation Pattern 100% 90% Relative Intensity (%) 80% 70% 60% 50% 40% 30% 20% 10% 0% -90° -80° -70° -60° -50° -40° -30° -20° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° Angular Displacement (°) Notes for figure 6: 1. 2. Typical viewing angle is 120⁰. The viewing angle is defined as the off axis angle form the centerline where Iv is ½ of the peak value. Figure 7: Typical Polar Radiation Pattern Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 13 of 17 Wavelength Characteristics at Drive Current, Tj=25°C Figure 8: Typical Color Spectrum Relative Intensity 3000K 4000K 5000K 110% 100% 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Notes for Figure 8: 1. Color spectrum shown for warm white is 3000K 80 CRI. 2. Color spectrum shown for neutral white is 4000K 80 CRI. 3. Color spectrum shown for cool white is 5000K 70 CRI. Mechanical Dimensions Figure 9: Drawing for Vero 13 LED Array Notes for Figure 9: 1. Mounting holes (2X) are for M2.5 screws. 2. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 3. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 4. Solder pads and connector port are labeled “+” and “-“ to denote positive and negative, respectively. 5. It is not necessary to provide electrical connections to both the solder pads and the connector port. Either set may be used depending on application specific design requirements. 6. Drawings are not to scale. 7. Drawing dimensions are in millimeters. 8. Unless otherwise specified, tolerances are ± 0.10mm. 9. Refer to Application Notes AN30 and AN31 for product handling, mounting and heat sink recommendations. 10. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 11. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 12. Bridgelux Vero 13 LED arrays are packaged in trays of 20 units with a maximum planar dimension of 215.mm x 279.4 mm (8.5 x 11 inches) per tray. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 14 of 17 Color Binning Information Figure 10: Graph of Warm White Test Bins in xy Color Space Planckian Locus (BBL) ANSI Bin 2SDCM 0.44 0.43 2700K 3000K 0.42 3SDCM 3500K 0.41 0.40 0.39 0.38 0.37 0.36 0.38 0.39 0.40 0.41 0.42 0.43 0.44 0.45 0.46 0.47 0.48 Note: Pulsed Test Conditions, Tj = 25°C Table 10: Warm White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K ANSI Bin (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (for reference only) 03 (3SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) 02 (2SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) Figure 11: Graph of Neutral White Test Bins in xy Color Space Planckian Locus (BBL) ANSI Bin 2SDCM 3SDCM 0.41 0.40 4000K 0.39 0.38 0.37 0.36 0.35 0.36 0.37 0.38 0.39 0.4 0.41 Note: Pulsed Test Conditions, Tj = 25°C Table 11: Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 4000K ANSI Bin (3710K - 4260K) (for reference only) 03 (3SDCM) (3851K - 4130K) 02 (2SDCM) (3895K - 4081K) Center Point (x,y) (0.3818, 0.3797) Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 15 of 17 Color Binning Information (continued) Figure 12: Graph of Cool White Test Bins in xy Color Space Planckian Locus (BBL) ANSI Bin 4SDCM 0.38 5000K 0.37 0.36 0.35 0.34 0.33 0.32 0.33 0.34 0.35 0.36 Note: Pulsed Test Conditions, Tj = 25°C Table 12: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code 5000K ANSI Bin (4745K - 5311K) (for reference only) 04 (4SDCM) (4801K - 5282K) Center Point (x,y) (0.3447, 0.3553) Bridgelux Vero 13 Array Series Product Data Sheet DS31 (4/21/2014) Page 16 of 17 Design Resources Bridgelux is developing a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. Included below is a list of resources under development which will be downloaded from the Bridgelux web site under the Design Resources section. Application Notes • AN30: Effective Thermal Management of Bridgelux Vero LED Arrays • AN31: Assembly Considerations for Bridgelux Vero LED Arrays • AN32: Electrical Drive Considerations for Bridgelux Vero LED Arrays • AN34: Reliability Data Sheet for Bridgelux Vero LED Arrays • AN36: Optical Considerations for Bridgelux Vero LED Arrays Optical Source Models Optical source models and ray set files are available for all Bridgelux Vero LED array products. The list below contains the formats currently available. If you require a specific format not included in this list, please contact your Bridgelux sales representative for assistance. • Zemax • ASAP • IESNA • LightTools • LucidShape • OPTIS SPEOS • PHOTOPIA • TracePro • Radiant Imaging Source Model 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both SAT and STEP formats. Please contact your Bridgelux sales representative for assistance. About Bridgelux Bridgelux is a leading developer and manufacturer of technologies and solutions transforming the $40 billion global lighting industry into a $100 billion market opportunity. Based in Livermore, California, Bridgelux is a pioneer in solid state lighting (SSL), expanding the market for light emitting diode (LED) technologies by driving down the cost of LED lighting systems. Bridgelux’s patented light source technology replaces traditional technologies (such as incandescent, halogen, fluorescent and high intensity discharge lighting) with integrated, solid state lighting solutions that enable lamp and luminaire manufacturers to provide high performance and energy efficient white light for the rapidly growing interior and exterior lighting markets, including street lights, commercial lighting and consumer applications. For more information about the company, please visit www.bridgelux.com. Bridgelux and the Bridgelux stylized logo design are registered trademarks, and Vero is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. © 2014 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (2/4/2014) Page 17 of 17
BXRC-40G2000-C-02 价格&库存
很抱歉,暂时无法提供与“BXRC-40G2000-C-02”相匹配的价格&库存,您可以联系我们找货
