Serial No.
TXC CORPORATION
Issue Date
www.txccorp.com
SPECIFICATION
CUSTOMER
PRODUCT TYPE
SMD GLASS SEALING XTAL 3.2 × 2.5
NOMINAL FREQ.
24.576000MHz
TXC P/N
7V24580009
REVISION
A3
CUSTOMER P/N
Customer Signature & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
PE/RD
QA
MFG
Robin Huang
Samson Xiong
Jake Liu
RoHS Compliant
FMT-R&D039
Issue Date: 10.16'08 VER.B
TXC CORPORATION
Rev
Revise page
S1
N/A
S2
3
A1
N/A
A2
A3
TXC P/N: 7V24580009
A3
PAGE: 1
Date
Ref.No.
Reviser
Initial released
26-Mar-12
N/A
Xiaoyan Jiang
Frequency Stability,
Drive Level,
Equivalent Resistance Rr Change
13-Aug-12
ECR-12N091004
Xiaoyan Jiang
S Turn A
3-Sep-12
N/A
Xiaoyan Jiang
P3~P11
Add SHARP's special requirements
Add CKG factory
Modify marking code instruction
20-Apr-16
ECR-16N042900
Xiaoyan Jiang
P3,4.11
1.Country of origin made in china/TXC
chungking factory
2.Making information
3.Add TXC chungking factory
22-Jun-16
ECR-16N062401
Xiaoyan Jiang
FMT-DOC024
Revise contents
REVISION:
Issue Date: 04.17'15 VER.G
TXC CORPORATION
TXC P/N:
7V24580009
REVISION:
A3
PAGE: 2
Spec Sheet Contents
No.
Content
Page
1
ELECTRICAL SPECIFICATIONS
P.3
2
DIMENSIONS
P.4
3
MARKING
P.4
4
FACTORY LOCATION
P.4
5
SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION
P.4
6
STRUCTURE ILLUSTRATION
P.5
7
EMBOSS CARRIER TAPE & REEL
P.6
8
PACKING
P.7
9
RELIABILITY SPECIFICATIONS
FMT-DOC024
P.8~9
TXC CORPORATION
TXC P/N:
7V24580009
A3
REVISION:
PAGE:
3
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.018±0.001 g/pcs
Country of origin:
Made in China/TXC Ningbo Factory
Made in China/TXC Chungking Factory
Parameters
1 Nominal Frequency
2 Oscillation Mode
SYM.
Electrical Spec.
MIN
TYP
FL
24.576000
MAX
Notes
UNITS
MHz
Fundamental
CL
8
pF
4 Frequency Tolerance
±15
ppm
at 25 ± 3 ℃
5 Frequency Stability
±20
ppm
Over Operating Temp. Range (Reference 25℃)
6 Operating Temperature
7 Aging
3 Load Capacitance
-10
85
±3
ppm
1st Year
8 Drive Level
DL
50
300
uW
9 Equivalent Resistance Rr
Rr
50
Ω
10 Shunt Capacitance C0
C0
3
pF
11 2 times reflow
All electric characteristics should be
guaranteed after twice reflow.
12 Spurious
Frequency of 3F0 +/- 100kHz response
3dB or more.
