EZA-035
EZA-035
    TRIPPLITE
    DISPLAY CABLE TYPE A PVC TRUNK
EZA-035 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Easy Pull Long-Run Display Cable - Type-A Analog PVC Trunk Cable, 35 ft. (10.67 m) MODEL NUMBER: EZA-035 Highlights ● Versatile trunk cable allows for a variety of connection options ● At a diameter of 7/8 in., it easily pulls through conduit or confined spaces using the included end cap with integrated pull tab ● High quality RGB style VGA cable supports resolutions up to 1600 x 1200, as well as Audio pass through Package Includes ● Features ● Eliminates the need to field terminate VGA connectors ● Detachable, screw-on connector with pull tab (7/8 in. diameter) makes it easy to pull through tight spaces, and helps protect the cable from strain, dirt, debris and damage when doing so ● Allows cable to be run according to code - inside conduit, drop ceilings, etc. ● Available in both PVC and Plenum versions ● Comes in 35 ft., 50 ft. and 100 ft. lengths ● Supports Video and Audio pass through depending on end kit used ● Choose from a variety of connector combinations for the perfect fit Specifications OVERVIEW UPC Code 037332141903 Product Type Passive Technology VGA/SVGA PHYSICAL Color Black; Green Cable Jacket Color Black; Green Cable Length (ft.) 35 Cable Length (m) 10.67 Shipping Dimensions (hwd / in.) 1.70 x 6.70 x 6.90 1/2 Easy Pull Type-A VGA Analog PVC Trunk Cable, 35 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 4.32 x 17.02 x 17.53 Shipping Weight (lbs.) 1.70 Shipping Weight (kg) 0.77 CONNECTIONS Side A - Connector 1 DIN 14 PIN (FEMALE) Side B - Connector 1 DIN 14 PIN (FEMALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
EZA-035 价格&库存
很抱歉,暂时无法提供与“EZA-035”相匹配的价格&库存,您可以联系我们找货
