1000 Eaton Boulevard
Cleveland, OH 44122
United States
PDU Power Cord, C13 to C14 - 10A, 250V, 18
AWG, 2 ft. (0.61 m), White
MODEL NUMBER: P004-002-AWH
Highlights
Recommended for powering
computers, printers and other
essential peripherals
Adds 2-ft. (0.61 m) to your
existing connection to provide
more flexibility in placing
devices
C13-to-C14 PDU-style
extension cord is ideal
replacement for worn-out or
missing cable
Color-coded white for fast, easy
identification in a crowded rack
or workstation
Applications
Connect devices like computers,
servers and monitors to a PDU
up to 2-ft. (0.61 m) away in your
data center
Extend an existing power
connection up to 2-ft. (0.61 m) to
more easily place a device or
reach a power source near your
workstation
Provide a high-quality
replacement for a worn-out or
missing power cord
Computer power extension cord connects 2 devices with C13/C14 power connectors or extends your
existing power connection by 2 ft.
Features
C14-to-C13 Power Cable Connects Computers, Printers, Servers and Other EquipmentThis IEC320-C14 to IEC-320-C13 cable is designed for small data center, office workstation and other lower-amp
applications. This C14 male to C13 female cord can be used to power a computer, server or monitor;
attach a server or drive to a UPS system or PDU; or extend an existing connection up to 2-ft. (0.61 m).
The 2-ft. (0.61 m) length helps reduce cable clutter and minimize the risk of tripping.
Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis computer power
extension cord features a white SJT jacket and fully molded white ends. The color-coding allows easy,
fast identification in a crowded rack or workstation and helps prevent the cable from becoming
inadvertently disconnected.
Specifications
OVERVIEW
UPC Code
037332198884
Device Compatibility
Computer; Monitor/HDTV; Printer; Server; UPS; PDU
Country/Region
Global
INPUT
Maximum Input Amps
10
Voltage Compatibility (VAC)
100-250
PHYSICAL
1/3
Package Includes
P004-002-AWH C14 Male to
C13 Female Power Cable, 2-ft.
(0.61 m), White
Cleveland, OH 44122
United States
Plug Color
White
Cable Jacket Color
White
Cable Jacket Material
PVC
Cable Jacket Rating
FT2
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
7.7mm
Number of Conductors
3
Wire Gauge (AWG)
18
Wire Gauge (OD - mm²)
0.82
Cable Length (ft.)
2
Cable Length (m)
0.61
Cable Length (cm)
60.96
Shipping Dimensions (hwd / in.)
0.50 x 7.50 x 8.40
Shipping Dimensions (hwd / cm)
1.27 x 19.05 x 21.34
Shipping Weight (lbs.)
0.40
Shipping Weight (kg)
0.18
ENVIRONMENTAL
Operating Temperature Range
-4 TO 140 F (- 20° TO 60°C)
Storage Temperature Range
Operating Humidity Range
20-80% RH
Storage Humidity Range
20-80% RH
CONNECTIONS
Side A - Connector 1
IEC-320-C14
Side B - Connector 1
IEC-320-C13
FEATURES & SPECIFICATIONS
High Voltage
Yes
Locking Plug
No
Antibacterial
No
Angled Plug
No
Coiled Power Cord
No
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); cUL Listed; UL Listed
Product Compliance
RoHS; REACH
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P004-002-AWH”相匹配的价格&库存,您可以联系我们找货
