HY3116-M010
HY3116-M010
    HYCON(纮康科技)
    MSOP10_3X3MM
    24位模数转换高分辨率Σ∆ADC与铁路到铁路OPAMP
HY3116-M010 数据手册
. HY3118/HY3116 Datasheet 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC With Rail-to-Rail OPAMP © 2008-2016 HYCON Technology Corp. www.hycontek.com DS-HY3118-V09_TC page1 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC Table of Contents 1. 特點 .............................................................................................................................. 6 2. 簡介 .............................................................................................................................. 7 3. 引腳定義 ....................................................................................................................... 8 4. 3.1. 產品引腳圖 .......................................................................................................................................... 8 3.2. I/O 引腳定義 ........................................................................................................................................ 8 3.2.1. SSOP package marker information .................................................................................................. 9 3.2.2. MSOP package marker information ................................................................................................. 9 應用電路 ..................................................................................................................... 10 4.1. 5. 6. 橋式感測器 ........................................................................................................................................ 10 暫存器列表 ................................................................................................................. 11 . 5.1. 暫存器列表 ........................................................................................................................................ 11 5.2. 暫存器說明 ........................................................................................................................................ 12 5.2.1. SYS Register System configuration control register (8bit) ............................................................. 12 5.2.2. ADC1 Register ADC configuration control register 1(8bit) (ADC input select) ............................... 12 5.2.3. ADC2 Register ADC configuration control register 2(8bit) ............................................................. 13 5.2.4. ADC3 Register ADC configuration control register 3(8bit) ............................................................. 14 5.2.5. ADC4 Register ADC configuration control register 3(8bit) ............................................................. 14 5.2.6. ADO Register ADC Output Code(24bit) ......................................................................................... 15 電氣特性 ..................................................................................................................... 16 6.1. ABSOLUTE MAXIMUM RATINGS.................................................................................................... 16 6.2. ELECTRICAL CHARACTERISTICS ................................................................................................. 17 6.3. OPAMP, Electrical Specification........................................................................................................ 21 7. ENOB AND NOISE-FREE .......................................................................................... 22 8. I2C 通訊協議............................................................................................................... 24 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page2 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 8.1. 9. I2C 通訊時序圖.................................................................................................................................. 24 OVERVIEW ................................................................................................................ 30 9.1. 系統工作頻率與低功耗 ( Frequency vs. Low Power mode ) ............................................................ 30 9.2. VDDA 電源 ( Low Dropout Regulator ) ............................................................................................ 31 9.3. REFO 參考電壓 ( Reference Voltage ) ............................................................................................. 31 9.4. 輸入通道多工器與中斷 IRQ ( Input Channel Multiplex with IRQ ).................................................... 32 9.5. 參考電壓輸入與參考電壓 ( Reference Voltage input Chancel with VREF ) ..................................... 33 9.6. 測量信號輸入通道與可編程信號放大器 ( Signal Input Channel with PGA ) ..................................... 35 9.7. 梳狀濾波器 ( COMB Filter ) .............................................................................................................. 37 9.8. 數據轉換格式 ( Data Conversion Format ) ....................................................................................... 39 9.9. 軌對軌運算放大器 ( Rail-to-Rail OPAMP ) ....................................................................................... 40 . 10. 訂貨資訊 ..................................................................................................................... 41 11. 封裝型式資訊 .............................................................................................................. 42 11.1. SSOP16 ............................................................................................................................................ 42 11.1.1. Package Dimensions ...................................................................................................................... 42 11.1.2. Tube Dimensions ............................................................................................................................ 43 11.1.3. Tape & Reel Information ................................................................................................................. 