SPZ1EM101E08O00RAXXX 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
PZ series
Endurance: +105°C 2,000 hours
Low ESR
Recommended Applications: System Board,Display Card,Small Charger and intelligent TV
RoHS Compliant and lead-free
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-55~+105°C
Rated Working Voltage Range
6.3~100 V dc
Nominal Capacitance Range
4.7~5600µF
Capacitance Tolerance
±20%(M)
DC Leakage Current
I≤0.2CV or 500μA, whichever is greater.
Where, I:Max.leakage current (µA),C:Nominal capacitance (µF),V: Rated voltage (V)
Dissipation Factor (tanδ)
Rated Voltage(V dc )
(at 20°C,120Hz)
6.3
tanδ (max.)
6.8
7.5
10
16
25
0.08
ESR(100kHz,20°C)
Value in characteristics table
Temperature Characteristic
(Impedance Ratio at 100kHz)
Z(+105°C)/Z(+20°C)≤1.25
Z(-55°C)/Z(+20°C)≤1.25
35
(at 20°C after 2 minutes)
50
63
100
0.12
0.15
(at 20°C,120Hz)
After applying rated voltage for 2,000 hours at 105°C,the capacitors shall meet the following requirements.
Endurance
Appearance
No significant damage
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤150% of the initial specified value
ESR
Leakage Current
≤The initial specified value
After subjecting to 90%~95% RH for 2,000 hours at 60°C without voltage applied, the capacitors shall meet the specified
values for the Endurance characteristics listed above.
Humidity Test
After subjecting to 1,000 cycles each consisting of charge with the surge voltage specified at normal temperature for 30
seconds through a protective resistor and discharge for 5 minutes 30 seconds, the capacitors shall meet the following
requirements.
Surge Test
Appearance
Capacitance Change
≤ ± 20% of the initial value
D.F. (tanδ)
ESR
Leakage Current
DIMENSIONS[mm]
Ød
ØD'
F±0.5
L'
4min.
15min.
ØD
5
5.5
6.3
8
10
Ød
0.5
0.5
0.5
0.6
0.6
F
ØD'
L'
2.0
2.5
2.5
3.5
5.0
Ø D-0.1~+0.5
L+1.0max.
L-0.5~+1
PART NUMBERING SYSTEM
S
P
Z
1 C
M
2
7
1
E
O
R
A
X X X
Special code
Marking code
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
23
PZ series
VDC
(SV)
Cap
(µF)
100
220
270
330
390
470
500
560
6.3
(7.2)
680
820
1000
1200
1500
1800
2200
3300
4700
5600
220
270
330
6.8
(7.8)
390
470
560
680
820
1000
150
220
270
330
7
(8.1)
470
560
680
820
220
270
330
390
470
7.5
(8.6)
500
560
680
820
1000
10
(11.5)
1200
1500
1800
2200
47
56
68
82
100
120
Size
ΦDxL(mm)
5×7
5×7
6.3×7
5×7
5×8
6.3×5
6.3×8
5×9
5×10
5.5×9
6.3×7
6.3×8
5×9
6.3×7
6.3×8
5.5×9
6.3×9
5.5×9
8×9
5.5×12
6.3×9
8×9
6.3×10
8×9
8×11
6.3×11
8×11
8×11
10×12
10×10
8×14
10×12
10×14
10×17
10×18
5×7
5×7
6.3×8
5×8
6.3×5
6.3×7
5×9
5×9
6.3×7
6.3×8
6.3×9
6.3×9
6.3×11
8×11
5×6
5×7
5×8
5×9
6.3×8
5.5×9
6.3×8
6.3×9
6.3×10
8×9
5×7
5×8
5×8
5×9
6.3×7
5.5×9
5×9
5.5×8
5.5×9
6.3×8
6.3×9
6.3×10
8×9
8×11
6.3×11
8×11
8×11
6.8×13
8×14
10×12
5×7
5×7
5×7
5×7
5×7
6.3×5
5×7
ESR
(mΩ,20°C,100kHz)
(max.)
Rated ripple current
(mArms/105°C,100kHz)
Leakage Current
(µA)(max.)
