A006-EW830-70
A006-EW830-70
    LEDDYNAMICS(LEDdynamics公司)
    LED ENG LUXSTRIP WARM WHT STRIP
A006-EW830-70 数据手册
A006 LuxStrip II™ 6 Line 12 in. LED Engine with Driver DATA SHEET Page 1 of 6 Product Overview The LuxStrip II A006 is a powerful compact light engine built on a Printed Circuit Board (PCB) and thermally engineered to accommodate high brightness LEDs. Utilizing “driver on board” technology allows the entire unit to easily be integrated into fixtures where space is at a premium. The LuxStrip II is a perfect solution for applications such as general lighting, fluorescent replacement, sign, channel letters, and architectural lighting. As a standard offering at 12”, the LuxStrip II comes with up to six CREE® XP-E or XP-G* devices. Strips can be cut to specific lengths, as short as 4”. The strips are designed to interconnect to allow for varying lengths, and can be deployed in lengths up to 12 feet. Optics are available for directional lighting. Standard optical options are 5º, 8º, and 20º. Other options may be added to suit custom applications. Unlike traditional PCBs, the driver for the LuxStrip II is conveniently contained on board, allowing power supplies which deliver a fixed voltage to be used. An industry standard 24VDC power supply is ideal for use with LuxStrip II. This is due to the use of a LUXdrive series power module, which allows for a fixed voltage input while maintaining a true, constant-current regulated output for the LEDs. Power and dimming control voltage is connected via a low profile board-to-board connector at the end of the strip, and utilizes a unique polarized connection for goof proof assembly. Several strips can be stacked/attached together upto 12 feet typical. “Stub” sections can be shortened at 2” increments to fit any length requirement. * - Units can be customized for other LEDs or redesigned for OEM applications - Contact LUXdrive for more information Features Typical Applications Designed to operate on 24VDC On board driver provides constant current 12” x .95”, cuttable every 2”, min length 4” Fits the Dialight 22mm optics (OPXP-1-xxxx) Easily joined for up to 12 feet length 0 to 100% dimming w/signal pass-through Works with 0-10V Dimmers, Lutron Nova T® Polarized connections - No Goofs Compatible with CREE® XP-E, and XP-G Series configuration eliminates current hogging Line lighting and wall wash Automotive, RV & Marine Lighting Tight space and cove lighting Point of Purchase Lighting Desk & Reading Lamps Fluorescent replacement fixtures Cabinet & Display Case Lighting Sign & Channel Letters Figure 1 (6) CREE XP-G LEDs in series (V = 24VDC) and end-feeding another strip LEDdynamics, Inc. 802.728.4533 P 802.728.3800 F sales@LUXdrive.com www.LUXdrive.com ©2011 LUXdrive, A Division of LEDdynamics, Inc. www.LUXdrive.com. Specifications subject to change without notice. June, 2011 - Rev 1.2 A006 LuxStrip II™ 6 Line 12 in. LED Engine with Driver DATA SHEET Page 2 of 6 Luminous Flux Table 1 Typical Luminous Flux at LED Junction Temperature of 25˚C Type Part Number Color A006-GW750-35 5000K White A006-GW750-70 5000K White Drive Current in (mA) Luminous Flux CRI Continuous lengh (feet) Power Consumption (per foot) 350 700 700 typ 1270 typ 75 typ 75 typ 12 max 8 max 7W 15W A006-GW740-35 Cree XP-G A006-GW740-70 A006-GW830-35 A006-GW830-70 4000K White 4000K White 3000K White 3000K White 350 700 350 700 700 typ 1270 typ 630 typ 1080 typ 75 typ 75 typ 80 typ 80 typ 12 max 8 max 12 max 8 max 7W 15W 7W 15W A006-EW750-35 A006-EW750-70 Cree XP-E A006-EW740-35 A006-EW740-70 A006-EW830-35 A006-EW830-70 5000K White 5000K White 4000K White 4000K White 3000K White 3000K White 350 700 350 700 350 700 630 typ 1080 typ 630 typ 1080 typ 450 typ 810 typ 75 typ 75 typ 75 typ 75 typ 80 typ 80 typ 12 max 8 max 12 max 8 max 12 max 8 max 7W 15W 7W 15W 7W 15W Notes for Table 1: 1. Custom units available upon request, restrictions apply. Contact LUXdrive for additional details. 2. See CREE® XP-E, and XP-G data sheets for more details. Part Number Identifications The part number is explaned below: A006- A B C DD - EE Where: A006..... designates the LUXdrive Product ID for a LuxStrip II board A............ designates LED Type (G for XP-G, E for XP-E, C for XP-C) B............. designates LED color (W= White) C............. designates CRI value (7= 75typ, 8=80 typ, 0 for direct color variants) DD.......... designates Color Variant (30=3000K White, 40=4000K White, 50=5000K White) EE........... designates Drive Current (35=350mA, 70=700mA) Thermal Resistance (LED junctions to bottom of PCB) LuxStrip II with XP-G LEDs in white 2.5° C/W Operating Temperature (T)................... -40° to 100°C LED junction temperature must be kept within manufacturers limits. See CREE® XP-E, XP-G data sheets for more details 3 FR4 board temperature LEDdynamics, Inc. 802.728.4533 P 802.728.3800 F sales@LUXdrive.com www.LUXdrive.com ©2011 LUXdrive, A Division of LEDdynamics, Inc. www.LUXdrive.com. Specifications