44 11.1.3.1. Reel Dimensions-Type 1……………..………………..…………… .......................................... 44 11.1.3.2. Carrier Tape Dimensions........................................................................................................ 44 11.1.3.3. Pin1 direction ......................................................................................................................... 44 11.1.3.4. Reel Dimensions-Type 2………………………………………….……...................................... 45 11.1.3.5. Carrier Tape Dimensions........................................................................................................ 45 11.1.3.6. Pin1 direction ......................................................................................................................... 45 11.2. MSOP10 ........................................................................................................................................... 46 11.2.1. Package Dimensions ...................................................................................................................... 46 11.2.2. Tape & Reel Information ................................................................................................................. 47 11.2.2.1. Reel Dimensions-Type 1…………..……………..………………… .......................................... 47 11.2.2.2. Carrier Tape Dimensions........................................................................................................ 47 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page3 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 11.2.2.3. Pin1 direction ......................................................................................................................... 47 11.2.2.4. Reel Dimensions-Type 2……………..………………………..… ............................................. 48 11.2.2.5. Carrier Tape Dimensions........................................................................................................ 48 11.2.2.6. Pin1 direction ......................................................................................................................... 48 12. 修訂記錄 ..................................................................................................................... 49 . © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page4 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 注意: 1、 本說明書中的內容,隨著產品的改進,有可能不經過預告而更改。請客戶及時到本公司網站下載更新 http://www.hycontek.com。 2、 本規格書中的圖形、應用電路等,因第三方工業所有權引發的問題,本公司不承擔其責任。 3、 本產品在單獨應用的情況下,本公司保證它的性能、典型應用和功能符合說明書中的條件。當使用在客戶 的產品或設備中,以上條件我們不作保證,建議客戶做充分的評估和測試。 4、 請注意輸入電壓、輸出電壓、負載電流的使用條件,使 IC 內的功耗不超過封裝的容許功耗。對於客戶在超 出說明書中規定額定值使用產品,即使是瞬間的使用,由此所造成的損失,本公司不承擔任何責任。 5、 本產品雖內置防靜電保護電路,但請不要施加超過保護電路性能的過大靜電。 6、 本規格書中的產品,未經書面許可,不可使用在要求高可靠性的電路中。例如健康醫療器械、防災器械、 車輛器械、車載器械及航空器械等對人體產生影響的器械或裝置,不得作為其部件使用。 7、 本公司一直致力於提高產品的品質和可靠度,但所有的半導體產品都有一定的失效概率,這些失效概率可 能會導致一些人身事故、火災事故等。當設計產品時,請充分留意冗餘設計並採用安全指標,這樣可以避 免事故的發生。 8、 本規格書中內容,未經本公司許可,嚴禁用於其他目的之轉載或複製。 . © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page5 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 1. 特點  傳感器的前置訊號處理設計  內建直流偏壓設計,可選擇 0,±1/8, ±1/4 , ±3/8,  具有 24-bitΣΔADC 類比數位轉換器 ±1/2,±5/8, ±3/4, ±7/8 倍 VREF 的偏置電壓  內置訊軌對軌(Rail-to-rail) OPAMP.  RMS Noise :  內置 VDDA 輸出可達 10mA 的傳感器驅動 1. 10 SPS 輸出速率時為 100nV (Gain = 128) 2. 7680 SPS 輸出速率時為 37uV (Gain = 1) 電源  外部晶體震盪器輸入或內部高精度 RC 震盪 3. 16 bit Noise-Free 的解析度 (Gain = 128, 器工作時脈切換選擇 VREF= 3.3V)  I2C 數據傳輸介面  參考電壓輸入可選擇使用輸入緩衝器  操作環境範圍  IRQ 功能  Rail-to-Rail OPAMP (HY3118 only)  數位電壓:2.2V to 3.6V  模擬電壓:2.4V to 3.6V  軌對軌信號輸入設計  操作電流:  具 1mA 輸出與輸入電流能力  內置線性穩壓器 VDDA 與參考電壓 REFO 1. 全速操作 1050uA(不含 OPAMP)  VDDA 可輸出電壓 2.4V、2.7V、3.0V 或 3.3V 2. 超低 Sleep 電流 1uA  操作溫度範圍 –40°C to +85°C  REFO 可輸出電壓 1.2V 或 1.5V  晶片內部方塊圖  I2C 傳輸介面 .  具標準或非標準通訊格式  FSCL = 400KHz  非標準模式具 ADC IRQ 功能  Sleep/Wake 功能(暫存器控制)  應用  Weight Scale  Strain Gauge  Pressure Scale  Industrial Process Control  封裝型式  24-bitsΣΔADC  內建前置放大器(PGA),可選擇增益 ×1, ×2, ×4, ×8, ×16, ×32, ×64, ×128。  SSOP16  MSOP10  可選擇不同的數據轉換輸出速率,最高可達 7680Sps。同時具備 10SPS 數據轉換輸出 速率時,可抑制 50/60Hz 的訊號干擾 Model No. Architecture Input Channels ENOB (Bits) HY3116 Sigma-Delta 2 20 HY3118 Sigma-Delta 4 20 © 2008-2016 HYCON Technology Corp www.hycontek.com RMS System Sample Noise Clock Rate(Max) 100nV Int. 327kHz/1Mhz 7680SPS (10SPS) 100nV Int. 327kHz/1Mhz 7680SPS (10SPS) Ext.4.9152MHz Rail-to-Rail OPAMP DC Offset Set Interface Package NO 4 bits IIC MSOP10 YES 4 bits IIC SSOP 16 DS-HY3118-V09_TC page6 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 2. 簡介 HY3118/HY3116 是一個高精度、低雜訊、低功率的 24-bit Analog-to-Digital 轉換器(ADC), 其內置的超低雜訊的可程編程前置放大器(PGA),在 1 倍的放大倍率下 ADC 具有 21bit 的有 效位數,而在增益 128 倍時最小分變訊號為 100nV 且增益的溫度系數小於 5 ppm/℃。另外, 還具有有兩組全差動訊號輸入通道、一組全差動參考電壓輸入通道、低雜訊放大器、參考電 壓輸入緩衝器、訊號輸入通道多工選擇器、可抑制 50/60 Hz 訊號干擾設計、輸入訊號零點直 流偏壓調整器等等功能。 在這顆晶片內還具有高性能可規劃輸出電壓的 VDDA 電壓源、低溫飄系數參考電壓源 ( low drift internal band gap reference )、可選擇外部時脈輸入或使用內建 RC 震盪時脈做為 工作頻率之功能、軌對軌 ( Rail-to-rail ) 低雜訊 OPAMP 及 I2C 等通訊介面。 此晶片可以使用內部 RC 震盪器或者外接震盪器進行操作,ADC 的數據轉換速度具有 10SPS ( 可抑制 50/60 Hz 訊號干擾 ) 到最快 7680 SPS。晶片功耗部分依數據轉換速率不 同存在不同的電流消耗,標準的操作電流為 1050uA 而休眠電流小於 1uA,而晶片的休眠與 喚醒方式採用 I2C 通訊介面控制特殊暫存器來達成。 此系列產品依功能別則可分為 SSOP16 與 MSOP10 兩種封裝型式。 LDO[1:0] . VDDA REFO LDO Bandgap Reference CKIN REFOS /5 /15 CKOUT 320 KHz SCL DCSET[3:0] HS ADGN[1:0] AN1 000 AN2 001 AN3 010 AN4 011 REFO 100 OPO 101 VSSA 110 0.1xVDD 111 SDA ENOP + AN3 - AN4 OP OPO PGA[2:0] OSR SI2 order ΣΔAD PGA 1bit AN1 AN1 AN2 AN3 AN4 REFO OPO VSSA 0.1xVDD OSCS 1MHz ENADC INN[2:0] AN2 VDD Comb Filter2 24bit ADCO[23:0] FRb SI+ 000 001 010 011 100 VRNS VRPS 101 110 V12 VDDA 111 VSSA V12 INP[2:0] VSSA REFP 01 REFN VSS 01 圖 1 晶片內部方塊圖 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page7 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 3. 引腳定義 3.1. 產品引腳圖 16 VDD VDDA 1 10 VDD VSSA 2 15 SCL VSSA 2 9 SCL OPO 3 14 SDA AIN1 3 8 SDA AIN1 4 13 CKOUT AIN2 4 7 VSS AIN2 5 12 CKIN REFO 5 6 REFP AIN3 6 11 VSS AIN4 7 10 REFN REFO 8 9 REFP HY3116 1 HY3118 VDDA 圖 3 MSOP10 引腳圖 圖 2 SSOP16 引腳圖 3.2. I/O 引腳定義 “I”輸入,“O”輸出,“S”史密斯觸發,“P”電壓源,“A”類比通道 引腳 名稱 引腳特性 功能說明 格式. 