Part Number
30
15
10
12
10
10
10
10
10
10
10
10
10
10
10
10
30
12
12
12
12
12
12
12
12
12
12
12
35
35
35
35
35
30
3500
3900
3800
4000
3160
4000
4100
4300
4100
3900
4400
4100
4200
4800
4300
5080
4800
4600
5000
5080
4700
5150
4800
5200
5200
5300
5400
5500
5560
5700
5800
5900
6100
6300
3300
3600
3900
3800
3100
3400
3900
4100
3700
4500
4800
4900
5100
5150
1500
3200
3400
3600
3800
3600
4000
4200
4500
4600
3100
3300
3500
3500
3200
3550
3550
3100
3600
3900
4100
4400
4550
4700
4500
4800
4900
4800
5100
5700
2200
2250
2300
2350
2400
2300
2450
500
500
500
500
500
500
500
500
592
592
592
592
630
706
706
706
857
857
857
1033
1033
1033
1260
1260
1260
1512
1512
1890
1890
2268
2772
2772
4158
5000
5000
500
500
500
500
500
500
530
639
639
762
925
1115
1360
1360
500
500
500
500
658
658
784
952
1148
1148
500
500
500
585
705
705
705
705
750
840
1020
1230
1230
1500
1500
1800
2250
2250
2700
3300
500
500
500
500
500
500
500
SPZ0JM101D07O00RAXXX
SPZ0JM221D07O00RAXXX
SPZ0JM221E07O00RAXXX
SPZ0JM271D07O00RAXXX
SPZ0JM331D08O00RAXXX
SPZ0JM331E05O00RAXXX
SPZ0JM331E08O00RAXXX
SPZ0JM391D09O00RAXXX
SPZ0JM471D10O00RAXXX
SPZ0JM471B09O00RAXXX
SPZ0JM471E07O00RAXXX
SPZ0JM471E08O00RAXXX
SPZ0JM501D09O00RAXXX
SPZ0JM561E07O00RAXXX
SPZ0JM561E08O00RAXXX
SPZ0JM561B09O00RAXXX
SPZ0JM681E09O00RAXXX
SPZ0JM681B09O00RAXXX
SPZ0JM681F09O00RAXXX
SPZ0JM821B12O00RAXXX
SPZ0JM821E09O00RAXXX
SPZ0JM821F09O00RAXXX
SPZ0JM102E10O00RAXXX
SPZ0JM102F09O00RAXXX
SPZ0JM102F11O00RAXXX
SPZ0JM122E11O00RAXXX
SPZ0JM122F11O00RAXXX
SPZ0JM152F11O00RAXXX
SPZ0JM152G12O00RAXXX
SPZ0JM182G10O00RAXXX
SPZ0JM222F14O00RAXXX
SPZ0JM222G12O00RAXXX
SPZ0JM332G14O00RAXXX
SPZ0JM472G17O00RAXXX
SPZ0JM562G18O00RAXXX
SPZ0CM221D07O00RAXXX
SPZ0CM271D07O00RAXXX
SPZ0CM271E08O00RAXXX
SPZ0CM331D08O00RAXXX
SPZ0CM331E05O00RAXXX
SPZ0CM331E07O00RAXXX
SPZ0CM391D09O00RAXXX
SPZ0CM471D09O00RAXXX
SPZ0CM471E07O00RAXXX
SPZ0CM561E08O00RAXXX
SPZ0CM681E09O00RAXXX
SPZ0CM821E09O00RAXXX
SPZ0CM102E11O00RAXXX
SPZ0CM102F11O00RAXXX
SPZ0QM151D06O00RAXXX
SPZ0QM221D07O00RAXXX
SPZ0QM271D08O00RAXXX
SPZ0QM331D09O00RAXXX
SPZ0QM471E08O00RAXXX
SPZ0QM471B09O00RAXXX
SPZ0QM561E08O00RAXXX
SPZ0QM681E09O00RAXXX
SPZ0QM821E10O00RAXXX
SPZ0QM821F09O00RAXXX
SPZ0AM221D07O00RAXXX
SPZ0AM271D08O00RAXXX
SPZ0AM331D08O00RAXXX
SPZ0AM391D09O00RAXXX
SPZ0AM471E07O00RAXXX
SPZ0AM471B09O00RAXXX
SPZ0AM471D09O00RAXXX
