1000 Eaton Boulevard
Cleveland, OH 44122
United States
Slim High-Speed HDMI Cable with Ethernet and
Digital Video with Audio, UHD 4K (M/M), 6 ft.
(1.83 m)
Highlights
Supports UHD video resolutions
up to 4K
Easy to install around corners
and through management
panels
Premium foil and braid shielding
protects against EMI/RFI noise
Gold-plated connectors and
contacts for optimal signal
transfer
MODEL NUMBER: P569-006-SLIM
Package Includes
Transmits digital audio/video and Ethernet signals from an HDMI source to a 4K-enabled television,
projector or monitor. Recommended for home theater systems and digital signage. Slim design increases
airflow in tight spaces.
Features
Connects HDMI Source to 4K TV, Projector or Monitor
● Ideal for home theater systems, digital signage and other applications that display UHD video and multichannel audio
High Performance and Wide Compatibility
● Supports UHD video resolutions up to 4K, and 3D
Audio return channel simplifies setup between display and receiver
Supports iPad2 video mirroring when used with Apple digital A/V adapter
Backward compatible with previous HDMI generations
Works in all HDMI cabling scenarios
Special Slim Design
● Improved airflow in tight spaces
Better flexibility for installing around corners and through cable management panels
Superior Construction Ensures a Flawless Signal
● Fully molded 36 AWG construction with integral strain relief for durability and long life
Premium foil and braid shielding for EMI/RFI noise protection
Corrosion-resistant gold-plated connectors and contacts for optimal signal transfer
Flexible PVC jacket easy to install in tight spaces
1/4
P569-006-SLIM Slim HighSpeed HDMI Cable with
Ethernet and Digital Video with
Audio (M/M), 6 ft.
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332199362
Product Type
Passive
Technology
HDMI
VIDEO
Max Supported Video Resolution
3840 x 2160 @ 30Hz
Max Supported Color Depth
24-bit True Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
EDID Support
Yes
Signal Transmission
Bidirectional
AUDIO
Audio Specification
Stereo Audio
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PHYSICAL
Color
Black
Cable Jacket Color
Black
Connector Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
3.6mm
Wire Gauge (AWG)
34
Cable Length (ft.)
3
Cable Length (m)
0.91
Ferrite Core
No
Minimum Bend Radius
36mm
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.08
2/4
Cleveland, OH 44122
United States
Shipping Weight (kg)
0.04
ENVIRONMENTAL
Operating Temperature Range
32 TO 113 F (0 TO 45 C)
Storage Temperature Range
-40 - 80 °C (-40 - 176 °F)
Operating Humidity Range
10 to 85% RH, Non-Condensing
Storage Humidity Range
5 to 90% RH, Non-Condensing
COMMUNICATIONS
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Side A - Connector 1
HDMI (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
EMI/RFI Line Noise Protection
No
MST Support
No
IP68 Rated
No
Antibacterial
No
Armored Cable
No
Ethernet Support
Yes
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
3/4
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“P569-006-SLIM”相匹配的价格&库存,您可以联系我们找货