subject to change without notice. June, 2011 - Rev 1.2 A006 LuxStrip II™ 6 Line 12 in. LED Engine with Driver DATA SHEET Page 3 of 6 Heat Sinking and Mounting The LuxStrip II has five mounting points for #4, or #6 screws used with fiber or nylon washers. These screw holes are provided to allow secure connection to the heat sink. Thermal epoxy, or double-sided thermal tape may be used for speedy and easy assembly. The LuxStrip II should be attached to additional heat sink for proper thermal management. At minimum, a heat sink of a metal plate (copper or aluminum), attched using a thermal interface material (such as LUXdrive A006-TAT), should be used to increase the area exposed to free air. The LuxStrip II FR4 Printed Circuit Board has a backing plate that is electrically isolated from the emitter. It is not necessary to use an electrically insulating thermal interface material. Table 2 Part Number Description A006-TAT Thermal Adhesive Number of Compatible With Feet 180 A006 Connection Diagram Figure 2 LuxStrip II wiring diagram There are two different types of wiring connectors available for the LuxStrip II. Both connectors are 24.1mm (0.95”) wide and 19.1mm (0.75”) long. The A006-HE which has four wires, two wires for power in and two wires for di ming, and the A006-HN which has 2 wires for power in. Also available are the Barrel Plug connectors A006-PE and A006-PN. Both Barrel Plug connectors feature a 2.5mm center positive plug. The A006-PE has dimming wires while the A006-PN does not. Both Barrel Plug solutions offer solderless setup of the system. Custom connectors available upon request, restrictions apply. Contact LUXdrive for additional details. Figure 3 A006-PN LEDdynamics, Inc. 802.728.4533 P 802.728.3800 F sales@LUXdrive.com www.LUXdrive.com Figure 4 A006-HE ©2011 LUXdrive, A Division of LEDdynamics, Inc. www.LUXdrive.com. Specifications subject to change without notice. June, 2011 - Rev 1.2 A006 LuxStrip II™ 6 Line 12 in. LED Engine with Driver DATA SHEET Page 4 of 6 Configuration To be able to fit lengths of less than 12”, the LuxStrip II can be trimmed as necessary. This method is called “stub”, where the unpowered end of the strip is cut to fit the fixture or extrusion. A common hacksaw and soldering iron is all that is required to allow for field modification of the strips to accommodate custom installations. Jumper pads are available at each cut point to shorten the electrical length of each string. Simply jump the pad that is located before the cut. The remaining LEDs will get the proper current and voltage since they have their own driver. As the length of the LuxStrip II is reduced, the minimum voltage to power the unit is also reduced. Using this approach, here are the possible lengths: Figure 5 Typical “stub” strip cut lengths and results Figure 6 Electrical equivalent of LuxStrip II LEDdynamics, Inc. 802.728.4533 P 802.728.3800 F sales@LUXdrive.com www.LUXdrive.com ©2011 LUXdrive, A Division of LEDdynamics, Inc. www.LUXdrive.com. Specifications subject to change without notice. June, 2011 - Rev 1.2 A006 LuxStrip II™ 6 Line 12 in. LED Engine with Driver DATA SHEET Page 5 of 6 Optics The LuxStrip II can be fitted with many different optics from the major optics manufacturers. Dialight optics, also offered by LUXdrive, offer five different illumination patterns: spot (5°), frosted spot (7°), medium(8°), wide(20°), and oval (8° x 25°) (Note that LED type and color will have a slight effect on illumination pattern, e.g., non-white LEDs give a narrower distribution). See the Dialight CREE™ XP® ADHESIVE-BACKED LENS SYSTEM” data sheet for more information, including typical light distribution patterns. Table 3 Description Number of LEDs Half Width Viewing Angle Compatible With L2-OPXP-1-SPOT L2-OPXP-1-SDIF LuxStrip II L2-OPXP-1-MED Spot Base Module Frosted Spot Base Module Medium Base Module 1 1 1 5° 7° 8° A006 A006 A006 L2-OPXP-1-WIDE L2-OPXP-1-OVAL Wide Frosted Base Module Oval Base Module 1 1 20° 8° x 25° A006 A006 Type Part Number Figure 7 Standard illumination patterns available, and approximate difusion at 1.5M (5ft.) Figure 8 LuxStrip II with optics. LEDdynamics, Inc. 802.728.4533 P 802.728.3800 F sales@LUXdrive.com www.LUXdrive.com ©2011 LUXdrive, A Division of LEDdynamics, Inc. www.LUXdrive.com. Specifications subject to change without notice. June, 2011 - Rev 1.2 A006 LuxStrip II™ 6 Line 12 in. LED Engine with Driver DATA SHEET Page 6 of 6 Physical Dimensions Figure 9a Top View - Typical Physical Dimensions, Including Mounting Holes Figure 9b Side View - Typical Height Side View Top View Base View (All Models) Spot, Wide, and Oval Medium Figure 10 Typical Dimensions for the Dialight Optic. LEDdynamics, Inc. 802.728.4533 P 802.728.3800 F sales@LUXdrive.com www.LUXdrive.com ©2011 LUXdrive, A Division of LEDdynamics, Inc. www.LUXdrive.com. Specifications subject to change without notice. June, 2011 - Rev 1.2
A006-EW830-70 价格&库存
很抱歉,暂时无法提供与“A006-EW830-70”相匹配的价格&库存,您可以联系我们找货