緩衝 SSOP16 MSOP10 1 1 VDDA P P Analog Power Supply: 2.4~3.6V 2 2 VSSA P P Analog Ground 3 - OPO O A Operational Amplifier 4 3 AIN1 I A Analog Input1 5 4 AIN2 I A Analog Input2 6 - AIN3 I A Analog Input3 7 - AIN4 I A Analog Input4 8 5 REFO O A Voltage Reference Output 9 6 REFP I A Reference Input (Positive) REFN I A Reference Input (Negative) 1 10 -* 11 7 VSS P P Digital Ground 12 - CKIN I A ADC Clock Input 13 - CKOUT O A ADC Clock Output 14 8 SDA I/O S I2C Data(Open-drain) 15 9 SCL I/O S I2C CLK(Open-drain) 16 10 VDD P P Digital Power Supply: 2.2~3.6V 1 * REFN 與 VSS 在 MSOP10 封裝時,連接在一起。 表 1 引腳定義與功能說明 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page8 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 3.2.1. SSOP 封裝片標記信息 XXXX HY3118 XXXXXX 紘康 Logo + 生產識別碼 產品名稱 : HY3118 產品批號 PIN 1 MARK 3.2.2. MSOP 封裝片標記信息 XXX 3118 . 紘康 Logo + 生產識別碼 產品名稱:3118 PIN 1 MARK © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page9 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 4. 應用電路 4.1. 橋式感測器 VDD AIN4 AIN3 VDDA 0.1uF REFP VDD 0.1uF 10k AIN1 10k MCU SDA HY3118 0.1uF AIN2 SCL REFN REFO 0.1uF VSSA VSS VSS . 圖 4 橋式感測器應用電路 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page10 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 5. 暫存器列表 5.1. 暫存器列表 暫存器 名稱 SYS 讀/寫 000h 上電復位 ADC1 讀/寫 001h 上電復位 ADC2 讀/寫 010h 上電復位 ADC3 讀/寫 011h 上電復位 ADC4 讀/寫 100h 上電復位 ADOH 讀/寫 上電復位 ADOM 讀/寫 101h 上電復位 ADOL 讀/寫 上電復位 位址 7 VRPS[1] R/W 0 OSCS[1] R/W 0 LDO[1] R/W 0 6 APO R/W 0 VRPS[0] R/W 0 OSCS[0] R/W 0 LDO[0] R/W 0 5 IRQEN R/W 0 INP[2] R/W 0 VRNS[1] R/W 0 FRb R/W 0 REFO R/W 0 R 0 R 0 R 0 R 0 R 0 R 0 R 0 R 0 R 0 位元組 4 3 2 1 0 ENADC ENLDO ENREFO ENOP R/W R/W R/W R/W 0 0 0 0 INP[1] INP[0] INN[2] INN[1] INN[0] R/W R/W R/W R/W R/W 0 0 0 0 0 VRNS[0] DCSET[3] DCSET[2] DCSET[1] DCSET[0] R/W R/W R/W R/W R/W 0 0 0 0 0 PGA[2] PGA[1] PGA[0] ADGN[1] ADGN[0] R/W R/W R/W R/W R/W 0 0 0 0 0 HS OSR[2] OSR[1] OSR[0] R/W R/W R/W R/W 0 0 0 0 ADOH R R R R R 0 0 0 0 0 ADOM R R R R R 0 0 0 0 0 ADOL ADST R R R R R 0 0 0 0 0 “-”:未使用, “R/W”:可讀寫, “R”:唯讀, “!”:保持 0 . 表 2 控制暫存器列表 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page11 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 5.2. 暫存器說明 5.2.1. SYS Register System configuration control register (8bit) 暫存器 位址 名稱 SYS 讀/寫 上電復位 000h 7 - 6 APO R/W 0 5 IRQEN R/W 0 位元組 4 3 ENADC ENLDO R/W R/W 0 0 2 ENREFO R/W 0 1 ENOP R/W 0 0 - 表 3 SYS 控制暫存器 APO[0] Auto Power off ENLDO[0] Enable LDO control Disable Disable Enable Enable IRQEN[0] SDA interrupt function ENREFO[0] Enable REFO control Disable SDA interrupt function Disable Enable SDA interrupt function Enable ENADC[0] ADC control ENOP[0] Enable rail-to-rail OPAMP Disable Disable Enable Enable 5.2.2. ADC1 Register ADC configuration control register 1(8bit) (ADC input select) 暫存器 位址 001h 名稱 ADC1 讀/寫 上電復位 7 - 6 - .5 INN[2] R/W 0 位元組 4 3 INN[1] INN[0] R/W R/W 0 0 2 INP[2] R/W 0 1 INP [1] R/W 0 0 INP [0] R/W 0 表 4 ADC1 控制暫存器 INN[2:0] Negative input voltage selection INP[2:0] Positive input voltage selection AIN1 AIN1 AIN2 AIN2 AIN3 AIN3 AIN4 AIN4 REFO REFO OPO OPO VSSA VSSA 0.1xVDD 0.1xVDD © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page12 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 5.2.3. ADC2 Register ADC configuration control register 2(8bit) 暫存器 位址 010h 名稱 ADC2 讀/寫 上電復位 7 VRPS[1] R/W 0 6 VRPS[0] R/W 0 位元組 4 3 VRNS[0] DCSET[3] R/W R/W 0 0 5 VRNS[1] R/W 0 2 DCSET[2] R/W 0 1 DCSET[1] R/W 0 0 DCSET[0] R/W 0 表 5 ADC2 控制暫存器 VRPS[1:0] Possitive reference voltage selection DCSET[3:0] DC offset input voltage selection Vrefp (Unbuffered) (VREF = REFP-REFN) VDDA 0 VREF Vrefp (buffered) +1/8 VREF Internal reference voltage V12 +1/4 VREF +3/8 VREF VRNS[1:0] Negative reference voltage selection Vrefn (Unbuffered) +1/2 VREF VSSA +5/8 VREF Vrefn (buffered) +3/4 VREF Internal reference voltage V12 +7/8 VREF 0 VREF -1/8 VREF -1/4 VREF -3/8 VREF -1/2 VREF -5/8 VREF -3/4 VREF -7/8 VREF . © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page13 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 5.2.4. ADC3 Register ADC configuration control register 3(8bit) 暫存器 位址 名稱 ADC3 讀/寫 上電復位 011h 7 OSCS[1] R/W 0 6 OSCS[0] R/W 0 位元組 4 3 PGA[2] PGA[1] R/W R/W 0 0 5 FRb R/W 0 2 PGA[0] R/W 0 1 ADGN[1] R/W 0 0 ADGN[0] R/W 0 表 6 ADC3 控制暫存器 OSCS[1:0] Oscillator source select PGA[2:0] Input signal gain for modulator Internal oscillator 327KHz PGA Disable Internal oscillator 1000KHz Gain = 8 External oscillator divider by 15 Reservations External oscillator divider by 5 Gain = 16 Reservations FRb [0] Full reference range select Full reference range input Reservations 1/2 reference range input Reservations Gain = 32 ADGN[1:0] Input signal gain for modulator . Gain = 1 Gain = 2 Reservations Gain = 4 5.2.5. ADC4 Register ADC configuration control register 3(8bit) 暫存器 位址 100h 位元組 名稱 ADC4 讀/寫 上電復位 7 LDO[1] R/W 0 6 LDO[0] R/W 0 5 REFO R/W 0 4 HS R/W 0 3 OSR[2] R/W 0 2 OSR[1] R/W 0 1 OSR[0] R/W 0 0 - 表 7 ADC4 控制暫存器 LDO[1:0] LDO output voltage selection OSR[2:0] ADC output rate select 3.3V 2560sps / 7680sps (128) 3.0V 1280sps / 3840sps (256) 2.7V 640sps / 1920sps (512) 2.4V 320sps / 960sps (1024) REFO[0] Reference voltage selection 160sps / 480sps (2048) REFO= 1.2V 80sps / 240sps (4096) REFO = 1.5V 40sps / 120sps (8192) 10sps / 30sps (32768) HS[0] High conversion rate Slow sampling rate (327KHz) High sampling rate (1000K Hz) © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page14 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 5.2.6. ADO Register ADC Output Code(24bit) 暫存器 位址 101h 名稱 ADOH 讀/寫 上電復位 ADOM 讀/寫 上電復位 ADOL 讀/寫 上電復位 7 6 5 R 0 R 0 R 0 R 0 R 0 R 0 R 0 R 0 R 0 位元組 4 3 ADOH R R 0 0 ADOM R R 0 0 ADOL R R 0 0 2 1 0 R 0 R 0 R 0 R 0 R 0 R 0 R 0 R 0 ADST R 0 表 8 ADO 控制暫存器 ADO[23:1] ADC output Code ADST[0] ADC output Code Status ADOH[7:0] ADC output Code of ADO[23:16] Information has been read ADOM[7:0] ADC output Code of ADO[15:8] Information is not read ADOL[7:1] ADC output Code of ADO[7:1] . © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page15 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 6. 