SPZ0AM471B08O00RAXXX
SPZ0AM501B09O00RAXXX
SPZ0AM561E08O00RAXXX
SPZ0AM681E09O00RAXXX
SPZ0AM821E10O00RAXXX
SPZ0AM821F09O00RAXXX
SPZ0AM102F11O00RAXXX
SPZ0AM102E11O00RAXXX
SPZ0AM122F11O00RAXXX
SPZ0AM152F11O00RAXXX
SPZ0AM152Q13O00RAXXX
SPZ0AM182F14O00RAXXX
SPZ0AM222G12O00RAXXX
SPZ1AM470D07O00RAXXX
SPZ1AM560D07O00RAXXX
SPZ1AM680D07O00RAXXX
SPZ1AM820D07O00RAXXX
SPZ1AM101D07O00RAXXX
SPZ1AM101E05O00RAXXX
SPZ1AM121D07O00RAXXX
24
Conductive Polymer
Radial Type
STANDARD RATINGS
PZ series
STANDARD RATINGS
VDC
(SV)
Cap
(µF)
150
180
220
270
330
390
10
(11.5)
470
560
680
820
1000
1200
1500
1800
2200
3300
330
470
12
(13.8)
560
680
820
1000
1200
1500
22
47
56
68
82
100
120
150
180
220
16
(18.4)
270
330
470
560
680
820
1000
1200
1500
1800
2200
120
150
220
270
330
470
Size
ΦDxL(mm)
5×7
6.3×7
5×8
5×9
6.3×5
6.3×8
6.3×8
6.3×8
8×9
6.3×10
6.3×8
5.5×9
6.3×8
8×9
8×11
6.3×10
8×9
8×11
8×8
8×11
8×11
10×12
8×12
10×12
10×12
8×14
10×13
10×15
10×18
5.5×9
6.3×8
5.5×9
6.3×9
6.3×10
6.3×11
8×10
8×11
8×12
8×14
8×16
5×9
5×7
5×7
5×7
5×8
5×7
6.3×5
6.3×8
5×8
5×8
5×8
6.3×7
5×10
6.3×8
6.3×10
5.5×9
6.3×8
8×9
5.5×9
6.3×9
6.3×10
5.5×11
6.3×11
8×11
8×9
8×11
8×13
10×12
8×11
10×12
8×13
10×12
10×12
8×14
10×15
10×12
10×12
10×18
10×14
10×17
10×15
6.3×8
6.3×10
8×11
8×11
8×11
6.3×10
10×12
8×16
8×11
ESR
(mΩ,20°C,100kHz)
(max.)
Leakage Current
(µA)(max.)
Part Number
15
12
12
13
15
12
12
10
10
10
10
10
10
10
10
15
15
12
12
12
12
80
11
13
11
15
11
15
11
11
11
11
11
12
12
12
12
12
12
12
30
2800
2700
2820
2800
3160
3100
3300
3400
3500
3400
3400
3500
3550
5650
3600
3600
3900
3300
4000
4200
5300
4500
5450
5500
4800
5800
6100
6200
3100
3100
3200
3450
3400
3600
3700
3800
4000
4400
4800
1600
2050
2100
2150
2200
2250
2100
2800
2350
2400
2450
2500
2600
2700
2900
2750
2800
2900
2900
2900
3100
3100
3200
4600
4100
3200
3300
3500
3400
3600
3500
3800
4000
3600
4300
4200
4800
5500
5400
5800
5500
2300
2350
2550
2700
2800
2100
2900
3000
2400
500
500
500
500
500
500
540
660
660
660
780
940
940
940
940
1120
1120
1360
1360
1640
2000
2000
2400
2400
3000
3000
3600
4400
5000
792
792
1128
1128
1344
1632
1632
1968
2400
2880
3600
500
500
500
500
500
500
500
500
500
500
576
576
704
704
704
864
864
864
1056
1056
1056
1504
1504
1504
1504
1792
1792
1792
2176
2176
2624
2624
3200
3200
3840
3840
4800
4800
5000
5000
5000
500
600
880
1080
