CD Series
Stackpole Electronics, Inc.
Zero Ohm Resistor
Resistive Product Solutions
Features:
Ideal for crossovers or jumpers on circuit boards with auto-insertion capability
High current rating
Cut and formed product is available on select sizes, contact Stackpole for details
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications
Part Number
Current Rating (A)
(zero Ohm)
@ 70ºC
CD18
2
CD14
3
CD12
4
Operating temperature range is -55C to +155C
Dielectric Withstanding
Voltage (V)
300
500
600
Marking
Resistance (Ω)
Single black band
0.01 or less
Mechanical Specifications
Type/Code
CD18
CD14
CD12
A
Body Length
0.126 ± 0.008
3.20 ± 0.20
0.236 ± 0.012
6.00 ± 0.30
0.354 ± 0.020
9.00 ± 0.50
B
Body Diameter
0.071 ± 0.008
1.80 ± 0.20
0.091 ± 0.008
2.30 ± 0.20
0.126 ± 0.020
3.20 ± 0.50
C
Lead Length (Bulk)
1.102 ± 0.079
28.00 ± 2.00
1.102 ± 0.079
28.00 ± 2.00
1.024 ± 0.079
26.00 ± 2.00
D
Lead Diameter
0.018 ± 0.0008
0.45 ± 0.02
0.022 ± 0.0012
0.55 ± 0.03
0.026 ± 0.0012
0.65 ± 0.03
Unit
inches
mm
inches
mm
inches
mm
Power Derating Curve:
Rev Date: 4/5/2022
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
CD Series
Zero Ohm Resistor
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
Rev Date: 4/5/2022
2
www.seielect.com
CD Series
Zero Ohm Resistor
Packaging Specifications
Series
CD
A max.(1)
B max
C
D(2)
Tape
Unit
18
2.508
63.70
0.197 ± 0.020
5.00 ± 0.50
2.063 ± 0.079
52.40 ± 2.00
0.250
6.35
inches
mm
14
2.618
66.50
13.504
343.00
13.504
0.197 ± 0.020
5.00 ± 0.50
2.063 ± 0.079
52.40 ± 2.00
0.250
6.35
inches
mm
12
2.736
69.50
0.197 ± 0.020
5.00 ± 0.50
2.063 ± 0.079
52.40 ± 2.00
0.250
6.35
inches
mm
Size
343.00
13.504
343.00
Dimension "E": This is a non-critical dimension that does not have a tolerance in the standard.
Range of diameters is from 0.547 inches (13.90 mm) to 1.500 inches (38.10 mm).
(1) Reference value only. The "A" dimension shall be governed by the overall length of the taped component.
The distance between flanges shall be 0.059 inches (1.50 mm) to 0.315 (8.00 mm) greater than the overall component.
(2) The given dimension "D" expresses the standard width spacing. A 26 mm narrow spacing is available as option "N" packaging code.
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
CD
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Axial Leaded Zero Ohm Resistor
Axial
YES
100% Matte Sn
Jan-04
04/01
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Rev Date: 4/5/2022
3
www.seielect.com
CD Series
Zero Ohm Resistor
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
C
Product Series
Code
Description
CD Zero Ohm - Axial Lead
D
1
Current Rating
Code
A
18
2
14
3
12
4
4
Z
Tolerance
Code
Tol
Z
< 0.01 ohm
T
Code
T
A
B
Rev Date: 4/5/2022
4
R
Packaging
Description
Size
12
Tape and Reel
14, 18
12
Ammo
14, 18
Bulk
12, 14, 18
Quantity
2500
5000
2000
5000
1000
Resistance Value
0R00 = Zero Ohm - Axial Lead
www.seielect.com
很抱歉,暂时无法提供与“CD18ZT0R00”相匹配的价格&库存,您可以联系我们找货
