1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat5e 350 MHz Bulk Solid PVC Cable, Gray, 500
ft.
Highlights
MODEL NUMBER: N022-500-GY
Premium cabling for Category 5
and 5e applications -- rated for
350 MHz/1Gbps
communications
System Requirements
For all non-Plenum horizontal
premise (in-wall) wiring
applications for Network
Installations 1000 Base-T
(1Gbps Ethernet), 10/100 BaseT (Ethernet), 100Mbps TPDDI,
155 Mbps ATM, ISDN, voice
and Token Ring Type 3
applications.
Package Includes
Description
Tripp Lite's 500-ft. gray category 5e (Cat5e) solid PVC bulk cable is designed for premise (in-wall) cabling
applications. This 24 AWG 4-pair solid cable has a PVC jacket and is rated for 350MHz/1Gbps
communication. Used for all non-plenum horizontal wiring applications. Meets most current industry
standards including IEEE 802.3AB, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC11801 and ETL (category 5e
draft 11). Tripp Lite warrants this product to be free from defects in materials and workmanship for life.
Features
Designed for premise (in-wall) cabling applications
Cabling for category 5 (Cat5) and 5e (Cat5e) applications
Length: 500-ft. Color: gray
24 AWG 4-pair solid cable with PVC jacket
Rated for 350MHz/ 1Gbps communication
Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568,
ISO/IEC 11801 and ETL (category 5e draft 11)
Available in other lengths
Available in stranded copper cable (N020-01K-GY), in plenum cable (N024-01K) and in Cat6 (N222-01K
and N224-01K)
Warranted to be free from defects in materials and workmanship for life
Specifications
OVERVIEW
UPC Code
037332013064
PHYSICAL
Color
Gray
1/2
500-ft. Cat5e Gray Bulk Patch
Cable Solid PVC 24AWG
350MHz
Cleveland, OH 44122
United States
Cable Shielding
UTP
Cable Length (ft.)
500
Cable Length (m)
152.44
Shipping Dimensions (hwd / in.)
7.00 x 11.25 x 11.50
Shipping Dimensions (hwd / cm)
17.78 x 28.58 x 29.21
Shipping Weight (lbs.)
12.46
Shipping Weight (kg)
5.65
CONNECTIONS
Side A - Connector 1
BARE WIRE
Side B - Connector 1
BARE WIRE
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“N022-500-GY”相匹配的价格&库存,您可以联系我们找货
