1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat5e 350 MHz Molded Shielded (STP) Ethernet
Cable (RJ45 M/M), PoE, Blue, 15 ft. (4.57 m)
MODEL NUMBER: N105-015-BL
Highlights
Rated for 350 MHz/1 Gbps
communications
Molded RJ45 male connectors
with gold-plated contacts
Protects Ethernet networks
against EMI/RFI line noise
4-pair 24 AWG stranded STP
with drain wire
TIA/EIA and UL certified
Package Includes
Connects network components like printers, computers, copiers, routers, servers, modems, hubs, patch
panels and switches. Recommended for high-density data centers and fast Ethernet networks.
Description
The N105-015-BL Cat5e 350 MHz Molded Shielded STP Patch Cable is recommended for connecting
network components like printers, computers, copiers, routers, servers, modems, hubs, patch panels and
switches in high-density data centers. Designed for fast transmission and excellent signal quality, this 15ft. (4.57 m) blue cable ensures peak performance throughout your local area network (LAN). EMI/RFI
shielding protects your Ethernet network from disruptive line noise.
Manufactured from 24 AWG copper wire and a durable PVC jacket, the four-pair stranded STP N105-015BL delivers speeds up to 350 MHz/1 Gbps. Molded RJ45 male connectors with gold-plated contacts
guarantee an accurate signal transfer. Integral strain relief ensures the cable and connectors last a long
time. Certified to TIA/EIA-568B and UL standards.
Features
Recommended Solution for Your Networking Needs
● Ideal for connecting components like printers, computers, copiers, routers, servers, modems and
Ensures peak performance throughout your LAN
EMI/RFI shielding protects network from disruptive line noise
Delivers speeds up to 350 MHz/1 Gbps
Premium Construction for Superior Performance
● Made from 24 AWG copper wire
PVC 4-pair stranded STP with drain wire
Integral strain relief for long life
1/3
Cable (RJ45 M/M), Blue, 15-ft.
(4.57 m)
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332148254
Technology
Cat5/5e
POWER
Power Over Cable (PoC) Support
No
PHYSICAL
Cable Jacket Color
Blue
Cable Jacket Material
PVC
Cable Jacket Rating
CM
Cable Shielding
STP
Cable Outer Diameter (OD)
5.9 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
24 AWG
Cable Length (ft.)
15
Cable Length (m)
4.57
Cable Length (in.)
180
Cable Length (cm)
457.2
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.43
Shipping Weight (kg)
0.20
ENVIRONMENTAL
Operating Temperature Range
14 to 104 F (-10 to 40 C)
Storage Temperature Range
5 to 122 F (-15 to 50 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
100 MHz
Maximum Bandwidth as Tested
350 MHz
Network Compatibility
1 Gbps (Gigabit)
2/3
Cleveland, OH 44122
United States
IEEE Standards Supported
802.3ab; 802.3at
CONNECTIONS
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Contact Plating
Gold
PoE Type
Type 2 PoE+ (30W, IEEE 802.3at)
Connector Type
Molded
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
Snagless Connector
No
Antibacterial
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3at PoE+; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N105-015-BL”相匹配的价格&库存,您可以联系我们找货