電氣特性 6.1. ABSOLUTE MAXIMUM RATINGS Description HY3118/HY3116 UNIT VDD to VSS –0.3 to +3.6 V VDD to VSSA –0.3 to +3.6 V VSSA to VSS –0.3 to +0.3 V 100, Momentary mA Input Current 10, Continuous mA –0.3 to VDDA + 0.3 V –0.3 to VDD + 0.3 V +150 °C Operating Temperature Range –40 to +85 °C Storage Temperature Range –60 to +150 °C Analog Input Voltage to VSSA Digital Input Voltage to VSS Maximum Junction Temperature 表 9a 電氣特性表 . © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page16 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 6.2. ELECTRICAL CHARACTERISTICS All specifications at TA = –40°C to +85°C, VDDA = VDD = REFP = +3V, REFN = VSSA, and PGA*Gain=128, unless otherwise noted. HY3118/HY3116 PARAMETER CONDITIONS MIN TYP MAX UNIT Analog Inputs Full-Scale Input Voltage (VINP – VINN) VREF =VDDA, ±0.5*VREF/(PGA*Gain) V VDDA=3.3V, VREF =1V, ±0.9*VREF/(PGA*Gain) V Full-Scale Input Voltage (VINP – VINN) Negative Signal Input (VINN) VSSA-0.1 VDDA V Positive Signal Input (VINP) VSSA-0.1 VDDA V Common-Mode Input Range VSSA-0.1 VDDA V System Performance Resolution No Missing Codes 23 Bits Internal oscillator 1000KHz, OSR=32768, HS[0]=1b Internal oscillator 327KHz, 30 SPS 10 SPS fCLK/61440 SPS fCLK/491520 SPS 4 Conversions . OSR=32768, , HS[0]=0b Data Rate External Oscillator (1) , HS[0]=1b, Speed=High External Oscillator (1) , HS[0]=0b, Speed=Low Digital Filter Settling Time Full Settling Differential Input, End-Point Fit, G = 1, Integral Nonlinearity (INL) VIN=0.9*VR, delta VR~1.2V ±30 ±100 ppm Gain=1, ±50 ppm of FS Gain=128, ±3 ppm of FS Gain=1 2 uV/°C Gain=128, 20 nV/°C Input Offset Error Input Offset Drift Reference Buffer off, Input common voltage=VDDA/2 5 Gain Drift Reference Buffer on, Input common voltage=VDDA/2 50 ppm/°C 90 dB ±1Hz, fDATA = 10SPS External Oscillator 90 dB at DC, Input Voltage=VDDA/2± 0.1V 75 dB fIN = 50Hz or 60Hz Internal Oscillator Normal-Mode Rejection (1) Common-Mode Rejection © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page17 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC fDATA = 10SPS , Gain=128, 100 nV, rms fDATA = 7680SPS , Gain=1, 3700 nV, rms at DC,VDDA=3V±0.1V, Gain=1 60 dB at DC,VDDA=3V±0.1V, Gain=128 95 dB Input-Referred Noise Power-Supply Rejection Voltage Reference Input Voltage Reference Input (VREF) VREF = REFP – REFN VDDA V VSS-0.1 VDDA/2 V VDDA/2 VDDA+0.1 V Negative Reference Input (REFN) Positive Reference Input (REFP) Voltage Reference Input Current Input buffer on 10 nA IL = 0mA, ENLDO[0]=1b, LDO[1:0]=00b 45 uA LDO[1:0]=00b 3.3 V IL = 0.1mA, LDO[1:0]=01b 3.0 V ENLDO[0]=1b, LDO[1:0]=10b . 2.7 V VDD≧VDDA+0.2V LDO[1:0]=11b 2.4 V LDO[1:0]=00b 130 mV LDO[1:0]=01b 140 mV IL = 10mA, LDO[1:0]=10b 155 mV ENLDO[0]=1b, LDO[1:0]=11b 175 mV TA=-40[1:0℃ 50 PPM/[ ±0.2 %/V 45 uA Power System VDDA operation current VDDA output voltage VDDA Dropout voltage IL = 0.1mA, VDDA temperature drift ENLDO[0]=1b, LDO[1:0]=11b IL = 0.1mA, VDDA voltgage drift ENLDO[0]=1b, LDO[1:0]=11b REFO operation current VDD=2.5V~3.6V IL = 0mA, ENREFO[0]=1b, REFO[0]=1b IL = 10uA, REFO[0]=0b 1.2 V ENREFO[0]=1b REFO[0]=1b 1.5 V REFO output voltage, VREFO REFO output voltage with load IL = ±200uA, ENREFO[0]=1b 0.98 1.02 VREFO IL = 10uA, REFO temperature drift ENREFO[0]=1b © 2008-2016 HYCON Technology Corp www.hycontek.com TA=-40EFO[0 50 PPM/E DS-HY3118-V09_TC page18 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC IL = 10uA, REFO voltgage drift ENREFO[0]=1b VDDA=2.4V~3.6V 100 uV/V Internal RC Oscillator Low speed oscillator frequency Internal oscillator, 327KHz, TA=25℃ 290 327 360 KHz Low speed oscillator VDD=2.2V~3.6V 0.5 % 2 % Voltage drift Low speed oscillator TA=-40ature temperature drift High speed oscillator frequency Internal oscillator, 1000KHz, TA=25℃ 900 1000 1100 KHz High speed oscillator VDD=2.2V~3.6V 1 % TA=-40ature 2 % Voltage drift High speed oscillator temperature drift Digital Digital inputs_SCL 0.7 VDD VDD + 0.1 V Digital inputs_S 0.7 VDD 3.7 V VSS 0.2 VSS V VIH Logic Levels . VIL VOH IOH = 1mA VOL IOL = 1mA Input Leakage V VDD – 0.4 0.2 VDD 0 < VIN < VDD V 0.1 nA 4.9152 MHz External Clock Input Frequency (fCLKIN) Serial Clock Input Frequency (fSCLK) 5 MHz (1). HY3116 不支援外部震盪器功能. 表 9b 電氣特性表 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page19 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC All specifications at VDD=3.6V, internal VDDA, Internal Oscillator enable, unless otherwise noted. HY3118/HY3116 PARAMETER CONDITIONS MIN TYP UNIT MAX Power Supply Power-Supply Voltage (VDDA, VDD) 2.4 3.6 V VDDA=2.4V, Gain=1 180 μA VDDA=2.4V, Gain=128 530 μA VDDA=3.0V, Gain=1 180 μA VDDA=3.0V, Gain=128 550 μA Analog Supply Current I, VDDA=3.3V, Gain=1 180 μA Internal oscillator 327KHz, VDDA=3.3V, Gain=128 570 μA OSR=32768, HS[0]=0b, Reference input buffer fDATA = 10SPS (VRPS[1:0]=VRNS[1:0]=10b) 30 μA VDDA=2.4V, Gain=1 440 μA VDDA=2.4V, Gain=128 1110 μA Analog Supply Current II, VDDA=3.0V, Gain=1 450 μA Internal oscillator 1000KHz, VDDA=3.0V, Gain=128 1150 μA OSR=32768, HS[0]=1b, VDDA=3.3V, Gain=1 460 μA fDATA = 30SPS VDDA=3.3V, Gain=128 1180 μA VDDA=2.4V, Gain=1 270 μA VDDA=2.4V, Gain=128 630 μA VDDA=3.0V, Gain=1 276 μA 650 μA Analog Supply Current III, . External Oscillator 4.9152MHz, VDDA=3.0V, Gain=128 OSR=32768, HS[0]=0b, VDDA=3.3V, Gain=1 280 μA fDATA = 10SPS VDDA=3.3V, Gain=128 670 μA VDDA=2.4V, Gain=1 520 μA VDDA=2.4V, Gain=128 1150 μA VDDA=3.0V, Gain=1 560 μA 1215 μA Analog Supply Current IV, External Oscillator 4.9152MHz, VDDA=3.0V, Gain=128 OSR=32768, HS[0]=1b, VDDA=3.3V, Gain=1 570 μA fDATA = 30SPS VDDA=3.3V, Gain=128 1240 μA ENLDO[0]=ENADC[0]= VDD = 2.4V 0.6 μA ENOP[0]=0b, 0.75 μA Power down current VDD = 3.6V 表 9c 電氣特性表 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page20 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 6.3. OPAMP, Electrical