1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat5e 350 MHz Bulk Stranded PVC Cable, Gray,
250 ft.
Highlights
MODEL NUMBER: N020-250-GY
System Requirements
Description
Tripp Lite's 250-ft. gray category 5e (Cat5e) stranded PVC bulk cable is best suited for patch (outside
wall) cabling applications. This 24 AWG 4-pair stranded UTP cable has a PVC jacket and is rated for
350MHz/1Gbps communication. Transition speed rating up to 100Mbps. Meets most current industry
standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e
draft 11). Tripp Lite warrants this product to be free from defects in materials and workmanship for life.
Features
Designed for patch (outside wall) cabling applications
Cabling for category 5 (Cat5) and 5e (Cat5e) applications
Length: 250-ft. Color: gray
24 AWG 4-pair stranded UTP cable with PVC jacket
Rated for 350MHz/ 1Gbps communication
Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568,
ISO/IEC 11801 and ETL (category 5e draft 11)
Available in other lengths
Available in solid copper cable (N022-01K-GY), in plenum cable (N024-01K) and in Cat6 (N222-01K
and N224-01K)
Warranted to be free from defects in materials and workmanship for life
OVERVIEW
037332013040
PHYSICAL
Color
Gray
Cable Shielding
UTP
Cable Length (ft.)
250
Cable Length (m)
76.22
Shipping Dimensions (hwd / in.)
4.75 x 7.75 x 7.75
Shipping Dimensions (hwd / cm)
12.06 x 19.68 x 19.68
Shipping Weight (lbs.)
6.61
Shipping Weight (kg)
3.00
CONNECTIONS
Side A - Connector 1
BARE WIRE
Side B - Connector 1
BARE WIRE
For making patch cables for
Network Installations 1000
Base-T (1Gbps Ethernet),
10/100 Base-T (Ethernet),
100Mbps TPDDI, 155 Mbps
ATM, ISDN, voice and Token
Ring Type 3 applications.
Package Includes
Specifications
UPC Code
Premium cabling for Category 5
and 5e applications — rated for
350 MHz/1Gbps
communications
1/2
250-ft. Cat5e Gray Bulk
Stranded PVC 24AWG 350MHz
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“N020-250-GY”相匹配的价格&库存,您可以联系我们找货
