REV.
DESCRIPTION
A Engineering Release
B Added R/Y & A/G LED Specs
C Added LED Specs
DATE
APPROVED
01/15/09
05/06/10
02/10/15
T. Y.
T. Y.
J. C.
0.177 [4.5mm]
1.00 [25.4mm]
MIN.
0.04 [1.0mm]
MIN.
N-Flange Dia.
0.100 [2.5mm]
0.020 [0.5mm] SQ.
MIN.
Shouldered Lead
"3BCC-XX" LED
Recommended Mounting
+.003
-.002
0.209 [5.3mm]
Flat Edge ID
1.00 [25.4mm]
MIN.
0.04 [1.0mm]
Flange Dia.
MIN.
0.100 [2.5mm]
0.020 [0.5mm] SQ.
MIN.
Flanged "3BCC-XX-F"LED
0.032 [0.8mm]
SHORT
LEAD
CATHODE
PART NO.
LONG
LEAD
CATHODE
RED
3BCC-X
GREEN
YELLOW
3BCC-Y/G-X
GREEN
RED
3BCC-R/Y-X
YELLOW
AMBER
3BCC-A/G-X
GREEN
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
REVERSE VOLTAGE
5V
REVERSE CURRENT
100uA
ANGULAR
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
T1 (3mm) BI-COLOR LED
OPERATING TEMPERATURE RANGE
DESIGNED:
STORAGE TEMPERATURE
Raffy Paje
CHECKED:
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
FAX: (949) 951-3974
TITLE:
F. Jensen
DATE:
01/15/09
DATE:
01/15/09
PART NO:
REVISION:
3BCC-XX-X
CAGE CODE : 32559
C
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
SEE SHEET #1
STANDARD TOLERANCE
DECIMALS
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
Raffy Paje
CHECKED:
F. Jensen
DATE:
01/15/09
DATE:
01/15/09
PART NO:
REVISION:
3BCC-XX-X
CAGE CODE : 32559
C
SHEET # 2 OF 2
很抱歉,暂时无法提供与“3BCC-A/G”相匹配的价格&库存,您可以联系我们找货
