315
    ADAFRUIT
    DIP4
    LAMP INCAND S-8 S.C. BAYONET
315 数据手册
LEDS / BARE LEDS Clear 'Piranha' Super-flux RGB (tri-color) LED (25 pack) - Common Anode PRODUCT ID: 315 DESCRIPTION - Clear 5mm tri-color LEDs with separate red, green and blue LED chips inside! Nice bright indicator or illuminator, and fun to color-swirl. 80 degree viewing angle. You can plug these into a breadboard diagonally These are Common-Anode type which means you connect one pin to 5V or so and then tie the other three legs to ground through a resistor. We carry and use CA more than CC because multi-LED driver chips (such as the TLC5940/TLC5941) are often designed exclusively for CA and can't be used with Common-Cathode. • 0.3"/7.6mm on each side, square. Sometimes called 'Super flux' or 'Piranha' • Clear lens, 80 degree viewing angle • Red: 630 nm wavelength, Green: 525 nm, Blue: 470 nm • Red: 2.1-2.5V Forward Voltage, at 20mA current, Green: 3.8-4.5V, Blue: 3.8-4.5V • Red: 400 mcd typical brightness, Green: 1200 mcd, Blue: 400 mcd< (2000 mcd total) • BL-FL7680RGBC Datasheet If you need some help using LEDs, please read our "Introduction to using LEDs" tutorial for any electronics project. http://www.adafruit.com/products/315 7/16/2015
很抱歉,暂时无法提供与“315”相匹配的价格&库存,您可以联系我们找货
