REV.
DESCRIPTION
A Engineering Release
Flat Edge
Cathode ID
DATE
APPROVED
02/10/15
J. C.
0.94 [24.0mm]
0.339 [8.6mm]
MIN.
0.04 [1.0mm]
MIN.
Flange Dia.
0.100 [2.5mm]
0.020 [0.5mm] SQ.
Flanged LED :
P/N: 5UYC-2K-F
MIN.
0.039 [1.0mm]
Recommended Mounting
+.003
-.002
0.94 [24.0mm]
0.346 [8.8mm]
MIN.
0.04 [1.0mm]
MIN.
0.100 [2.5mm]
0.020 [0.5mm] SQ.
Non-Flanged LED:
P/N: 5UYC-2K
MIN.
ABSOLUTE MAXIMUM RATINGS (Ta=25 C)
REVERSE VOLTAGE
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
ANGULAR
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
DESIGNED:
STORAGE TEMPERATURE
Brian Oliver
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
CHECKED:
A. Wright
DATE:
02/10/15
DATE:
02/10/15
PART NO:
FAX: (949) 951-3974
LED
TITLE:
5UYC-2K-X
CAGE CODE : 32559
REVISION:
A
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“5UYC-2K-F”相匹配的价格&库存,您可以联系我们找货
