CMD11505UR
CMD11505UR
    VCC
    SMD2
    LED RED DIFFUSED 2SMD R/A
CMD11505UR 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 CMD11505 Series Bright★Angle™ Right Angle Surface Mount LED Description and Features All dimensions in mm. LE D C HIP 2.10 0.60 0.10 1.70 0.10 P LAS T IC S UB S T R AT E 1.00 0.50 0.30 0.30 • Available in Red, Orange, Yellow, Green and Pure Green. • Right angle mounting. • Compact size: 2.10mm x 1.00mm x 0.60mm Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Packaged 4000 pieces per reel. Leading Edge LED Optoelectronic Performance • Consistent high brightness. ANODE C AT HODE P IN C ONNE C T ION MAR K Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. • Refer to “Solder Pad Geometry 3.pdf” Electro-Optical Characteristics and Ratings P AR T NUMB E R Output C olor Diffused/Non-Diffused P ackage C olor P ower Dissipation (mW) P eak F orward C urrent Max. (mA) R everse V oltage (IR =100µA) (V ) Operating T emperature (°C ) S torage T emperature (°C ) F orward Voltage Typ. (IF =20mA) F orward Voltage Max. (IF =20mA) Viewing Angle (degrees) Luminous Intensity Min. (IF=20mA) Luminous Intensity Typ. (IF=20mA) P eak Wavelength (IF =20mA) R ated C urrent (mA) Lead S older T ime @ 260°C (seconds) C MD11505P G G reen Diffused C lear 70 60 4 -30 to +85 -40 to +100 2.1 2.8 130 3.8 6.4 560 20 5 C MD11505P Y Y ellow Diffused C lear 70 60 4 -30 to +85 -40 to +100 2.1 2.8 130 7.0 11.7 570 20 5 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. C MD11505UR R ed Diffused C lear 57.5 60 4 -30 to +85 -40 to +100 1.7 2.3 130 7.0 11.7 660 20 5
CMD11505UR 价格&库存
很抱歉,暂时无法提供与“CMD11505UR”相匹配的价格&库存,您可以联系我们找货
