Rectangular Package Discrete LED
RED, 2 x 7 mm
R7HX
Rectangular Package
RoHS Compliant
Water Clear (C), Diffused (D), and Tinted (T) Lenses
Available in Standard Lead Frame style
Ideal for Status Indication and Bar Graph Displays
Bivar Rectangular 2 x 7mm Package LED may be used in almost any application requiring greater indication visibility and is ideal for creating bar graph displays when arranged in linear LED arrays. Bivar
offers water clear LED lens for maximum light output, diffused LED lens for uniform light output, and
tinted lens to identify the color of the LED. The Standard Lead frame LED is ideal for vertical spacer
assemblies and Right Angle Holder assemblies that require lead bends.
Part Number
Material
Emitted Color
Peak. Wavelength
λp(nm) TYP.
R7HC
R7HD
GaAsP/GaP
RED
625nm
R7HT
Lens Appearance
Viewing Angle
Water Clear
100°
Red Diffused
120°
Red Tinted
100°
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Part Number Designation
R 7 X X
LED Body, mm
Lens Appearance
Emitted Color
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision A 07/08
Page 1 of 4
3mm
(T1) Package
Discrete
LEDs
Rectangular
Package
Discrete
LED
AMBER
RED, 2 x 7 mm
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
80 mW
Forward Current ( DC )
30 mA
Peak Forward Current 1
150 mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
R7HC
R7HD
2.0
2.8
R7HT
Notes: 1. Tolerance of forward voltage : ±0.05V.
100
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MIN
TYP
MAX
MIN
TYP
MAX
TYP
10
100
8
120
10
100
2. Tolerance of dominant wavelength : ±1.0nm.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision A 07/08
Page 2 of 4
3mm
(T1) Package
Discrete
LEDs
Rectangular
Package
Discrete
LED
AMBER
RED, 2 x 7 mm
Typical Electrical / Optical Characteristics
0°
Iv
10°
1.0
20°
30°
100°
120°
40°
50°
0.5
60°
70°
80°
λ(nm)
0.0
550 600
650 700 750
Fig. 1 Relative Luminous Intensity vs. Wavelength
@ 20mA
90°
0.5
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
Iv
Iv (%)
1000
50
40
100
30
10
.01
1.2
Vf (V)
1.6
2.0 2.4
1
2.8 3.0
10
100
1000
Fig. 4 Relative Luminous Intensity (%) vs.
Forward Current
Fig. 3 Relative Intensity (10mA) vs.
Forward Voltage
50
If (mA)
1
If(mA)
400
Iv (%)
200
40
100
30
10
T (°C)
60
80
100
Fig. 5 Forward Current vs. Temperature
10
T (°C)
-20
0 20 40
60
80 100
Fig. 6 Relative Intensity (%) vs. Temperature
@ 20 mA
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 07/08
Page 3 of 4
3mm
(T1) Package
Discrete
LEDs
Rectangular
Package
Discrete
LED
AMBER
RED, 2 x 7 mm
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A A
01/16/08
Revision
07/08
Page
Page 4
4 of
of 4
4
很抱歉,暂时无法提供与“R7HD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+1.22320100+0.14849
- 400+1.21748400+0.14780
- 1000+1.217451000+0.14780
- 2500+1.217422500+0.14779
- 4000+1.217404000+0.14779