Specification All specifications at VDD=3V, internal VDDA, Internal Oscillator enable, unless otherwise noted. Sym. Parameter VDDA Power supply VOUT Output range Test Conditions Min. Typ. Max. unit 2.4 3.6 V 0 VDDA V 0 VDDA V Input common VINC range IOA OA current Each OA μA 70 VDDA = 3.0V, Output current 0.3V < Output voltage < VDDA-0.3V IOA_LOAD 1 mA 0.5 mA 1000 pF loading (push or VDDA = 2.4V, pull) 0.3V < Output voltage < VDDA-0.3V Max output CLOAD capacitor load Reference input RFB resistance Ω 5K Switch turn on RSW . resistance 300 Ω SR ADC input clock Loading R=10K, C=100pF 0.6 V/ms GOPEN Open loop gain Loading C=100pF 100 dB bandwidth Loading C=100pF 1000 KHz PM Phase margin Loading C=100pF 68 Deg GM Gain margin 18 dB NVIN AINx Input refer Vin= 1.2V, 1KHz 220 nV/V0= noise 75 nV/Vn= Unit gain UGB VOS Vin= 1.2V, 10KHz Offset error ±25 mV Power supply PSRR rejection ratio Vout=1.2V, ΔVDD = 100mV, at DC 70 dB Vout=1.2V, ΔVIN= 100mV, at DC 70 dB Common mode CMRR rejection ratio © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page21 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 7. ENOB and Noise-Free 下表列出典型的雜訊規格表與 Gain 及 DATA RATE 等關係。測試條件設定在 DD=3.3V, VDDA=3.0V,ADC 參考電壓差為 VDDA/2,ADC 等效輸入阻抗以 1K Loadcell 短路下, 取樣 1024 筆資料所得測試結果。 ΣΔADC Noise Performance with Output rate/GAIN at VDDA=3.0V, VREF=1.5V Output rate (sps) 10 Max. Vin(mV) =0.9*VREF (1) Gain = PGA × ADGN ENOB (RMS Bit) RMS Noise (nV) Noise Free (Bit) PEAK-TO-PEAK Noise (nV) 2389 1246 690 347 120 105 17.54 17.56 17.33 17.29 16.80 16.00 15699 7810 4594 2345 829 729 100 15.23 619 7045 3439 1960 1009 312 267 245 39153 21075 11539 5664 1810 1474 1352 36854 20172 10915 5332 1685 1416 1363 15.96 16.02 15.92 15.81 15.47 14.78 13.89 13.48 13.38 13.30 13.25 12.93 12.23 11.40 13.57 13.51 13.31 13.36 12.95 12.27 11.35 47382 22550 12163 6518 2069 1665 1554 262213 140432 74202 38456 12057 9772 8694 247636 128579 73940 35838 11822 9466 8969 ±1350 ±675 ±338 ±169 ±42 ±21 1 2 4 8 32 64 = = = = = = 1 1 1 8 32 32 × × × × × × 1 2 4 1 1 2 20.26 20.20 20.05 20.04 19.59 18.79 ±11 128 = 32 × 4 17.82 18.70 ±1350 1 = 1 × 1 18.73 ±675 2 = 1 × 2 18.54 ±338 4 = 1 × 4 80 18.50 ±169 8 = 8 × 1 18.19 ±42 32 = 32 × 1 17.42 ±21 64 = 32 × 2 16.55 ±11 128 = 32 × 4 16.22 ±1350 1 = 1 × 1 16.11 ±675 2 = 1 × 2 15.99 ±338 4 = 1 × 4 2560 16.01 ±169 8 = 8 × 1 15.66 ±42 32 = 32 × 1 14.95 ±21 64 = 32 × 2 14.08 ±11 128 = 32 × 4 16.31 ±1350 1 = 1 × 1 16.18 ±675 2 = 1 × 2 16.07 ±338 4 = 1 × 4 7680 16.10 ±169 8 = 8 × 1 15.76 ±42 32 = 32 × 1 15.01 ±21 64 = 32 × 2 14.07 ±11 128 = 32 × 4 (1) Max.Vin (mV) is the max. input voltage of single end to analog ground (AVSS). . 表 10 轉換頻率與倍數特性表 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page22 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC RMS Noise 與 Peak-to-Peak Noise 是指輸入端晶片本身所產生的 Noise,RMS Noise 是指晶片 ADC 的輸入 Noise,而本規格所使用的 Peak-to-Peak Noise 是在 1000 筆內(±3.3 個標準差)的最大與最小 Noise 的差值。 ENOB = In RMSFSR Noise Noise - Free Bits = In 2 In Peak-toFSR -Peak Noise In 2 RMS Noise Diagram RMS Noise Diagram 300 Gain=1 Output rate ~ 10sps 4 3 Output Code (LSB) Occurrence 250 5 Gain=1 Output rate ~ 10sps 200 150 100 2 1 0 -1 -2 -3 50 -4 0 -5 -5 -4 -3 -2 -1 0 1 2 3 4 5 1 201 Output Code (LSB) 401 601 LSB base on 21-bit output 1001 LSB base on 21-bit output 圖 5 RMS Noise Diagram 圖 6 Output Code Diagram RMS Noise Diagram RMS Noise Diagram 400 350 801 Time (reading number) 5 . Gain=128 Output rate ~ 10sps Gain=128 Output rate ~ 10sps 4 3 Output Code (LSB) Occurrence 300 250 200 150 100 2 1 0 -1 -2 -3 50 -4 -5 0 -5 -4 -3 -2 -1 0 1 2 3 4 5 LSB base on 18-bit output 圖 7 RMS Noise Diagram © 2008-2016 HYCON Technology Corp www.hycontek.com 1 201 401 601 801 1001 Time (reading number) Output Code (LSB) LSB base on 18-bit output 圖 8 Output Code Diagram DS-HY3118-V09_TC page23 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 8. I2C 通訊協議 VCC  支援 ADC IRQ 向量  兩線式通訊介面  fSCL=400KHz  地址定義 0xA0h  低功耗通訊介面 HY3118/HY3116 IRQ / SDA 10KΩ MCU 10KΩ SCL 圖 9 通訊介面連接示意圖 通訊方式採用彈性化的 I2C 的架構,使用時可規劃成 ADC 轉換完畢後具有 IRQ 通知 或無 IRQ 通知以達到不同的應用方式。當通訊協議設置在無 IRQ 模式,對於 ADC 轉換 完成的讀取時間必須由使用者自行計算;當通訊協議設置在具 IRQ 模式,則 ADC 轉換 完成會有 IRQ 的脈衝信號。 IRQ 的脈衝信號會由 I2C 通訊引腳的 SDA 來產生,設置在此模式時 SDA 在資料傳 送結束後引腳會因外部上拉電阻而處於高電位,待 ADC 轉換完成後會在 SDA 產生一個 低電位的脈衝信號以達到通知用戶的目的。當 SDA 為低電位時,其消耗電流則依上拉電 阻值與 VCC 電壓所計算。 在未啟動 IRQ 模式時,使用者可以讀取暫存器 ADO[ADST]的狀態來判斷 ADC 輸出 . 資料是否已經讀取過,而 ADC 輸出資料與 ADO[ADST]的狀態更新時間只發生在未對 ADO 暫存器讀取時;因此在未啟動 IRQ 模式下,當 ADC 中斷發生時,若正好在讀取 ADO 暫存器,則 ADC 的輸出資料與 ADO[ADST]的狀態將保留上一次狀態而不會被更 新。 晶片地址固定在 0xA0 即是 device address[6:0] = 1010000b。 8.1. I2C 通訊時序圖 HY3118/HY3116 的 I2C 從機端通訊格式說明如下圖所示,其細分為: a. 有效資料定義 ( Data Validity ) b. 開始與停止定義 ( Start and Stop Definition ) c. ACK 回應信號定義 ( ACK Definition ) d. IRQ 中斷信號定義 ( IRQ Definition ) e. 波形描述定義 ( Wave Definition ) f. 暫存器的寫入 ( Write Register ) g. 暫存器的讀取 ( Read Register ) h. 重新讀取暫存器 ( Reread Register ) i. 暫存器的寫入確認 ( Write Register then Read Register ) j. 中斷 IRQ 的 ADO 暫存器讀取 ( IRQ Read Register ) k. 復位晶片 (Call Chip Reset) © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page24 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 有效资料定義(Data Validity Definition) SCL LINE SDA LINE 穩定資料 (Data Stable) 資料“1” (Data“1”) 穩定資料 (Data Stable) 資料“0” (Data“0”) 圖 10 通訊 I2C 有效資料波形 開始與停止定義(Start and Stop Definition) . 開始 (Start) 停止 (Stop) 圖 11 通訊 I2C 開始與停止波形 ACK 回應信號定義(ACK Definition) SCL LINE 1 7 8 *1 9 SDA LINE 開始 (Start) *1 回應 (ACKNOWLEDGE) 主控端(Master)向從機端(Slave)發送 SCL 信號 的至第8個時鐘時,主控端的 SDA 引 腳必須由輸出狀態轉為輸入狀態,以接收從機端產生的回應(ACK)信號。 從機端(Slave)設置具ADC IRQ中斷信號功能時,主控端的 SDA 引腳必須設置為輸入狀 態,以待接收從機端產生的 IRQ 低電位脈衝信號。 圖 12 通訊 I2C 回應信號波形 (ACK) © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page25 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC MACK 傳送信號定義( MACK Definition ) *1 SCL LINE 8 7 1 9 SDA LINE 傳送 MACK ( MASTER ACKNOWLEDGE ) 開始 ( Start ) * 1 MACK發生在讀取Word Address=05h (ADO), 須連續讀取3bytes資料輸出時, 當DATA2/DATA3要輸出 資料前, 須在第9個CLOCK上升緣之前, 由主控端(Master)控制SDA為輸出引腳, 設定輸出為Low, 通知從 機端(Slave)得以繼續輸出DATA2/DATA3資料. 