1320
1320
1880
1880
1880
SPZ1AM151D07O00RAXXX
SPZ1AM181E07O00RAXXX
SPZ1AM181D08O00RAXXX
SPZ1AM221D09O00RAXXX
SPZ1AM221E05O00RAXXX
SPZ1AM221E08O00RAXXX
SPZ1AM271E08O00RAXXX
SPZ1AM331E08O00RAXXX
SPZ1AM331F09O00RAXXX
SPZ1AM331E10O00RAXXX
SPZ1AM391E08O00RAXXX
SPZ1AM471B09O00RAXXX
SPZ1AM471E08O00RAXXX
SPZ1AM471F09O00RAXXX
SPZ1AM471F11O00RAXXX
SPZ1AM561E10O00RAXXX
SPZ1AM561F09O00RAXXX
SPZ1AM681F11O00RAXXX
SPZ1AM681F08O00RAXXX
SPZ1AM821F11O00RAXXX
SPZ1AM102F11O00RAXXX
SPZ1AM102G12O00RAXXX
SPZ1AM122F12O00RAXXX
SPZ1AM122G12O00RAXXX
SPZ1AM152G12O00RAXXX
SPZ1AM152F14O00RAXXX
SPZ1AM182G13O00RAXXX
SPZ1AM222G15O00RAXXX
SPZ1AM332G18O00RAXXX
SPZ1TM331B09O00RAXXX
SPZ1TM331E08O00RAXXX
SPZ1TM471B09O00RAXXX
SPZ1TM471E09O00RAXXX
SPZ1TM561E10O00RAXXX
SPZ1TM681E11O00RAXXX
SPZ1TM681F10O00RAXXX
SPZ1TM821F11O00RAXXX
SPZ1TM102F12O00RAXXX
SPZ1TM122F14O00RAXXX
SPZ1TM152F16O00RAXXX
SPZ1CM220D09O00RAXXX
SPZ1CM470D07O00RAXXX
SPZ1CM560D07O00RAXXX
SPZ1CM680D07O00RAXXX
SPZ1CM820D08O00RAXXX
SPZ1CM101D07O00RAXXX
SPZ1CM101E05O00RAXXX
SPZ1CM101E08O00RAXXX
SPZ1CM121D08O00RAXXX
SPZ1CM151D08O00RAXXX
SPZ1CM181D08O00RAXXX
SPZ1CM181E07O00RAXXX
SPZ1CM221D10O00RAXXX
SPZ1CM221E08O00RAXXX
SPZ1CM221E10O00RAXXX
SPZ1CM271B09O00RAXXX
SPZ1CM271E08O00RAXXX
SPZ1CM271F09O00RAXXX
SPZ1CM331B09O00RAXXX
SPZ1CM331E09O00RAXXX
SPZ1CM331E10O00RAXXX
SPZ1CM471B11O00RAXXX
SPZ1CM471E11O00RAXXX
SPZ1CM471F11O00RAXXX
SPZ1CM471F09O00RAXXX
SPZ1CM561F11O00RAXXX
SPZ1CM561F13O00RAXXX
SPZ1CM561G12O00RAXXX
SPZ1CM681F11O00RAXXX
SPZ1CM681G12O00RAXXX
SPZ1CM821F13O00RAXXX
SPZ1CM821G12O00RAXXX
SPZ1CM102G12O00RAXXX
SPZ1CM102F14O00RAXXX
SPZ1CM122G15O00RAXXX
SPZ1CM122G12O00RAXXX
SPZ1CM152G12O00RAXXX
SPZ1CM152G18O00RAXXX
SPZ1CM182G14O00RAXXX
SPZ1CM222G17O00RAXXX
SPZ1CM222G15O00RAXXX
SPZ1DM121E08O00RAXXX
SPZ1DM151E10O00RAXXX
SPZ1DM221F11O00RAXXX
SPZ1DM271F11O00RAXXX
SPZ1DM331F11O00RAXXX
SPZ1DM331E10O00RAXXX
SPZ1DM471G12O00RAXXX
SPZ1DM471F16O00RAXXX
SPZ1DM471F11O00RAXXX
25
PZ series
VDC
(SV)
Cap
(µF)
560
680
820
1000
6.8
10
22
33
39
47
56
68
82
100
120
150
25
(28.8)
180
220
270
330
470
560
680
820
1000
4.7
10
15
22
33
39
47
56
68
82
100
35
(40.3)
120
150
180
220
270
330
470
560
680
820
1000
4.7
10
15
22
33
47
56
68
50
(57.5)
63(72.5)
100
120
150
180
220
270
330
440
470
4.7
Size
ΦDxL(mm)
ESR
(mΩ,20°C,100kHz)
(max.)
Leakage Current
(µA)(max.)
