1000 Eaton Boulevard
Cleveland, OH 44122
United States
Heavy-Duty PDU Power Cord, C13 to C14 - 15A,
250V, 14 AWG, 3 ft. (0.91 m), Orange
MODEL NUMBER: P005-003-AOR
Highlights
Recommended for powering
computers, servers and other
network devices
3-ft. (0.91 m) length allows
flexibility in placing devices,
while avoiding cable clutter
PDU-style cord replaces or
upgrades standard power cord
provided by manufacturer
Color-coded orange for fast,
easy identification in a crowded
rack or workstation
Thick 14 AWG wire gauge
manages high power levels
required for larger equipment
Applications
Computer power extension cord connects devices with C13/C14 power connectors or extends your
existing power connection by 3 ft.
Features
C14-to-C13 Power Cable for Network Devices That Require a Heavy-Gauge ConnectionThis IEC320-C14 to IEC-320-C13 cable features 14 AWG wire suitable for high power connections, making it a
reliable solution for large server applications that require a higher-rated, heavier-gauge cable. This C14
male to C13 female cord can be used to connect a computer, server, monitor or drive to a UPS system or
PDU or replace or upgrade the standard power cord provided by the device’s manufacturer. The threefoot length helps reduce cable clutter and minimize the risk of tripping.
Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis computer power
extension cord features an orange SJT jacket and fully molded orange ends. The color-coding allows
easy, fast identification in a crowded rack or workstation and helps prevent the cable from becoming
inadvertently disconnected.
Specifications
OVERVIEW
UPC Code
037332198990
Device Compatibility
Computer; Monitor/HDTV; Printer; Server; Router; Network Switch; UPS; PDU
Country/Region
Global
INPUT
Maximum Input Amps
15
Voltage Compatibility (VAC)
100-250
PHYSICAL
1/3
Connect devices like computers,
servers and monitors to a PDU
up to 3 ft. away in your data
center
Extend an existing power
connection up to 3 ft. to more
easily place a device or reach a
power source in a rack
Update or replace the standard
power cord provided by a
device’s original manufacturer
Package Includes
P005-003-AOR Heavy-Duty C13
to C14 PDU-Style Power
Extension Cable, 3 ft., Orange
Cleveland, OH 44122
United States
Plug Color
Orange
Cable Jacket Color
Orange
Cable Jacket Material
PVC
Cable Jacket Rating
FT2
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
9.2mm
Number of Conductors
3
Wire Gauge (AWG)
14
Wire Gauge (OD - mm²)
2.08
Cable Length (ft.)
3
Cable Length (m)
0.91
Cable Length (cm)
91.44
Shipping Dimensions (hwd / in.)
9.90 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
25.15 x 17.78 x 1.27
Shipping Weight (lbs.)
0.44
Shipping Weight (kg)
0.20
ENVIRONMENTAL
Operating Temperature Range
-4 TO 140 F (- 20° TO 60°C)
Storage Temperature Range
Operating Humidity Range
20-80% RH
Storage Humidity Range
20-80% RH
CONNECTIONS
Side A - Connector 1
IEC-320-C14
Side B - Connector 1
IEC-320-C13
FEATURES & SPECIFICATIONS
High Voltage
Yes
Locking Plug
No
Antibacterial
No
Angled Plug
No
Coiled Power Cord
No
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); cUL Listed; UL Listed
Product Compliance
RoHS; REACH
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P005-003-AOR”相匹配的价格&库存,您可以联系我们找货
