USB 2.0 4-Port Hub
Product Brief Rev. 1.2
FE1.1
USB 2.0 HIGH SPEED 4-PORT HUB CONTROLLER
______________________PRODUCT BRIEF_______________________
INTRODUCTION
The FE1.1 is a highly integrated, high quality,
high performance, low power consumption, yet
low cost solution for USB 2.0 4-Port Hub.
It adopts Multiple Transaction Translator (MTT)
architecture to explore the maximum possible
throughput. Six, instead of two, non-periodic
transaction buffers are used to minimize potential
traffic jamming. The whole design is based on
state-machine-control to reduce the response
delay time; no micro controller is used in this
chip.
To guarantee high quality, the whole chip is
covered by Test Scan Chain – include even the
high speed (480MHz) modules, so that all the
logic components could be fully tested before
shipping. Special Build-In-Self-Test mode is
designed to exercise all high, full, and low speed
analog components on the packaging and testing
stage as well.
Low power consumption is achieved by using
0.18μm technology and comprehensive
power/clock control mechanism. Most part of the
chip will not be clocked unless needed.
Dec. 29, 2008
FEATURES
□ 115 mA when four Downstream ports
enabled in High-Speed mode;
□ 64 mA when one Downstream port
Fully compliant with Universal Serial Bus
Specification Revision 2.0 (USB 2.0);
□ Upstream facing port supports HighSpeed (480MHz) and Full-Speed
(12MHz) modes;
□ 4 downstream facing ports support
High-Speed (480MHz), Full-Speed
(12MHz), and Low-Speed (1.5MHz)
modes;
Integrated USB 2.0 Transceivers;
Integrated upstream 1.5KΩ pull-up,
downstream 15KΩ pull-down, and serial
resisters;
Integrated 5V to 3.3V and 1.8V regulator.
Integrated Power-On-Reset circuit;
Integrated 12MHz Oscillator with feedback
resister, and crystal load capacitance;
Integrated 12MHz-to-480MHz Phase Lock
Loop (PLL);
Multiple Transaction Translators (MTT) –
□ One TT for each downstream port;
□ Alternate Interface 0 for Single-TT, and
1
USB 2.0 4-Port Hub
Alternate Interface 1 for Multiple-TT;
□ Each TT could handle 64 periodic
Start-Split transactions, 32 periodic
Complete-Split transactions, and 6
none-periodic transactions;
Automatic self-power status monitoring;
□ Automatic re-enumeration when SelfPowered switching to Bus-Powered;
Board configured options –
□ Ganged or Individual Power Control
Mode select;
□ Global or Individual Over-Current
Detection Mode select;
□ Removable or Non-Removable
Downstream Devices configuration;
Comprehensive Port Indicators support:
□ Standard downstream port status
indicators (Green and Amber LED
control for each downstream port);
□ Hub active LED support;
Support Microsoft Windows 98SE/ME,
2000, XP, and Vista;
Support Mac OS 8.6 and above;
Support Linux kernel 2.4.20 and above.
PACKAGE
48-pin LQFP (Body Size: 7x7 mm)
48-pin QFN (Body Size: 6x6 mm, 0.4 pitch)
TERMINUS TECHNOLOGY INC.
1052, 10F, NO. 3-2, YUANQU ST. NANGANG
TAIPEI, TAIWAN, ROC
Dec. 29, 2008
2
很抱歉,暂时无法提供与“FE1.1-AQFP48A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.88750
- 30+6.65000
- 100+6.17500
- 500+5.70000
- 1000+5.46250
- 国内价格
- 1+7.22520
- 10+6.09120
- 30+5.46480
- 250+4.69800
