RC Series
Stackpole Electronics, Inc.
Carbon Composition Resistor
Resistive Product Solutions
Features:
Non-inductive design
Molded body for package uniformity
Ideal for pulse-load handling characteristics
RoHS compliant, lead free and halogen free
Electrical Specifications
Type / Code
Maximum
Maximum
Dielectric Withstanding
Continuous
Pulse Voltage
Voltage (V)
(1)
(V)
Working Voltage (V)
0.25
250
400
500
0.5
350
700
700
or maximum working voltage.
Power Rating
(W) @ 70ºC
RC14
` RC12
(1) Lesser of √ P*R
Ohmic Range (Ω) and Tolerance
5%
2.2 - 91K
1 - 91K
10%
1 - 5.6M
1 - 22M
Mechanical Specifications
Type / Code
RC14
RC12
A
Body Length
0.248 ± 0.028
6.30 ± 0.70
0.374 ± 0.031
9.50 ± 0.80
B
Body Diameter
0.094 ± 0.004
2.40 ± 0.10
0.142 ± 0.008
3.60 ± 0.20
C
Lead Length (Bulk)
1.181 ± 0.118
30.00 ± 3.00
1.102 ± 0.118
28.00 ± 3.00
D
Lead Diameter
0.024 ± 0.002
0.60 ± 0.05
0.028 ± 0.003
0.70 ± 0.07
Unit
inches
mm
inches
mm
Performance Characteristics
Test
Test Results
Voltage Proof
No breakdown or flashover
Overload
Termination Strength
Solderability
Resistance to
Soldering Heat
Temperature Shock
Climatic Sequence
Damp Test, Steady State
Endurance @ 70ºC
±2% +0.05Ω
No visible damage, legible markings
Tensile: ±2% +0.05Ω. No visible damage
Bending: ±2% +0.05Ω. No visible damage
Torsion: ±2% +0.05Ω. No visible damage
In accordance with Clause 4.17.4.5
±3% +0.05Ω
±2% +0.05Ω
No visible damage.
±10% +0.5Ω
Insulation resistance: R ≥100M ohm.
±10% +0.5Ω
Insulation resistance: R ≥1G ohm.
No visible damage.
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
After immersion into flux, the immersion into solder shall be
carried out 4mm from the body at 350ºC for 3.5 seconds
5 cycles between -55ºC to 125ºC
Dry/Damp heat: 12 +12 hour cycle, first cycle
Cold/Damp heat: 12 + 12 hour cycle, remaining cycle D.C.
load
±10% +0.5Ω
Rev Date: 01/18/2019
Test Method
V-block method RC 1/4 100 VAC, 60 seconds
RC 1/2 500 VAC, 60 seconds
2.5 times the rated voltage or twice the limiting element
voltage, whichever is less. Severe, 5 seconds.
10N for 5 - 10 seconds
5N, twice
180ºC, two rotations
235ºC, 5 seconds
1
40ºC 95% relative humidity for 56 days,
test a, b and c of Clause 4.24.2.1
Rated voltage, 1.5 hours ON, 0.5 hours OFF at 70ºC,
1000 hours
www.seielect.com
marketing@seielect.com
RC Series
Performance Characteristics (cont.)
Test
Test Results
±10% +0.5Ω
Endurance @ 125ºC
No visible damage.
