1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat5e 350 MHz Snagless Molded (UTP) Ethernet
Cable (RJ45 M/M), PoE - Purple, 25 ft. (7.62 m)
MODEL NUMBER: N001-025-PU
Highlights
Premium cabling for Cat5/5e
applications
Rated for 350 MHz/1 Gbps
communications
Snagless RJ45 male connectors
26 AWG 4-pair stranded UTP
with PVC jacket
Color-coded purple for easy
identification
System Requirements
For 1000Base-T (1Gbps
Ethernet), 10/100Base-T
(Ethernet), 100 Mbps TPDDI,
155 Mbps ATM, ISDN, voice
and Token Ring Type3
applications
Package Includes
Color-coded Cat5e cable connects high-speed network components like computers, servers, printers,
copiers, routers and switches in a home or office Cat5/5e application. Ideal for high-density data centers.
Description
The N001-025-PU Cat5e 350 MHz Snagless Molded UTP Patch Cable (M/M) is recommended for
connecting high-speed network components, such as computers, servers, printers, copiers, routers and
switches, in high-density data centers. Designed for fast transmission and excellent signal quality, this 25ft. (7.62 m) purple cable ensures peak performance throughout your Cat5/5e network.
Manufactured from 26 AWG copper wire that cuts down on interference, the four-pair stranded UTP N001025-PU delivers speeds up to 350 MHz/1 Gbps. Near-end crosstalk levels are kept to a minimum. The
RJ45 male connectors' snagless design protects the locking tabs from being damaged or broken off
during installation. Integral strain relief with ridges on each end gives the cable extra flexibility, reduces
stress, and helps the cable and connectors move freely without cracking.
Wrapped in a durable PVC jacket that resists corrosion, the N001-025-PU is designed for 1000Base-T (1
Gbps Ethernet), 10/100Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token
Ring Type 3 applications. It meets most current industry standards, including IEEE 802.3ab, IEEE 802.5,
ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (Cat5e draft 11).
Features
An Ideal Solution for High-Speed Cat5/5e Networking
● Connects high-speed network components, such as computers, servers, printers, copiers, routers and
switches
Designed for 1000Base-T, 10/100Base-T, 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token
Provides high-speed connections up to 350 MHz/1 Gbps
Flawless signal delivery with minimal near-end crosstalk levels
Snagless RJ45 Male Connectors
● Molded snagless boots prevent locking tabs from damage during installation
Connectors and cable color-coded purple for easy ID in crowded applications
Premium Construction Ensures Excellent Performance
● Manufactured from 26 AWG 4-pair stranded UTP
1/3
Cable (RJ45 M/M), Purple, 25-ft.
(7.62 m)
Cleveland, OH 44122
United States
Gold-plated copper contacts for accurate signal transfer
Molded integral strain relief for long life
Durable corrosion-resistant PVC jacket
Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568,
Specifications
OVERVIEW
UPC Code
037332202642
Technology
Cat5/5e
POWER
Power Over Cable (PoC) Support
No
PHYSICAL
Cable Jacket Color
Purple
Cable Jacket Material
PVC
Cable Jacket Rating
CM
Cable Shielding
UTP
Cable Outer Diameter (OD)
5.0 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
26 AWG
Cable Length (ft.)
25
Cable Length (m)
7.62
Cable Length (in.)
300
Cable Length (cm)
762
Shipping Dimensions (hwd / in.)
0.50 x 8.00 x 10.00
Shipping Dimensions (hwd / cm)
1.27 x 20.32 x 25.40
Shipping Weight (lbs.)
0.70
Shipping Weight (kg)
0.32
ENVIRONMENTAL
Operating Temperature Range
14 to 104 F (-10 to 40 C)
Storage Temperature Range
5 to 122 F (-15 to 50 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
2/3
Cleveland, OH 44122
United States
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
100 MHz
Maximum Bandwidth as Tested
350 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3ab; 802.3at
CONNECTIONS
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Contact Plating
Gold
PoE Type
Type 2 PoE+ (30W, IEEE 802.3at)
Connector Type
Molded; Snagless
Wiring Configuration
EIA/TIA 568B
Angled Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
Snagless Connector
No
Antibacterial
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3at PoE+; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
