REV.
A
DESCRIPTION
DATE
Engineering Release.
APPROVED
04/05/06
M. C.
0.339 [8.6mm]
Flat Edge
Cathode ID
Ø.224 [Ø5.7mm]
0.94 [24.0mm]
0.197 [5.0mm]
MIN.
0.04 [1.0mm]
MIN.
0.177 [4.5mm]
0.100 [2.5mm]
0.039 [1.0mm]
Ø0.032+.003
-.002 TYP.
0.020 [0.5mm]SQ. TYP.
0.100 [2.5mm]TYP.
Recommended Mounting Holes
LED
Part No.
5HC-8-F
Material
GaAsP/GaAs
Chip
Peak Wave
Length
lp(nm)
635
Absolute Maximum Ratings
Lens Appearance
Emitted Color
RED
WATER CLEAR
ABSOLUTE MAXIMUM RATINGS (Ta = 25°C)
Dl
(nm)
Pd
(mW)
If
(mA)
Peak If
(mA)
45
80
30
150
2.0
2.6
180
STANDARD TOLERANCE
5V
.X
REVERSE CURRENT ( VR=5V)
100 µA
OPERATING TEMPERATURE RANGE
.XX
± .02
.XXX ± .010
-25°C ~ 85°C
STORAGE TEMPERATURE
-30°C ~ 100°C
LEAD SOLDERING TEMPERATURE (1/16" FROM BODY)
260°C for 5 Seconds
± .1
DESIGNED:
Sonny Dam
CHECKED:
T. Yin
ANGULAR
X°
± 1°
04/05/06
DATE:
04/05/06
8
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
Viewing
Angle
(Deg)
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
REVERSE VOLTAGE
Electro-Optical Data @ 20mA
Vf
lv
(V)
(mcd)
Typ.
Typ.
Max.
PART NO:
FAX: (949) 951-3974
T-1 ¾ (5mm)
Narrow Viewing Angle 5 Ø
REVISION:
5HC-8-F
CAGE CODE : 32559
A
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“5HC-8-F”相匹配的价格&库存,您可以联系我们找货