Operating Temperature Range: -55ºC to +125ºC
Power Derating Curve:
125ºC, no load, 1000 hours
-55ºC
100
Percent Rated Power (%)
Test Method
70ºC
80
60
40
125ºC
60
80
100
120
140
Ambient Temperature (ºC)
Reliability Test – Load Life in Moisture
Criteria (%)
∆ R/R
±5
±10
Load Ratio
P/Pn (%)
Total Testing
Time (Hrs)
Number of
Fractures (pcs)
ƛ
Failure Ratio
ƛCL (60%)
Average Lifetime
(60% reliability level) (Hrs)
2.984 x 106
6
0.201
0.244
4.098 x 105
2.990 x 106
4
0.134
0.176
5.682 x 105
60
6
2.997 x 10
2
0.067
0.104
9.615 x 105
100
2.992 x 106
3
0.1
0.139
7.194 x 105
Total
1.196 x 107
15
0.125
0.138
7.209 x 105
Total
1.2 x 107
0.0077
1.299 x 107
Resistance Temperature Characteristics
Resistance Range
Under 1K
1K to 9.1K
10K to 91K
100K
100K to 910K
1M to 10M
-55ºC
+2 to + 5
+5 to +9
+8 to +11
+10 to +14
+10 to +14
+13 to +20
+105ºC
-4 to -2
-5 to -3
-7 to -5
-9 to -7
-9 to -7
-14 to -9
2
Maximum % resistance change
from room temperature (+25ºC)
value
www.seielect.com
RC Series
Temperature Rise
Single Pulse Power Capability
3
www.seielect.com
RC Series
Continuous Pulse Circuit
100 Pulse Data
E: 10kV; C1: 1000pF; R1: 1KΩ; R2: 4MΩ; X: Sample: RS: 15MΩ; 100 times pulse.
Continuous Pulse Capability
4
www.seielect.com
RC Series
Impedance x Frequency
Equipment: HP4291A Impedance/Material Analyzer
5
www.seielect.com
RC Series
Current Noise
Current Noise Data (Q.T.L.)
Characteristic Data
Impressing Electric Power (W)
0.125
0.250
0.375
Surface Temperature (°C)
40.7
53.6
66.8
6
www.seielect.com
RC Series
Characteristic Data
0.25
0.50
0.75
52.3
68.5
85.6
Measurement Condition:
Technical Guide:
1. Storage Conditions:
Temperature:
5 to 35ºC (40 to 95ºF).
Humidity:
25 – 60% relative humidity.
Term:
One year in poly-bag with desiccant. If parts are removed from the poly-bag,
they should be used immediately or resealed in the bag.
Environment:
Clean, dry environment, free of corrosive gases.
2. Application precautions:
Lead forming:
Forming is recommended at least 2mm of farther from the base of the lead.
Soldering:
Soldering is recommended at least 4mm or farther from the base of the lead.
3. Washing:
Carbon composition resistors are highly hygroscopic and changes in resistance value can occur if too much
moisture is absorbed. For this reason, it is recommended not to use water or water-soluble solvents to clean these
components. Alcohol or hydrocarbon solvents are recommended for rinsing.
7
www.seielect.com
RC Series
4. Soldering Recommendations:
Note: The conditions shown below are for reference. Please perform a mounting evaluation to assure
compatibility.
a. Flow soldering (recommended profile for Sn and Sn/Pb solders).
b. Soldering iron (recommended for Sn and Sn/Pb solders):
Temperature of soldering tip:
300ºC, duration: 10 sec. max.
350ºC, duration: 3 sec. max.
Other:
1. Evaluate and confirm the compatibility of your assembly process with this product.
2. Refer to the catalog, the product news, and the specifications for details on the RC series resistors.
3. If you have any questions, please contact our sales staff.
Packaging Specifications
Type / Code
RC14
RC12
A max.
B max
2.787
70.80
2.756
70.00
13.504
343.00
13.504
343.00
C
0.394
10.00
0.394
10.00
8
D
0.020
0.50
0.020
0.50
2.063
52.40
2.063
52.40
0.079
2.00
0.079
2.00
Tape
Unit
0.250
6.35
0.250
6.35
inches
mm
inches
mm
www.seielect.com
RC Series
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
RC
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Carbon Composition
Leaded Resistor
Axial
YES
100% Matte Sn
Jan-86
86/01
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
RC
1
2
3
4
5
6
7
8
9
10
R
C
1
4
J
T
1
R
Product Series
Carbon Comp
Size
Code
W
14
0.25
12
0.5
Code
J
K
Tolerance
Tol Value
5%
E24
10%
Code
T
B
Packaging
Description
Size
Quantity
Tape and Reel
5000
All Sizes
Bulk
1000
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
1 ohm = 1R00
10 Kohm = 10K0
1 Mohm = 1M00
9
www.seielect.com
