MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
RE series
Low impedance and high frequency.
Endurance: +105°C 2,000~4,000 hours
RE 105 C
1808
Suitable for switching power, UPS, power sources, etc.
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+105°C
Rated Voltage Range
6.3~100 V dc
Capacitance Tolerance
±20%(M)
Leakage Current
I≤0.01CV or 3μA, whichever is greater.
Where, I:Max.leakage current (μA),C:Nominal capacitance (μF),V: Rated voltage (V)
(at 20°C,120Hz)
Rated Voltage(V dc )
Dissipation Factor (tanδ)
6.3
10
16
25
35
0.22 0.19 0.16 0.14 0.12
tanδ (max.)
50
63
100
0.10
0.09
0.08
(at 20°C after 2 minutes)
When nominal capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase. (at 20°C,120Hz)
Low Temperature
Characteristics
(Max. Impedance Ratio)
6.3
10
Z(-25°C)/Z(+20°C)
4
3
Z(-40°C)/Z(+20°C)
8
6
16
25
35
50
63
100
2
4
3
(at 120Hz)
The following specifications listed below shall be met when the capacitors are restored to 20°C after DC voltage plus rated
ripple current is applied for a specified period of time at 105 °C.
Endurance
Capacitance Change
Case Dia.(mm)
≤±25% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
≤The initial specified value
ØD≤6.3
ØD=8&10
ØD≥12.5
Load life (hours)
2,000
3,000
4,000
The following specifications shall be satisfied when the capacitors are restored to 20°C after leaving them under no load
at 105°C for 1,000 hours.
Shelf Life
Capacitance Change
≤ ± 25% of the initial value
D.F. (tanδ)
Leakage Current
DIMENSIONS[mm]
Sleeve(Violet)
Ød
ØD'
F±0.5
L'
4min.
15min.
( Ø 5~ Ø 12.5)
ØD
5
6.3
Ød
0.5
0.5
F
ØD'
L'
2.0
2.5
8
0.5
0.6
3.5
10
12.5
0.6
0.6
5.0
5.0
Ø D+0.5max.
L+2max.
PART NUMBERING SYSTEM
E
RE 1H
M 330 E11 O- -
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
Cap.(μF)
120
1k
10k
100k
Cap.
很抱歉,暂时无法提供与“ERE1KM221K20OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.19472
- 20+1.08805
- 100+0.98138
- 500+0.87471
- 1000+0.82493
- 2000+0.78937
- 国内价格
- 5+1.58825
- 50+1.27872
- 150+1.14599
