Rectangular Package Discrete LED
ORANGE, 2 x 5 mm
R5OD
Rectangular Package
RoHS Compliant
Diffused Lens
Available in Standard Lead Frame style
Ideal for Status Indication and Bar Graph Displays
Bivar Rectangular 2 x 5mm Package LED may be used in almost any application requiring greater indication visibility and is ideal for creating bar graph displays when arranged in linear LED arrays. Bivar
offers diffused LED lens for uniform light output. The Standard Lead frame LED is ideal for vertical
spacer assemblies and Right Angle Holder assemblies that require lead bends.
Part Number
Material
Emitted Color
Peak. Wavelength
λp(nm) TYP.
Lens Appearance
Viewing Angle
R5OD
GaAsP/GaP
ORANGE
625nm
Orange Diffused
120°
Outline Dimensions
Standard “R5XX” LED
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Part Number Designation
R 5 X X
LED Body, mm
Emitted Color
Lens Appearance
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision A 02/15
Page 1 of 4
3mm
(T1) Package
Discrete
LEDs
Rectangular
Package
Discrete
LED
AMBER
ORANGE, 2 x 5 mm
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
80 mW
Forward Current ( DC )
Peak Forward Current
30 mA
1
150 mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb )
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
R5OD
2.0
2.6
Notes: 1. Tolerance of forward voltage : ±0.05V.
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MAX
MIN
TYP
MAX
MIN
TYP
MAX
TYP
100
8
120
2. Tolerance of dominant wavelength : ±1.0nm.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision A 02/15
Page 2 of 4
3mm
(T1) Package
Discrete
LEDs
Rectangular
Package
Discrete
LED
AMBER
ORANGE, 2 x 5 mm
Typical Electrical / Optical Characteristics
0°
Iv
10°
20°
30°
1.0
120°
40°
50°
0.5
60°
70°
80°
λ(nm)
0.0
550 600
650 700 750
Fig. 1 Relative Luminous Intensity vs. Wavelength
@ 20mA
90°
0.5
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
Iv
Iv (%)
50
1000
40
100
30
10
.01
1.2
Vf (V)
1.6
2.0 2.4
2.8 3.0
1
Fig. 3 Relative Intensity (10mA) vs.
Forward Voltage
50
If (mA)
1
10
100
1000
Fig. 4 Relative Luminous Intensity (%) vs.
Forward Current
If(mA)
400
Iv (%)
200
40
100
30
10
T (°C)
60
80
100
Fig. 5 Forward Current vs. Temperature
10
T (°C)
-20
0 20 40
60
80 100
Fig. 6 Relative Intensity (%) vs. Temperature
@ 20 mA
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 02/15
Page 3 of 4
3mm
(T1) Package
Discrete
LEDs
Rectangular
Package
Discrete
LED
AMBER
ORANGE, 2 x 5 mm
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A A
01/16/08
Revision
02/15
Page
Page 4
4 of
of 4
4
很抱歉,暂时无法提供与“R5OD”相匹配的价格&库存,您可以联系我们找货