Part Number
10×12
8×16
10×15
8×14
10×18
10×18
6.3×5
5×8
5×9
5×9
5×8
5×9
5×9
6.3×7
6.3×7
6.3×8
6.3×10
8×11
6.3×8
6.3×10
6.3×10
8×9
8×11
10×12
5.5×11
8×11
8×11
10×12
10×10
10×12
8×16
8×11
10×10
10×12
8×12
10×15
10×12
8×14
10×18
10×12
8×16
10×18
5×8
5×8
5×8
5×9
5×9
5×9
6.3×7
6.3×7
6.3×7
6.3×7
6.3×8
6.3×10
8×11
6.3×10
6.3×10
6.3×11
8×11
10×12
6.3×11
10×12
10×12
10×13
10×14
10×16
10×18
10×18
5×8
6.3×7
5×8
5×8
6.3×7
6.3×7
6.3×8
6.3×8
6.3×10
8×11
8×9
8×11
10×12
10×12
10×12
10×13
10×15
10×18
10×18
6.3×8
70
60
50
60
60
60
30
30
30
60
60
100
50
50
50
50
50
50
50
40
40
40
40
40
40
30
40
30
30
35
70
70
40
40
35
35
30
30
40
30
30
30
30
3100
3200
3300
2700
3400
3900
1100
1800
1810
1850
1900
1950
2050
2100
2150
2500
2800
3000
2500
2800
2800
2500
3000
3500
1900
3000
3100
3800
2800
4000
3400
3000
2800
4000
3100
4300
2240
2240
2720
2720
3280
4000
500
500
500
500
500
500
500
500
500
500
500
500
600
750
900
900
1100
1100
1100
1350
1650
1650
1650
2350
2350
2350
2350
2800
2800
3400
3400
3400
4100
4100
4100
5000
500
500
500
500
500
500
500
500
500
574
700
700
700
840
1050
1260
1540
1540
1540
1890
2310
3290
3920
4760
5000
5000
500
500
500
500
500
500
500
560
680
1000
1000
1200
1500
1800
2200
2700
3300
4400
4700
500
SPZ1DM561G12O00RAXXX
SPZ1DM561F16O00RAXXX
SPZ1DM681G15O00RAXXX
SPZ1DM681F14O00RAXXX
SPZ1DM821G18O00RAXXX
SPZ1DM102G18O00RAXXX
SPZ1EM6R8E05O00RAXXX
SPZ1EM100D08O00RAXXX
SPZ1EM220D09O00RAXXX
SPZ1EM330D09O00RAXXX
SPZ1EM390D08O00RAXXX
SPZ1EM470D09O00RAXXX
SPZ1EM560D09O00RAXXX
SPZ1EM680E07O00RAXXX
SPZ1EM820E07O00RAXXX
SPZ1EM101E10O00RAXXX
SPZ1EM101F11O00RAXXX
SPZ1EM121E08O00RAXXX
SPZ1EM151E10O00RAXXX
SPZ1EM181E10O00RAXXX
SPZ1EM181F09O00RAXXX
SPZ1EM221F11O00RAXXX
SPZ1EM221G12O00RAXXX
SPZ1EM221B11O00RAXXX
SPZ1EM271F11O00RAXXX
SPZ1EM331F11O00RAXXX
SPZ1EM331G12O00RAXXX
SPZ1EM331G10O00RAXXX
SPZ1EM471G12O00RAXXX
SPZ1EM471F16O00RAXXX
SPZ1EM471F11O00RAXXX
SPZ1EM471G10O00RAXXX
SPZ1EM561G12O00RAXXX
SPZ1EM561F12O00RAXXX
SPZ1EM681G15O00RAXXX
SPZ1EM681G12O00RAXXX
SPZ1EM681F14O00RAXXX
SPZ1EM821G18O00RAXXX
SPZ1EM821G12O00RAXXX
SPZ1EM821F16O00RAXXX
SPZ1EM102G18O00RAXXX
SPZ1VM4R7D08O00RAXXX
SPZ1VM100D08O00RAXXX
SPZ1VM150D08O00RAXXX
SPZ1VM220D09O00RAXXX
SPZ1VM330D09O00RAXXX
SPZ1VM390D09O00RAXXX
SPZ1VM470E07O00RAXXX
SPZ1VM560E07O00RAXXX
SPZ1VM680E07O00RAXXX
SPZ1VM820E07O00RAXXX
SPZ1VM101E08O00RAXXX
SPZ1VM101E10O00RAXXX
SPZ1VM101F11O00RAXXX
SPZ1VM121E10O00RAXXX
SPZ1VM151E10O00RAXXX
SPZ1VM181E11O00RAXXX
SPZ1VM221F11O00RAXXX
SPZ1VM221G12O00RAXXX
SPZ1VM221E11O00RAXXX
SPZ1VM271G12O00RAXXX
SPZ1VM331G12O00RAXXX