13 Insulation Resistance
500
MΩ
14 Storage Temperature Range
-40
85
FMT-DOC024
at DC 100V
TXC CORPORATION
TXC P/N:
7V24580009
A3
REVISION:
PAGE:
4
■ DIMENSIONS
(Unit:mm)
3.2±0.1
Connection
0.25
NC
3
3
4
2.5±0.1
4
1
0.8 ± 0.1
3
Suggested Layout
0.8 1.4
1.4
1.2 0.5 1.2
4
NC
0.7±0.1
2
0.8±0.05
0.9±0.05 1.2±0.1
1
2
1
2
*Coplanarity of solderable areas Camber 0.10 mm Max
■ MARKING
TXC Logo
T□□□
Frequency Code
Ex.: 24.576000 MHz = 245
Lot Code
Date Code
Line Code
Date Code:
MONTH
YEAR
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
2005
2009
2013
2017
A
B
C
D
E
F
G
H
J
K
L
M
2006
2010
2014
2018
N
P
Q
R
S
T
U
V
W
X
Y
Z
2007
2011
2015
2019
a
b
c
d
e
f
g
h
j
k
l
m
2008
2012
2016
2020
n
p
q
r
s
t
u
v
w
x
y
z
*This date code will be cycled every four years
■ SUGGESTED REFLOW PROFILE(QCII-P1-06)
Pb-free Reflow Profile
CONDITION
REFLOW
PEAK TEMP/TIME
220℃≦
PREHEAT
150 ~ 190℃
MOISUTURE PROOF
OPEN-1st REFLOW
1st-2nd
Measure Ponit
Storage Condition
FMT-DOC024
S=REFLOW
W=REFLOW
240℃/5s≧
20 ~ 40s
230℃/5s
20 ~ 40s
90 ~ 120s
90 ~ 120s
(It is not necessary )
SURFACE OF COMPONENT
0 ~ 30℃, 70%RH≧
TXC CORPORATION
TXC P/N:
7V24580009
REVISION:
A3
PAGE:
5
■ STRUCTURE ILLUSTRATION
5
4
6
1
7
2
3
NO
MATERIALS
COMPONENTS
FINISH/SPECIFICATIONS
supplier
Kyocera
2 Package
Ceramic (AI2O3)
Ceramic (AI2O3)
Kyocera
3 PAD
Au
included in Kyocera base Tungsten metalize
1 Cap
+W plating 10~20um
+ Ni plating 1.27~8.89um
+ Au plating 0.2~1.0um
The substrate(W or Ni) should
not be seen due to less Au.
4 Crystal blank
SiO2
TXC
5 Conductive adhesive
Resin+Ag
FUJIKURA
6 Electrode
Noble Metal
SOLAR
7 Sealing Glass
Glass(PbO)
included in Kyocera base -
FMT-DOC024
TXC CORPORATION
7V24580009
TXC P/N:
A3
REVISION:
PAGE: 6
■ EMBOSS CARRIER TAPE & REEL
F
E
B
H
G
DIMENSIONS
A
1.65±0.10
B
Feeding
D
C
A
C
D
E
F
G
H
3.40±0.10 2.70±0.10 4.00±0.10 8.00±0.20 4.00±0.10 1.55±0.10 1.75±0.10 (UNIT:mm)
Release strength of cover tape. It has to between 20g~80g under following condition.
Pulling Direction : keep angle 165°to 180°
Speed : 300mm/Min.
TAPE
Material
TAPE
Material
Carrier tape
ABS or PS
Cover tape
PS or PET
REMARK :
Products put in 3000pcs
Trailer
160mm(Min)
Empty Sealed
Leader
160mm(Min)
230mm(Min)
User direction of feed
W
W1
2.0
L1
DIMENSIONS
FMT-DOC024
L
L
L1
W
W1
178±1.00
13±0.50
11.5±0.20
8±0.10
(UNIT:mm)
TXC CORPORATION
TXC P/N:
7V24580009
REVISION:
A3
PAGE:
7
■ PACKING
Reel Quantity :
1. Reel X 6 (6 Reels)
2. Reel X 12 (12 Reels)
3. Reel X 25 (12 Reels + 13 Reels)
4. Reel X 50 ( 12 Reelsx2 + 13 Reelsx2 )
Label A
C-3
Box Size:
1. L200 X W200 X H140mm
2. L200 X W200 X H250mm
3. L400 X W200 X H250mm
4. L400 X W400 X H280mm
Tape
Tape
Label B
QA Pass
(Label A) Size:80 X 40mm
(Label C-3) Size:100 X 50mm
(Lable B) Size:100 X 100mm
[STORAGE]
1.The storage time to be 1 year maximum.
2.Don't be caught in the rain.
3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine.
4.If customers have special requirements, we can paste labels according to it.
FMT-DOC024
TXC CORPORATION
TXC P/N: 7V24580009
REVISION: A3
PAGE: 8
■ RELIABILITY SPECIFICATIONS
■ It guarantees after reflow twice by pretreatment.
Items
Conditions
Specifications
FINE LEAK
He bombing 4.5kg/cm2 for 2 hours
很抱歉,暂时无法提供与“7V24580009”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.68173
- 100+0.63803
- 300+0.59433
- 500+0.55063
- 2000+0.52878
- 5000+0.51567
