1000 Eaton Boulevard
Cleveland, OH 44122
United States
PDU Power Cord, C13 to C14 - 10A, 250V, 18
AWG, 6 ft. (1.83 m), Blue
MODEL NUMBER: P004-006-ABL
Highlights
Recommended for powering
computers, printers and other
essential peripherals
Adds 6-ft. (1.83 m) to your
existing connection to provide
more flexibility in placing
devices
C13-to-C14 PDU-style
extension cord is ideal
replacement for worn-out or
missing cable
Color-coded blue for fast, easy
identification in a crowded rack
or workstation
Applications
Connect devices like computers,
servers and monitors to a PDU
up to 6-ft. (1.83 m) away in your
data center
Extend an existing power
connection up to 6-ft. (1.83 m) to
more easily place a device or
reach a power source away
from your workstation
Provide a high-quality
replacement for a worn-out or
missing power cord
Computer power extension cord connects 2 devices with C13/C14 power connectors or extends your
existing power connection by 6 ft.
Features
C14-to-C13 Power Cable Connects Computers, Printers, Servers and Other EquipmentThis IEC320-C14 to IEC-320-C13 cable is designed for small data center, office workstation and other lower-amp
applications. This C14 male to C13 female cord can be used to power a computer, server or monitor;
attach a server or drive to a UPS system or PDU; or extend an existing connection up to 6-ft. (1.83 m).
The 6-ft. (1.83 m) length allows you flexibility in placing equipment with respect to the power outlet.
Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis computer power
extension cord features a blue SJT jacket and fully molded blue ends. The color-coding allows easy, fast
identification in a crowded rack or workstation and helps prevent the cable from becoming inadvertently
disconnected.
Specifications
OVERVIEW
UPC Code
037332198891
Device Compatibility
Computer; Monitor/HDTV; Printer; Server; UPS; PDU
Country/Region
Global
INPUT
Maximum Input Amps
10
Voltage Compatibility (VAC)
100-250
PHYSICAL
1/3
Package Includes
P004-006-ABL C14 Male to C13
Female Power Cable, 6-ft. (1.83
m), Blue
Cleveland, OH 44122
United States
Plug Color
Blue
Cable Jacket Color
Blue
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
7.8mm
Number of Conductors
3
Wire Gauge (AWG)
18
Wire Gauge (OD - mm²)
0.82
Cable Length (ft.)
6
Cable Length (m)
1.83
Cable Length (cm)
182.88
Shipping Dimensions (hwd / in.)
9.90 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
25.15 x 17.78 x 1.27
Shipping Weight (lbs.)
0.51
Shipping Weight (kg)
0.23
ENVIRONMENTAL
Operating Temperature Range
-4 F TO 140 F (-20 C TO 60 C)
Storage Temperature Range
Operating Humidity Range
10 TO 65% RH
Storage Humidity Range
10 TO 65% RH
CONNECTIONS
Side A - Connector 1
IEC-320-C14
Side B - Connector 1
IEC-320-C13
FEATURES & SPECIFICATIONS
High Voltage
Yes
Locking Plug
No
Antibacterial
No
Angled Plug
No
Coiled Power Cord
No
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); cUL Listed; UL Listed
Product Compliance
RoHS; REACH
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P004-006-ABL”相匹配的价格&库存,您可以联系我们找货
