3mm
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER
3AX-X
Industry Standard 3mm (T1) Package
RoHS Compliant
Water Clear (C), Diffused (D), and Tinted (T) Lenses
Available in Flange (F) and Shouldered (S) Lead Frame
styles
Ideal for Status Indication and Display
Bivar 3mm T1 Package LED may be used in almost any application. Bivar offers water clear LED lens
for maximum light output, diffused LED lens for uniform light output, and tinted lens to identify the color
of the LED. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies. The Shouldered Lead
frame LED is ideal for vertical spacer assemblies without lead bends and also has a built in strain relief
feature which is ideal for right angle holder assemblies that require lead bends.
Part Number
Viewing Angle
3AC-F
Water Clear
20°
3AD-F
Amber Diffused
35°
Amber Tinted
20°
Water Clear
30°
3AD-S
Amber Diffused
40°
3AT-S
Amber Tinted
30°
3AC-S
GaAsP/Gap
Emitted Color
Peak. Wavelength
λp(nm) TYP.
Lens Appearance
3AT-F
Material
AMBER
605nm
Part Number Designation
3 X X - X
LED Body, mm
Emitted Color
Lead Frame & Body Style
i.e. -F or -S
Lens Appearance
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision C 06/15
Page 1 of 5
3mm
(T1) Package
Package Discrete
Discrete LED
LEDs
3mm (T1)
AMBER
AMBER
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision C 06/15
Page 2 of 5
3mm
(T1) Package
Package Discrete
Discrete LED
LEDs
3mm (T1)
AMBER
AMBER
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
80 mW
Forward Current ( DC )
30 mA
Peak Forward Current 1
150 mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MIN TYP MAX MIN TYP MAX
MAX
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MIN
TYP
MAX
MIN
TYP
MAX
TYP
40
35
3AT-F
40
3AC-S
40
30
25
40
40
30
3AC-F
3AD-F
3AD-S
2.0
2.0
2.8
2.8
100
3AT-S
Notes: 1. Tolerance of forward voltage : ±0.05V.
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision C 06/15
Page 3 of 5
3mm
(T1) Package
Package Discrete
Discrete LED
LEDs
3mm (T1)
AMBER
AMBER
Typical Electrical / Optical Characteristics
0°
10°
20°
30°
Iv
1.0
40°
20°
30°
35°
50°
40°
0.5
60°
70°
80°
0.0
550
λ(nm)
600
650
700
750
90°
0.5
Fig. 1 Relative Luminous Intensity vs. Wavelength
@ 20mA
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
If (mA)
Iv
1000
3.0
100
2.0
10
1.0
1
0.1
1.0
2.0
3.0
4.0
5.0
Vf (V)
0.0
1
10
100
1000
If (mA)
Fig. 4 Relative
Luminous Intensity vs. Forward
Fig. 3 Forward Current vs. Forward Voltage
Vf (V)
Iv
1.2
3.0
1.1
2.0
1.0
1.0
0.9
0.8
-40
T (°C)
80
Fig. 5 Forward Voltage vs. Temperature
0.0
T (°C)
-40
80
Fig. 6 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision C 06/15
Page 4 of 5
3mm
(T1) Package
Package Discrete
Discrete LED
LEDs
3mm (T1)
AMBER
AMBER
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
Anti Static Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 Web:
E-mail:
bivar@bivar.com Web: www.bivar.com
Phone: (949)
www.bivar.com
Rev. A C
01/16/08
Revision
06/15
Page
Page 4
5 of
of 4
5
很抱歉,暂时无法提供与“3AC”相匹配的价格&库存,您可以联系我们找货
