3mm
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
RED,
Super
Bright
Bright
RED, Super
Super
Bright
B
3SRX-X
Industry Standard 3mm (T1) Package
RoHS Compliant
Water Clear (C), Diffused (D), and Tinted (T) Lenses
Available in Flange (F) and Shouldered (S) Lead frame
styles
Up to 60 mcd Luminous Intensity at 20 mA
Ideal for Status Indication and Display
Recommended for Bivar Flexible Light Pipe assemblies
Bivar 3mm T1 Package Super Bright LED is ideal for those applications where higher ambient lighting
exists such as sign boards, security system displays, and medical applications. Bivar offers water
clear LED lens for maximum light output, diffused LED lens for uniform light output, and tinted lens to
identify the color of the LED. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies. The
Shouldered Lead frame LED is ideal for vertical spacer assemblies without lead bends and also has a
built in strain relief feature which is ideal for right angle holder assemblies that require lead bends.
Part Number
Viewing Angle
3SRC-F
Water Clear
20°
3SRD-F
Red Diffused
35°
Red Tinted
20°
Water Clear
30°
3SRD-S
Red Diffused
40°
3SRT-S
Red Tinted
30°
3SRC-S
Emitted Color
Peak. Wavelength
λp(nm) TYP.
Lens Appearance
3SRT-F
Material
GaAIAs/GaAs
RED
645nm
Part Number Designation
3 S X X -X
LED Body, mm
Super Bright
Emitted Color
Lead Frame & Body Style
i.e. -F, -S
Lens Appearance
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision C 06/15
Page 1 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
Super
Bright
RED, Super
Bright
Outline Dimensions
Flanged “3SXX-F” LED
Shouldered Lead “3SXX-S” LED
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision C 06/15
Page 2 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
Super
Bright
RED, Super
Bright
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
70 mW
Forward Current ( DC )
30 mA
Peak Forward Current 1
150 mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MIN
TYP
MAX
MIN
TYP
MAX
TYP
60
35
3SRT-F
60
3SRC-S
60
30
40
40
60
30
3SRC-F
3SRD-F
3SRD-S
1.7
1.7
2.4
2.4
100
3SRT-S
Notes: 1. Tolerance of forward voltage : ±0.05V.
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision C 06/15
Page 3 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
Super
Bright
RED, Super
Bright
Typical Electrical / Optical Characteristics
0°
10°
20°
30°
Iv
1.0
40°
20°
30°
35°
50°
40°
0.5
60°
70°
80°
0.0
600
λ(nm)
700
650
90°
750
0.5
Fig. 1 Relative Luminous Intensity vs. Wavelength
@ 20mA
If (mA)
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
Iv
1000
4.0
100
3.0
10
2.0
1
1.0
0.1
Vf (V)
1.0
0.3
2.0
3.0
4.0
If (mA)
0.0
5.0
1
Fig. 3 Forward Current vs. Forward Voltage
10
100
1000
Fig. 4 Relative Luminous Intensity vs. Forward Current
Normalize @ 20 mA
Vf (V)
Iv
3.0
1.2
1.1
2.0
1.0
1.0
0.9
0.8
-40
T (°C)
80
Fig. 5 Forward Voltage vs. Temperature
0.0
T (°C)
-40
80
Fig. 6 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision C 06/15
Page 4 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
Super
Bright
RED, Super
Bright
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
Anti-Static Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 Web:
E-mail:
bivar@bivar.com Web: www.bivar.com
Phone: (949)
www.bivar.com
Rev. A C
01/16/08
Revision
06/15
Page
Page 4
5 of
of 4
5
很抱歉,暂时无法提供与“3SRT-S”相匹配的价格&库存,您可以联系我们找货
