1000 Eaton Boulevard
Cleveland, OH 44122
United States
24-Port 1U Rack-Mount 110-Type Color-Coded
Patch Panel, RJ45 Ethernet, 568B, Cat6
MODEL NUMBER: N253-024-RBGY
Highlights
4 color-coded banks for
convenient zone cabling
Color-coded rear 110
connections for EIA/TIA 568A/B
wiring
Supports 22 to 26 AWG
stranded and solid wire
Ports numbered front and rear
for easy ID of cable runs
Mounts into 1U of EIA-standard
19 in. rack
Package Includes
Manages and organizes up to 24 input and output Cat6 network cable connections in just 1U of an EIAstandard 19 in. rack. Recommended for Ethernet, Fast Ethernet and Gigabit Ethernet network
applications.
Description
The UL-approved N253-024-RBGY 24-Port 1U Rack-Mount 110-Type Color-Coded Patch Panel manages
and organizes up to 24 input and output UTP Cat6 network cable connections in just 1U of an EIAstandard 19 in. rack.
The 24 RJ45 ports are split into four banks of six ports each that are color-coded—red, blue, green and
yellow—for easily identifiable zones. Rear 110 connections are also color-coded for convenient EIA/TIA
568A/B wiring. All ports are numbered front and rear for quick identification of connections.
Recommended for Ethernet, Fast Ethernet and Gigabit Ethernet network applications, this durable metal
patch panel supports 22 to 26 AWG stranded and solid wire.
Features
Manages and Organizes 24 UTP Cat6 Network Connections
● Recommended for Ethernet, Fast Ethernet and Gigabit Ethernet network applications
Ports split into 4 color-coded banks of 6 ports each for convenient zone cabling
Color-coded 110 connections for EIA/TIA 568A/B wiring
Ports numbered front and rear for easy ID of cable runs
Supports 22 to 26 AWG stranded and solid wire
Reliable Construction and Easy Installation
● Mounts easily into 1U of EIA-standard 19 in. rack
UL-approved and RoHS-compliant
Durable metal construction
Meets or exceeds EIA/TIA TSB-40 Cat6 connecting hardware specifications
Specifications
1/2
Rack-Mount 110-Type ColorCoded Patch Panel
Mounting hardware
Quick Start Guide
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332197450
Product Type
Punchdown
Technology
Cat6
PHYSICAL
Color
Black
Shipping Dimensions (hwd / in.)
3.90 x 2.90 x 21.90
Shipping Dimensions (hwd / cm)
9.91 x 7.37 x 55.63
Shipping Weight (lbs.)
1.40
Shipping Weight (kg)
0.64
CONNECTIONS
Number of Ports
24
Side A - Connector 1
(24) 110 IDC
Side B - Connector 1
(24) RJ45 (FEMALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“N253-024-RBGY”相匹配的价格&库存,您可以联系我们找货
