1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat6 Gigabit Snagless Molded (UTP) Ethernet
Cable (RJ45 M/M), PoE, Purple, 6 ft. (1.83 m)
MODEL NUMBER: N201-006-PU
Highlights
Rated for 550 MHz/1 Gbps
communications
Snagless RJ45 connectors
protect against broken tabs
Meets Cat6 TIA/EIA standards
High-quality 24 AWG stranded
copper wire
Reduces impedance and
structural return loss
System Requirements
For 1000 Base-T (1Gbps
Ethernet), 10/100 Base-T
(Ethernet), 100 Mbps TPDDI, 155
Mbps ATM, ISDN, voice and Token
Ring TYPE 3 applications, as well
as EIA/TIA applications.
Connects critical components, such as computers, network adapters, routers, servers, modems, hubs and
switches, in Gigabit Ethernet networks. Recommended for distributing data, voice and video in highdensity data centers.
Features
Perfect Solution for Your Cat6 Gigabit Ethernet Networking Needs
● Ideal for connecting computers, network adapters, routers, servers, modems, hubs and switches in
high-density data centers
Designed for 10/100/1000 Base-T, 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice, Token Ring Type 3
and EIA/TIA applications
Ensures peak performance throughout your LAN
Rated for 550 MHz/1 Gbps communications
Reduces impedance and structural return loss compared to standard 100 MHz wire
Snagless RJ45 Male Connectors
● Molded snagless boots prevent locking tabs from damage during installation
Premium Construction for Superior Performance
● High-quality 24 AWG 4-pair stranded copper wire
Minimal near-end crosstalk ensures a strong signal
Integral strain relief protects cable and connectors from stress and cracking
Rugged PVC jacket stands up to long-term use
Meets Top Cabling Standards
● Meets Cat6 TIA/EIA standards
Meets most other current industry standards, including IEEE 802.3ab, 802.5, ISO/IEC 11801 and ETL
(Cat6 draft 11)
1/3
Package Includes
N201-006-PU Cat6 Gigabit
Snagless Molded UTP Patch
Cable (RJ45 M/M), Purple, 6 ft.
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332202673
Technology
Cat6
PHYSICAL
Cable Jacket Color
Purple
Cable Jacket Material
PVC
Cable Jacket Rating
CM
Cable Shielding
UTP
Cable Outer Diameter (OD)
6.0 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
24 AWG
Cable Length (ft.)
6
Cable Length (m)
1.83
Cable Length (in.)
72
Cable Length (cm)
182.9
Shipping Dimensions (hwd / in.)
0.50 x 7.00 x 9.00
Shipping Dimensions (hwd / cm)
1.27 x 17.78 x 22.86
Shipping Weight (lbs.)
0.30
Shipping Weight (kg)
0.14
ENVIRONMENTAL
Operating Temperature Range
14 to 122 F (-10 to 50 C)
Storage Temperature Range
5 to 140 F (-15 to 60 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
250 MHz
Maximum Bandwidth as Tested
500 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3an; 802.3at
CONNECTIONS
2/3
Cleveland, OH 44122
United States
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Contact Plating
Gold
PoE Type
Type 2 PoE+ (30W, IEEE 802.3at)
Connector Type
Snagless; Molded
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
Snagless Connector
Yes
Antibacterial
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3an 10GBase-T; IEEE 802.3at PoE+; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N201-006-PU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+16.994781+2.05443
- 10+16.9630710+2.05060
- 25+16.8181125+2.03308
- 50+16.8033950+2.03130
- 100+16.53613100+1.99899
- 250+12.14812250+1.46854
- 500+11.93128500+1.44233
- 1000+11.526631000+1.39341
- 2500+11.351622500+1.37225
