3mm
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
GREEN,
TURQUOISE,
BLUE,
YELLOW,
Low
Ultra
Ultra
Super
5V
Low
Current
Bright
Ultra
Bright
Current
Bright
Bright
YELLOW,
5V
B
3YX5V-X
Industry Standard 3mm (T1) Package
RoHS Compliant
Water Clear (C), Diffused (D), and Tinted (T) Lenses
Available in Flange (F) and Shouldered (S) Lead Frame
styles
5V Operating Voltage
Ideal for Status Indication and Display
Bivar 3mm T1 Package 5V LED is ideal for those applications equipped with regular 5V power supplies
such as servers and computer peripherals. Bivar offers water clear LED lens for maximum light output,
diffused LED lens for uniform light output, and tinted lens to identify the color of the LED. The Flanged
LED is ideal for Panel Mount Clip & Ring assemblies. The Shouldered Lead frame LED is ideal for
vertical spacer assemblies without lead bends and also has a built in strain relief feature which is ideal
for right angle holder assemblies that require lead bends.
Part Number
Viewing Angle
3YC5V-F
Water Clear
20°
3YD5V-F
Yellow Diffused
35°
Yellow Tinted
20°
Water Clear
30°
3YD5V-S
Yellow Diffused
40°
3YT5V-S
Yellow Tinted
30°
3YC5V-S
GaAsP/Gap
Emitted Color
Peak. Wavelength
λp(nm) TYP.
Lens Appearance
3YT5V-F
Material
YELLOW
590nm
Part Number Designation
3 X X 5V - X
LED Body, mm
Emitted Color
Lens Appearance
Lead Frame & Body Style
i.e. -F, -S
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision B 06/15
Page 1 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
TURQUOISE,
BLUE,
GREEN,
YELLOW,
AMBER,
Low
Ultra
Low
5V
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Bright
YELLOW,
5V
Outline Dimensions
Flanged “3XX5V-F” LED
Shouldered Lead “3XX5V-S” LED
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision B 06/15
Page 2 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
TURQUOISE,
BLUE,
GREEN,
YELLOW,
AMBER,
Low
Ultra
Low
5V
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Bright
YELLOW,
5V
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
/ mW
Forward Current ( DC )
8 mA
Peak Forward Current 1
12 mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb )
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & Vf = 5V unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MIN
TYP
MAX
MIN
TYP
MAX
TYP
40
3YT5V-F
40
3YC5V-S
40
30
40
30
3YC5V-F
3YD5V-F
3YD5V-S
5.0
5.0
100
100
3YT5V-S
Notes: 1. Tolerance of forward voltage : ±0.05V.
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision B 06/15
Page 3 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
TURQUOISE,
BLUE,
GREEN,
YELLOW,
AMBER,
Low
Ultra
Low
5V
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Bright
YELLOW,
5V
Typical Electrical / Optical Characteristics
0°
10°
20°
30°
Iv
1.0
40°
20°
30°
35°
50°
40°
0.5
60°
70°
80°
0.0
500
λ(nm)
550
600
650
90°
700
0.5
Fig. 1 Relative Luminous Intensity vs. Wavelength
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
Iv
3.0
2.0
1.0
0.0
T (°C)
-40
80
Fig. 3 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision B 06/15
Page 4 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
TURQUOISE,
BLUE,
GREEN,
YELLOW,
AMBER,
Low
Ultra
Low
5V
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Bright
YELLOW,
5V
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
Anti-Static Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 Web:
E-mail:
bivar@bivar.com Web: www.bivar.com
Phone: (949)
www.bivar.com
Rev. A 01/16/08
Revision
B 06/15
Page
Page 4
5 of
of 4
5