圖 13 通訊 I2C 傳送信號波形 (MACK) IRQ 中斷信號定義(IRQ Definition) SCL LINE *1 . SDA LINE *1 回應 (ACK) 停止 (Stop) IRQ 中斷 (ADC) 開始 (Start) 圖 14 通訊 I2C 中斷信號波形 ( IRQ ) © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page26 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 波形描述定義(Wave Definition) Stop ACK R/W Start Device Address SCL LINE SDA LINE 停止(Stop) 回應(ACK) Stop ACK Write Start Device Address 寫入(Write) “0” “0”或“1” “1” “0”或“1” “0” “0”或“1” 開始(Start) “1” SDA LINE 圖 15 波形描述定義 暫存器的寫入(Write Register) . *2 Word Address SDA LINE Stop Write Start Device Address Word Data *3 ACK LSB MSB ACK LSB MSB ACK LSB R/W MSB *2 *3 當寫入的 Word Address 大於 04h,將得不到 ACK 回應且Word Address 的值不會被改變 I2C 通訊終止操作,必須先 Stop 再重新 Start 才可繼續進行通訊。 此4個位元寫入的值必須為“0”,以免晶片發生誤動作。 圖 16 通訊 I2C 暫存器的寫入 暫存器的讀取( Read Register) *6 Word Data 1 *3 SDA LINE *4 *5 NACK LS B 當讀取的 Word Address 在 00h ~ 04 h 之間, 傳回的資料只有 Word Data 1; Word Data 3 MS B MAC K LS B MS B MAC K LS B MS B AC K R/ W LS B MS B *6 AC K LS B *5 MS B AC K R/ W LS B MS B *4 Word Data 2 St o p Read Device Address St ar t Word Address Write St art Device Address 。 當讀取 Word Address 在 05h( ADO ) 的值, 則傳回的資料有 Word Data 1+ Word Data 2+ Word Data 3。當需要傳回Data2/Data3資料, 則MACK須由主控端設定為Low 當讀取的 Word Address 大於 06h, 將得不到 ACK 回應且 Word Address 的值不會被改變 I2 C 通訊終止操作 , 必須先 Stop 再重新 Start 才可繼續進行通訊。 圖 17 通訊 I2C 暫存器的讀取 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page27 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 重新讀取暫存器( Reread Register) *6 *3 SDA LINE *4 *5 *5 NACK LS B Word Data 3 *4 MS B M AC K LS B Word Data 2 Word Data 3 St op Read Start Word Data 1 MS B M AC K LS B MS B AC K R/ W LS B MS B AC K LS B MS B AC K R/ W LS B MS B Device Address Word Data 2 St o p Word Data 1 Read Device Address S t ar t Word Address Writ e S t art Device Address *7 SDA LINE NACK LS B MS B M ACK LS B MS B M ACK LS B MS B ACK R/ W LS B MS B *7 當讀取過指定的 Word Address , 再次讀取時無須重新指定 Word Address 即可進行讀取 。 圖 18 通訊 I2C 重新讀取暫存器 暫存器的寫入確認 ( Write Register then Read Register) Stop Writ e Start Device Address *1 Word Address Word Data *2 SDA LINE ACK St op Word Data 3 LSB . MSB Word Data 2 ACK LSB Read Word Data 1 MSB ACK R/ W LSB MSB St art Device Address *7 *3 SDA LINE NACK LS B MS B MACK LS B MS B MACK LS B MS B ACK R/ W LS B MS B *7 *4 當寫入過指定 Word Address 的 Word Data, 接著進行讀取時無須再次指定 Word Address 即可進行讀取 。 圖 19 通訊 I2C 暫存器的寫入確認 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page28 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 中斷 IRQ的 ADO 暫存器讀取( IRQ Read Register) *6 ADC Interrupt Start Word Data Word ADC0(00h) Stop Write Start Device Address SDA LINE I RQ *6 ADO[15:8] ADO[23:16] Stop Device Address Read Word ADO( 05h) Start Write Start Device Address ACK LS B MS B AC K LSB MS B AC K R/ W LSB M SB ADC Interrupt ADO[7:0] SDA LINE NACK LS B Stop Word Data 3 Word Data 2 Word Data 1 MS B M ACK LS B MS B MACK LS B MS B ACK R/ W LS B MS B Read Start Device Address ACK LS B MS B ACK R/ W LS B MS B I RQ ADC Interrupt SDA LINE NACK LS B MS B M ACK LS B MS B M ACK LS B MS B ACK R/ W LS B MS B IRQ 圖 20 中斷 IRQ 的 ADO 暫存器讀取 復位晶片 ( Call Chip Reset ) St op Star t 00 h 06 h . SDA LINE AC K LS B MSB AC K LS B MSB 圖 21 通訊 I2C 復位晶片 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page29 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 9. Overview 9.1. 系統工作頻率與低功耗 ( Frequency vs. Low Power mode )  可選擇內部或外部震盪器 OSCS[1:0] HS[0]  低速 RC 震盪器 327KHz  高速 RC 震盪器 1000KHz 327KHz RC  外接震盪器經除頻 5 倍分頻器 1000KHz RC  外接震盪器經除頻 15 倍分頻器  可編程工作頻率及 ΣΔADC 取樣頻率  ÷15 除 頻 器 低功耗模式設計 四 選 一 多 工 器 系統時脈源 System Clock ( OSC ) ÷5  晶片休眠模式  自動關閉模式(Auto Power Off) 圖 22 系統時脈方塊圖 透過設置暫存器 OSCS[1:0] 選擇系統時脈(同 ADC 的取樣頻率)以產生系統工作 頻率 OSC。另外,當 ΣΔADC 的取樣頻率操作在 327KHz 以上時,必須將暫存器 HS[0] 設置為 “1” 以得切換至高速模式。當 ΣΔADC 切換至高速模式時,會增加晶片耗電流。 暫存器 OSC OSCS[1:0] 00 01 10 11 HS[0] 0 1 0/1 0/1 1000KHz EXO ÷ 15 EXO ÷ 5 System Clock 327KHz . ADC Sample Rate 0/1:System Clock 除頻後超過 327KHz 時,設置 “1”。 EXO:外部震盪器頻率 表 11 系統工作時脈與 ADC 取樣頻率 當考慮 AC 電源產生的 50/60Hz 干擾時,需選用外部震盪頻率源且建議外接晶體震 盪器 Crystal 的頻率為 4.9152MHz。主要原因在於內部 RC 震盪器具有 5% 的誤差, 會導致抑制 AC 電源干擾設計效果不佳。 晶片具有兩種低功耗的模式,分別為自動關閉與休眠模式。  使用者預計在最近一筆 ADC 資料轉出後關閉晶片即可啟用自動關閉模式:  測量模式下將 APO[0] 設置 “1” 以啟用自動關閉功能。  APO[0] 設置 “1” 後,ADC 會在最近一次轉換輸出 ADO[23:0]並自動將 ENLDO[0] 與 ENADC[0] 設置 “0” 以關閉晶片電源使晶片進入休眠模式。   I2C 通訊介面本身為低功耗設計,需注意具上拉電阻引腳不可處於低電位。 休眠模式消耗電流會降至 1uA 以下,使用者按以下說明進行設置即可使得晶片進入該模式:  暫存器 ENADC[0] 設置 “0”,關閉內/外震盪器。  暫存器 ENOP[0]、ENLDO[0] 與 ENREFO[0] 設置 “0” ,關閉運算放大器 OPAMP、 VDDA 與 REFO。  I2C 通訊介面本身為低功耗設計,需注意具上拉電阻引腳不可處於低電位 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page30 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 9.2. VDDA 電源 ( Low Dropout Regulator )  10mA 負載驅動能力  可外部輸入電壓方式設計  可編程輸出電壓  低溫度係數 低溫飄係數的可編程輸出線性穩壓器 VDDA,其為 ADC、OPAMP、輸入緩衝器的 電壓源且具有可編程輸出電壓及 10mA 負載能力的特色,加上採用低溫飄係數電路設計 故非常適合用於驅動小電流的傳感器。 當測量系統需要使用共同電源時,亦可關閉 VDDA 而採用外部輸入電壓方式來驅動。 將 ENLDO[0] 設置 “1” 即可啟用 VDDA,且透過暫存器 LDO[1:0] 可選擇 VDDA 的輸 出電壓值。 暫存器 ENLDO[0]* LDO 1 LDO[1:0] VDDA* 1 1 1 1 1 0 0 0 0 00 01 10 11 00 01 10 11 3.3V 3.0V 2.7V 2.4V off/EXT 1 * off/EXT:VDDA 無輸出電壓,此時容許外部輸入電壓 表 12 VDDA 輸出電壓值設置表 9.3. REFO 參考電壓 ( Reference Voltage )  200uA 負載驅動能力  可編程輸出電壓 .  可外部輸入電壓方式設計  低溫度係數 低溫飄係數的可編程輸出 REFO 參考電壓,其為類比電路共地電源且具有可編程輸 出電壓及 200uA 負載能力的特色,加上採用低溫飄係數電路設計故適合用於當成參考電 壓源。 當測量系統需要使用共同參考電源時,亦可關閉 REFO 而採用外部輸入電壓方式來 驅動。將 ENREFO[0] 設置 “1” 即可啟用 REFO,且透過暫存器 REFO[0] 可選擇 REFO 的輸出電壓值。 暫存器 REFO ENREFO[0]* REFO[0] REFO* 1 1 1 1 0 0 0 1 0 1 1.2V 1.5V off/EXT 1 * off/EXT:REFO 無輸出電壓,此時容許外部輸入電壓 表 13 REFO 輸出電壓值設置表 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page31 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 9.4. 輸入通道多工器與中斷 IRQ ( Input Channel Multiplex with IRQ )  彈性化的測量與參考信號輸入多工器  ADC 轉換數據箝制輸出的穩定時間計算  輸入多工器網路切換設計與 ADC 轉換數據  ADC 轉換數據完成回應 IRQ 功能 箝制功能 VRPS[1:0] VRNS[1:0] INP[2:0] INN[2:0] AIN1 AIN2 000 001 AIN1 SI+ AIN2 010 AIN3 010 AIN4 011 AIN4 011 ACM 100 ACM 100 OPO 101 OPO 101 VSS 110 VSS 110 111 0.1*vdd 00 01 REFPB 10 ACM 11 REFN 00 001 AIN3 0.1*vdd REFP VDDA 000 SI- REFP REFP REFPB 111 REFN REFN VSSA 01 REFNB 10 ACM 11 VRP VRN REFNB 測量信號輸入網路 參考電壓輸入網路 圖 23 輸入通道多工器 信號輸入具彈性化多工器網路切換設計,當輸入網路控制器發生切換後內置的資料轉 . 