2475/28BR-1000
2475/28BR-1000
    DABURNELECTRONICS
    FEPHIVOLT#2818KV1000FTBR
2475/28BR-1000 数据手册
Daburn Electronics & Cable 44 Richboynton Road Dover, NJ 07801 #2475 FEP High Voltage Wire Fluorinated Ethylene Propylene (FEP) high voltage wire. This wire achieves high voltage protection due to the excellent dielectric properties of FEP and therefore has smaller diameters than other high voltage wires. FEP also has a high stress crack resistance and retains its toughness and flexibility even at higher temperatures up to 200°C. This wire is very resistant to chemicals including transformer oils. It has a low coefficient of friction, low flammability, negligible moisture absorption, and excellent resistance to ozone sunlight and weather. • High voltages - depending on AWG size up to 30 KV DC • High flexibility • Excellent resistance to chemicals • Small diameters • FEP Resins meet flammability requirements of UL94V-O This series is RoHS compliant. Description: Stranded silver plated soft copper conductors insulated with FEP. Operating Temperature: -65°C to +200°C Daburn Cat. No. AWG Nom. Wall Nom. O.D. IN MM IN MM KV DC Rating Stranding 2475/28 28 19/40 .0145” .368 .044” 1.118 18 2475/26 26 19/38 .0155" .394 .050" 1.270 20 2475/24 24 19/36 .013" .330 .050" 1.270 18 2475/22 22 19/34 .015" .381 .060" 1.524 20 2475/20A 20 19/32 .021" .533 .080" 2.032 25 2475/20B 20 19/32 .031" .787 .100" 2.540 30 2475/18 18 19/30 .041" 1.041 .130" 3.302 30 Standard Put-Ups: 1,000 feet, 500 feet, 250 feet. 100 feet if in stock only. Standard Colors: Clear or Natural, White, Black, Red, Green, Yellow, Blue, Brown, Orange, Gray, Violet. Tel: 973-328-3200 Fax: 973-328-3130 www.daburn.com Revision B
2475/28BR-1000 价格&库存
很抱歉,暂时无法提供与“2475/28BR-1000”相匹配的价格&库存,您可以联系我们找货