SPZ1VM471G13O00RAXXX
SPZ1VM561G14O00RAXXX
SPZ1VM681G16O00RAXXX
SPZ1VM821G18O00RAXXX
SPZ1VM102G18O00RAXXX
SPZ1HM4R7D08O00RAXXX
SPZ1HM100E07O00RAXXX
SPZ1HM100D08O00RAXXX
SPZ1HM150D08O00RAXXX
SPZ1HM220E07O00RAXXX
SPZ1HM330E07O00RAXXX
SPZ1HM470E08O00RAXXX
SPZ1HM560E08O00RAXXX
SPZ1HM680E10O00RAXXX
SPZ1HM101F11O00RAXXX
SPZ1HM101F09O00RAXXX
SPZ1HM121F11O00RAXXX
SPZ1HM151G12O00RAXXX
SPZ1HM181G12O00RAXXX
SPZ1HM221G12O00RAXXX
SPZ1HM271G13O00RAXXX
SPZ1HM331G15O00RAXXX
SPZ1HM441G18O00RAXXX
SPZ1HM471G18O00RAXXX
SPZ1JM4R7E08O00RAXXX
4100
3400
4500
4100
3600
4500
1700
1800
1850
1950
2000
2050
2100
2150
2200
2250
2350
2400
2600
2500
2550
2600
2800
2900
2600
3000
3100
3200
3300
3400
3500
3700
1600
1850
1630
1660
1900
2000
2100
2120
2150
2300
2100
2400
2500
2600
2700
2900
3000
3100
3150
1600
26
Conductive Polymer
Radial Type
STANDARD RATINGS
PZ series
STANDARD RATINGS
VDC
(SV)
63
(72.5)
80
(92.0)
100
(115.0)
Cap
(µF)
Size
ΦDxL(mm)
6.8
10
33
39
47
56
68
82
100
150
180
220
270
330
4.7
6.8
22
33
47
68
100
4.7
6.8
6.3×8
6.3×5
6.3×8
6.3×8
6.3×9
8×9
8×11
8×11
10×12
10×12
10×13
10×15
10×17
10×18
6.3×8
6.3×8
6.3×10
8×11
10×12
10×12
10×14
6.3×8
6.3×8
6.3×10
8×11
8×11
10×12
10×14
10×16
10
15
22
33
47
ESR
(mΩ,20°C,100kHz)
(max.)
60
60
30
30
30
30
30
30
30
30
60
60
35
35
35
35
120
120
50
50
35
35
35
35
Leakage Current
(µA)(max.)
Part Number
1650
1600
1700
1750
1900
1800
2000
2100
2200
2500
2600
2650
2850
2950
1500
1550
1650
1700
1850
1900
2100
1400
1450
1500
1550
1550
1600
1650
1800
500
500
500
500
592
706
857
1033
1260
1890
2268
2772
3402
4158
500
500
500
528
752
1088
1600
500
500
500
500
500
500
660
940
SPZ1JM6R8E08O00RAXXX
SPZ1JM100E05O00RAXXX
SPZ1JM330E08O00RAXXX
SPZ1JM390E08O00RAXXX
SPZ1JM470E09O00RAXXX
SPZ1JM560F09O00RAXXX
SPZ1JM680F11O00RAXXX
SPZ1JM820F11O00RAXXX
SPZ1JM101G12O00RAXXX
SPZ1JM151G12O00RAXXX
SPZ1JM181G13O00RAXXX
SPZ1JM221G15O00RAXXX
SPZ1JM271G17O00RAXXX
SPZ1JM331G18O00RAXXX
SPZ1BM4R7E08O00RAXXX
SPZ1BM6R8E08O00RAXXX
SPZ1BM220E10O00RAXXX
SPZ1BM330F11O00RAXXX
SPZ1BM470G12O00RAXXX
SPZ1BM680G12O00RAXXX
SPZ1BM101G14O00RAXXX
SPZ1KM4R7E08O00RAXXX
SPZ1KM6R8E08O00RAXXX
SPZ1KM100E10O00RAXXX
SPZ1KM100F11O00RAXXX
SPZ1KM150F11O00RAXXX
SPZ1KM220G12O00RAXXX
SPZ1KM330G14O00RAXXX
SPZ1KM470G16O00RAXXX
※ Specifications subject to change without notice.
27
SPZ1EM101E08O00RAXXX 价格&库存
很抱歉,暂时无法提供与“SPZ1EM101E08O00RAXXX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.58500
- 100+0.54600
- 300+0.50700
- 500+0.46800
- 2000+0.44850
- 5000+0.43680
- 国内价格
- 5+0.86752
- 50+0.71028
- 150+0.63165
- 1000+0.57268
- 2000+0.52551