換箝制器將發生作用,該箝制器主要作用是使得 ADO[23:0]暫存器等待 ADC 轉換數據穩 定後資料才被更新,而資料更新穩定時間的計算方式如下: 1 1 ADC ≅ 128 × ADC + 4 × ADC ……………………………………………………..(式 1) t Stable f OSCS f OSR ADC t Stable : ADC網路切換後的穩定時間 ADC f OSCS : ADC取樣頻率 ADC f OSR :ADC轉換頻率 此時,若將 ADC4[7:0] 的 IRQEN 設置 1,則當 ADC 資料轉換完畢後會將數據 寫入 ADO[23:0] 並於 SDA 引腳產生 IRQ 信號。IRQ 信號為一低電位脈衝信號,當 主控端接收到此脈衝信號後即可讀取 ADO[23:0] 暫存器的內容。 必須注意,輸入通道多工器的設置一旦進行切換、正輸負輸入短路或交換、參考電壓 ADC 變更,都需要 tStable 的時間 ADC 才會輸出正確的轉換數據或產生中斷回應 IRQ。 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page32 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 9.5. 參考電壓輸入與參考電壓 ( Reference Voltage input Chancel with VREF )  全差動信號輸入設計  軌對軌信號輸入電壓準位 ( Rail-to-Rail )  低溫飄係數 ( Low-Drift ) 與低噪聲設計 (Low-Noise)  可編程參考電壓衰減倍率  具輸入緩衝器設計  輸入阻抗匹配關係 圖 24 參考電壓輸入與衰減器 參考電壓具全差動輸入設計,且內置的可編程輸入衰減器具低飄移 ( Low-Drift )、低 噪聲( Low-Noise ) 的特性。 參考電壓輸入透過輸入多工器 VRPS[1:0] 與 VRNS[1:0]可選擇合適的信號輸入通道。 如下表所示: 暫存器 通道 VRPS[1:0] / VRNS[1:0] . 00 01 10 11 VRP REFP VDDA REFPB V12 *1 VRN REFN VSSA REFNB V12 *1 V12: internal reference voltage 1.2V. 表 14 測量信號輸入設置對照表 參考電壓由引腳 REFP 與 REFN 輸入後產生△VREF 電壓差,再經可編程參考電壓 衰減器控制暫存器 FRb[0] 選擇衰減倍率產生 ΣΔADC 的產考電壓 VREF,且 REFP 輸 入電壓必須高於 REFN。 暫存器 GREF Gain FRb[0] 0 1 1 1/2 表 15 參考電壓輸入衰減器倍率對照表 參考電壓 VREF 計算如下: ∆VREF = VREFP − VREFN ………………………………………………………………..(式 2) VREF = GREF × ∆VREF ……………………………………………………………....(式 3) DVREF : 外部輸入引腳產生的電壓差值 VREFP、VREFN:外部輸入引腳電壓值(VREFP > VREFN) GREF:參考電壓輸入衰減器 VREF:ADC內部參考電壓值 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page33 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 另外,REFP / REFN 的輸入阻抗設計值為 500KΩ,且 REFP 或 REFN 的輸入電壓 不可小於 VSS -100mV,也不可超過 VDDA +100mV;透過設置 VRP / VRN 的輸入為 REFPB / REFNB 可增加 REFP 跟 REFN 的輸入阻抗,但必須注意當使用輸入緩衝器 時 REFP 輸入電壓不得小於 1.2V;而 REFN 輸入電壓不得大於 VDDA - 1.2V。 信號端 VRP VRN 引腳端 REFP VSSA - 0.1V ≦ REFP ≦ VDDA + 0.1V REFN VSSA - 0.1V ≦ REFN ≦ VDDA + 0.1V REFPB VSSA + 0.15V ≦ REFN ≦ VDDA – 1.2V REFNB VSSA + 1.2V ≦ REFP ≦ VDDA – 0.15V 表 16 參考電壓輸入限制特性表 . © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page34 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 9.6. 測量信號輸入通道與可編程信號放大器 ( Signal Input Channel with PGA )  全差動信號輸入設計  可編程輸入信號放大倍率  軌對軌信號輸入電壓準位 ( Rail-to-Rail )  輸入信號零點偏移設計  低溫飄係數 ( Low-Drift ) 與低噪聲設計  最小分辨信號 100nVRMS ( Low-Noise ) INP[2:0] INN[2:0] ADGN[1:0] PGA[2:0] AIN1 AIN2 AIN3 AIN4 ACM OPO VSS 0.1*vdd 000 001 010 011 100 101 110 111 INP SI+ SI- PGA ADGN 000 001 010 011 100 101 110 111 x½,x1,x3,x4 AIN1 AIN2 AIN3 AIN4 ACM OPO VSS 0.1*vdd INN 圖 25 信號輸入與放大器 信號量測具全差動輸入設計亦可實現單端信號測量應用,且內置的可編程輸入放大器 . PGA 具低飄移 ( Low-Drift )、低噪聲( Low-Noise ) 的特性,當信號放大倍率達 128 倍 ( PGA 設置 32 倍、ΣΔAD 設置 4 倍)時,最小的信號輸入分辨率可達 100nVRMS 。 輸入信號透過多工器可分別連接至 SI+ 或 SI- 通道,多工器的控制暫存器為 INP[2:0] 與 INN[2:0]。 暫存器 通道 INP[2:0] / INN[2:0] 000 001 010 011 100 101 110 111 SI+ AIN1 AIN2 AIN3 AIN4 REFO OPO VSSA 0.1*VDD SI- AIN1 AIN2 AIN3 AIN4 REFO OPO VSSA 0.1*VDD 表 17 測量信號輸入設置對照表 輸入信號的放大倍率則由 PGA 與 ΣΔAD 的增益組成,而放大倍率的選擇與輸入電 壓的範圍,如表 18、表 19、表 20 所示,不同的 PGA 與 ΣΔAD 的增益組成所產生的 輸入阻抗如表 21 所示: 暫存器 PGA Gain PGA[2:0] 000 001 010 011 100 101 110 111 off 8 - 16 - - - 32 表 18 輸入信號 PGA 放大倍率對照表 暫存 器 ΣΔA D Gain © 2008-2016 HYCON Technology Corp www.hycontek.com ADGN[1:0] 00 01 10 11 1 2 - 4 DS-HY3118-V09_TC page35 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 表 19 輸入信號 ΣΔAD 放大倍率對照表 信號端 SI+ 引腳端 SI- AIN0 AIN1 VSSA - 0.1V ≦ AIN0 ~ AIN3 ≦ VDDA + 0.1V AIN2 AIN3 VDDA 2.3V ≦ VDDA ≦ 3.6V REFO 1.0V ≦ REFO ≦ 1.5V 表 20 參考電壓輸入限制特性表 Sensor output Gain = PGA × ADGN × FRb 1 = 1 × 1 × 1 200 2 = 1 × 2 × 1 100 4 = 1 × 4 × 1 32 32 = 8 × 4 × 1 4 64 = 16 × .4 × 1 2 128 = 32 × 4 × 1 1 impedance(KΩ) 表 21 輸入阻抗對照表 +23 bit = 7FFFFFh + 7/8 VREF 輸入信號滿量程發生溢位 + 3/4 VREF ADC 溢位 ADC 未溢位 + 5/8 VREF VREF 輸入信號滿量程未溢位 + 1/2 VREF + 3/8 VREF 輸入信號範圍 ( Full Scale ) + 1/4 VREF + 1/8 VREF 0 - 1/8 VREF - 1/4 VREF - 3/8 VREF VREF 另外,為了因應不同測量的應用輸入 信號皆具有零點偏移功能 ( 平移調整 ); 即是透過改變輸入信號零點的位置,以 改善因為傳感器輸入偏移電壓過大而導 致最大測量範圍溢出的現象。下圖為一 測量訊號取 16-bit( ±15-bit ) 的示意圖, 輸入信號未做零點偏移調整時在滿量程 部分存在溢位現象,而在做了調整 -1/4 VREF 零點偏移準位後可使得測量信號 滿量程時不會發生溢位。 輸入信號範圍 ( Full Scale ) +15 bit = 7FFFh -15 bit = 8000h - 1/2 VREF - 5/8 VREF - 2/4 VREF - 7/8 VREF -23 bit = 800000h 圖 26 取 16-bit 有效位發生溢位的處理方式示意圖 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page36 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 9.7. 梳狀濾波器 ( COMB Filter )  三階梳狀濾波器   可編程的超取樣頻率 AC 頻率干擾抑制設計 ΣΔADC 採用三階的數位濾波器設計,透過設置 OSR[2:0] 可得到不同的數據轉換頻 率。 暫存器 OSR[2:0] OSR OSR 000 001 010 011 100 101 110 111 128 256 512 1024 2048 4096 8192 32768 表 22 超取樣頻率除頻表 OSCS / HS 00 01 10 11 OSCS[1:0] OSR OSR[2:0] 0 1 1 0 HS[0] 000 2500 7812.5 7680 2560 EXO:外接 4.9152MHz 001 1250 3906.2 3840 1280 石英震盪器 010 625 1953.1 1920 640 011 312.5 976.5 960 320 100 156.2 488.2 480 160 101 78.1 244.1 240 80 110 39 122 120 40 111 9.7 30.5 30 10 . 表 23 ΣΔADC 超取樣轉換頻率對照表 如果外接震盪器使用 4.9152MHz 的震盪器則 ΣΔADC 數據轉換有 2560、640、80 和 10Hz 的輸出頻率。圖 27 10SPS 頻率響應圖抑制了 AC 電源的 50/60Hz 干擾。 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page37 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 圖 28 80SPS 頻率響應圖 圖 27 10SPS 頻率響應圖 . 圖 29 10/80SPS 頻率響應圖 © 2008-2016 HYCON Technology Corp www.hycontek.com 圖 30 10SPS 頻率響應放大圖 DS-HY3118-V09_TC page38 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 9.8. 數據轉換格式 ( Data Conversion Format )  ADO 暫存器  兩極性輸出  24-bit 資料長度  二補數格式 ADO 暫存器為存放梳狀濾波器轉換完成的數據,其存放外部輸入訊號的轉換值於 ADO[23:0]。圖 31 為 ADO[23:0]的數據格式,其 ADO[23:1]為 ADC 的轉換輸出而 ADO[0] 位元為 ADO 被讀取的狀態旗標 ADST[0];下圖為 ADO[23:0]的數據格式。 ADO[23:0] ADCL[6:0] ADCM[14:7] ADCH[23:15] 高位元 MSB 低位元 LSB Analog to Digital Convert Data 23-bit 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 符號位 7 6 5 4 3 2 1 0 ADST 資料更新判斷旗標 0:已讀取 1:未讀取 數據轉換長度 16bit ( ±15-bit) 數據轉換長度 17bit ( ±16-bit) ……………… 圖 31 ADO 資料轉換格式 ADO[23:0] 等效待測信號 十六進制 二進制 7F FF FE 0111-1111 1111-1111 1111-111x △11*(1/2 ) 00 00 02 0000-0000 0000-0000 0000-001x 0 00 00 00 0000-0000 0000-0000 0000-000x -0000-000 ) FF FF FE 1111-1111 1111-1111 1111-111x -111 80 00 00 1000-0000 0000-0000 0000-000x △進制 兩極性輸出 22 二補數格式 22 . 表 24 ADO[23:0]與輸入信號關係表 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page39 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 9.9. 軌對軌運算放大器 ( Rail-to-Rail OPAMP )   軌對軌信號輸入設計 具 1mA 輸出與輸入電流能力 軌對軌運算放大器 Rail-to-Rail OPAMP 設計,其具 90dB 的直流增溢 ( DC gain ) 及 70dB 的 CMRR 設計,最大可推動 1uF 的電容負載而運算放大器的輸入信號的電 壓範圍出如下表所示。 信號 OPAMP 輸入電壓範圍 OPAMP OPP VSSA ≦ OPP ≦ VDDA OPN VSSA ≦ OPN ≦ VDDA 表 25 參考電壓輸入限制特性表 另外,運算放大器 OPO 的輸出電壓小於 0.3V 或是大於 VDDA - 0.3V。此時,運 算放大器的輸出阻抗就會增加,下圖是將運算放大器接成單倍增益緩衝器 ( unit gain buffer ) 時 OPO 輸出電壓呈現的輸出阻抗變化曲線圖。 Ron Max . Min 0.3 VDDA-0.3 Vout 圖 32 OPO 輸出組抗變化圖 使用軌對軌運算放大器時,使用者只要將暫存器 ENOP[0] 設置 “1” 即可啟用。在 使用運算放大器的同時必須注意確認 VDDA 是處於開啟的狀態,且透過暫存器 INP[2:0]、INN[2:0] 的設置才能使得 ADC 測量到 OPO 的輸出信號。 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page40 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 10. 訂貨資訊 下單品名 1 HY3118-E016 1 封裝型式 SSOP 封裝型式 出貨包裝 個裝 材料 描述方式 形式 數量 組成 Tube 100 Green 引腳數 16 E 016 HY3118-E016 SSOP 16 E 016 Tape & Reel 2500 Green HY3116-M010 MSOP 10 M 010 Tape & Reel 3000 Green MSL2 3 MSL-3 3 MSL-3 3 MSL-3 產品名稱 – 封裝型式描述方式(標準品) 例如:您的需求是 HY3118 封裝片 SSOP16 出貨,則下單品名為 HY3118-E016, 且需以 Tube 出貨,則除下單品名外,請特別註明出貨包裝形式為 Tube 例如:您的需求是 HY3116 封裝片 MSOP10 出貨,則下單品名為 HY3116-M010, 且需以 Tape & Reel 出貨,則除下單品名外,請特別註明出貨包裝形式為 Tape & Reel 2 MSL: 濕度敏感性等級係依據 IPC/JEDEC J-STD-020 的規範加以試驗分級,並參考 IPC/JEDEC J-STD-033 的標準處理、包裝、運輸與使用。 3 Green (RoHS & no Cl/Br): . HYCON 產品皆為 Green Product,符合 RoHS 指令,REACH 高關注物質(SVHC) 以及無鹵素相關規定。 © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page41 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 11. 封裝型式資訊 11.1. SSOP16 11.1.1. Package Dimensions D 9 b e 8 0.25 . A A2 c 1 E E1 16 GAUGE PLANE SEATING PLANE A1 L SYMBOLS MIN NOM MAX A - - 1.75 A1 0.10 0.15 0.25 A2 - - 1.50 b 0.20 - 0.30 c 0.18 - 0.25 D 4.80 4.90 5.00 E1 3.81 3.91 3.99 E 5.79 5.99 6.20 L 0.41 - 1.27 e θ° 0 0.635 BASIC - 8 Note: 1. All dimensions refer to JEDEC OUTLINE MO-137. 2. Do not include Mold Flash or Protrusions. 3. Unit : mm © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page42 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 11.1.2. Tube Dimensions . © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page43 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 11.1.3. Tape & Reel Information 11.1.3.1. Reel Dimensions-Type 1……………..………………..………………….. Unit : mm A W1 11.1.3.2. Carrier Tape Dimensions P2 D0 . F W E P0 B0 K0 A0 P1 R0.30MAX Reel SYMBOLS Carrier Tape Dimensions Dimensions A W1 A0 B0 K0 P0 P1 P2 E F D0 W Spec. 330 12.5 6.90 5.40 2.00 4.00 8.00 2.00 1.75 5.50 1.50 12.00 Tolerance +6/-3 +1.5/-0 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.05 ±0.10 ±0.05 +0.1/-0 ±0.30 Note: 10 Sprocket hole pitch cumulative tolerance is ±0.20mm. Unit : mm 11.1.3.3. Pin1 direction © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page44 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 11.1.3.4. Reel Dimensions-Type 2………………………………………….……….. Unit : mm A W1 11.1.3.5. Carrier Tape Dimensions P2 D0 F W E P0 B0 . K0 A0 P1 R0.30MAX Reel SYMBOLS Carrier Tape Dimensions Dimensions A W1 A0 B0 K0 P0 P1 P2 E F D0 W Spec. 330 12.5 6.50 5.20 2.10 4.00 8.00 2.00 1.75 5.50 1.50 12.00 Tolerance +6/-3 +1.5/-0 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.05 ±0.10 ±0.05 +0.1/-0 ±0.30 Note: 10 Sprocket hole pitch cumulative tolerance is ±0.20mm. Unit : mm 11.1.3.6. Pin1 direction © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page45 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 11.2. MSOP10 11.2.1. Package Dimensions D 1 E 6 E1 10 5 . A c A2 0.25 e b A1 GAUGE PLANE SEATING PLANE L L1 SYMBOLS MIN NOM MAX *Note: A - - 1.10 1.All dimensions refer to JEDEC OUTLINE MO -187. A1 0.00 0.10 0.15 2.Do not include Mold Flash or Protrusions. A2 0.75 0.85 0.95 Unit : mm b 0.17 0.20 0.27 c 0.08 0.15 0.23 D 3.00 BASIC E1 3.00 BASIC E 4.90 BASIC L 0.40 0.60 L1 0.95 REF e 0.50 BASIC θ° 0 © 2008-2016 HYCON Technology Corp www.hycontek.com - 0.80 8 DS-HY3118-V09_TC page46 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 11.2.2. Tape & Reel Information 11.2.2.1. Reel Dimensions-Type 1…………..……………..……………………….. Unit : mm A W1 11.2.2.2. Carrier Tape Dimensions P2 D0 E P0 W F 8ºMAX . P1 B0 Reel SYMBOLS K0 8ºMAX A0 Carrier Tape Dimensions Dimensions A W1 A0 B0 K0 P0 P1 P2 E F D0 W Spec. 330 12.5 5.30 3.40 1.40 4.00 8.00 2.00 1.75 5.50 1.50 12.00 Tolerance ±2.00 ±1.50 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.05 ±0.10 ±0.05 +0.1/-0 ±0.20 Note: 10 Sprocket hole pitch cumulative tolerance is ±0.20mm. Unit : mm 11.2.2.3. Pin1 direction © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page47 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 11.2.2.4. Reel Dimensions-Type 2……………..………………………..………….. Unit : mm A W1 11.2.2.5. Carrier Tape Dimensions P2 D0 E P0 W F 8ºMAX B0 . P1 Reel SYMBOLS K0 8ºMAX A0 Carrier Tape Dimensions Dimensions A W1 A0 B0 K0 P0 P1 P2 E F D0 W Spec. 330 12.5 5.20 3.30 1.20 4.00 8.00 2.00 1.75 5.50 1.50 12.00 Tolerance ±2.00 ±1.50 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.05 ±0.10 ±0.05 +0.1/-0 ±0.30 Note: 10 Sprocket hole pitch cumulative tolerance is ±0.20mm. Unit : mm 11.2.2.6. Pin1 direction © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page48 HY3118/HY3116 24-Bit Analog-to-Digital Convert High Resolution ΣΔADC 12. 修訂記錄 以下描述本文件差異較大的地方,而標點符號與字形的改變不在此描述範圍。 版本 頁次 V01 V02 V03 All All All V04 4 15 V05 4 19 39 21 23 24-26 39 32-33 9 41 43 44~45 47~48 V06 V07 V08 V09 變更摘要 初版發行 描述與功能修訂 增加產品比較表 修改 REFO 名稱 修改電氣特性內容 增加 ADO[ADST]使用說明 增加訂貨資訊內容 修正錯別字描述 更正特點內容中的產品對照表 增加 Internal RC Oscillator 規格表 修正比較表, ENOB 錯誤描述 更新表 10 轉換頻率與倍數特性表單位 MSOP10 封裝形式修訂 . 增加說明, 晶片地址”固定” 增加圖 13 通訊 I2C 傳送信號波形(MACK)內容 更新圖 17~圖 21 說明(ACK --> MACK) 更新 SSOP16 封裝型式資訊 新增輸入阻抗對照表 新增封裝型式與正印說明 更新 Green (RoHS & no Cl/Br) 新增 Tube Dimensions 新增 Tape & Reel Information 新增 Tape & Reel Information © 2008-2016 HYCON Technology Corp www.hycontek.com DS-HY3118-V09_TC page49
HY3116-M010 价格&库存
很抱歉,暂时无法提供与“HY3116-M010”相匹配的价格&库存,您可以联系我们找货
HY3116-M010
  • 1+13.74048
  • 10+13.23158
  • 100+11.70486
  • 500+11.39951
