MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
CD11GC series
Endurance: +130 °C 4,000~5,000 hours
CD11GC 130 C
1808
+105 °C 15,000~20,000 hours
Withstand high temperature, extremely long life
Suitable for output circuit and input circuit of LED driving power, electronic ballast and electronic energy saving lamp.
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+130°C(160~450 V dc )
Rated Voltage Range
160~450 V dc
Capacitance Tolerance
±20%(M)
(at 20°C,120Hz)
160~400 V dc
450 V dc
I≤0.02CV+10μA
I≤0.03CV+10μA
Leakage Current
Where, I: Max.leakage current (μA),C:Nominal capacitance (μF),
V: Rated voltage (V)
(at 20°C after 2 minutes)
Rated Voltage(V dc )
160
200
250
350
400
450
tanδ (max.)
0.15
0.15
0.15
0.20
0.20
0.20
160
200
250
350
400
450
Z(-25°C)/Z(+20°C)
3
3
3
5
5
6
Z(-40°C)/Z(+20°C)
6
6
6
6
6
9
Dissipation Factor (tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20°C,120Hz)
(at 120Hz)
The specifications listed below shall be met when the capacitors are restored to 20°C after DC voltage plus rated ripple current
is applied for a specified period of time at 130°C or 105°C, the peak voltage shall not exceed the rated voltage.
Endurance
Capacitance Change
≤±30% of the initial value
D.F. (tanδ)
≤300% of the initial specified value
Leakage Current
≤The initial specified value
Height
(mm)
L≤10
L>10
130°C
Load life (hours)
105°C
Load life (hours)
4,000
5,000
15,000
20,000
The following specifications shall be satisfied when the capacitors are restored to 20°C after leaving them under no load
at 105°C for 1,000 hours.
Shelf Life
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
DIMENSIONS[mm]
ØD
Ød
Ød
ØD'
F±0.5
L'
4min.
15min.
( Ø 8~ Ø 18)
F
ØD'
L'
8
0.5
0.6
3.5
10
12.5
16
18
0.6
0.6
0.8
0.8
5.0
5.0
7.5
7.5
Ø D+0.5max.
L+2max.
Radial Type
Sleeve(Dark Green)
PART NUMBERING SYSTEM
E
GC 2G
M 3R3 G16 O- -
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
Rated voltage(Vdc)
160~450
120
1k
10k
100k
0.50
0.80
0.90
1.00
98
CD11GC series
STANDARD RATINGS (Rated ripple current:mArms/130°C 100kHz)
WV
(Vdc)
Cap
(µF)
Cap
(µF)
Size
Rated ripple
current
ΦDxL (mm)
PartNumber
70
EGC2CM3R3F12OT
1
8×12
49
EGC2VM010F12OT
4.7
8×12
77
EGC2CM4R7F12OT
1.5
8×16
73
EGC2VM1R5F16OT
8×16
82
EGC2CM5R6F16OT
8×16
75
EGC2VM1R8F16OT
10×9
80
EGC2CM5R6G09OT
10×9
65
EGC2VM1R8G09OT
8×16
88
EGC2CM6R8F16OT
10×9
75
EGC2VM2R2G09OT
10×9
145
EGC2CM8R2G09OT
10×16
90
EGC2VM2R2G16OT
10×16
183
EGC2CM8R2G16OT
2.8
10×16
95
EGC2VM2R8G16OT
10×9
190
EGC2CM100G09OT
3.3
10×16
100
EGC2VM3R3G16OT
10×16
223
EGC2CM100G16OT
4.7
10×20
142
EGC2VM4R7G20OT
15
22
10×16
300
EGC2CM150G16OT
10×20
152
EGC2VM5R6G20OT
10×20
400
EGC2CM220G20OT
12.5×20
165
EGC2VM5R6W20OT
33
12.5×20
480
EGC2CM330W20OT
10×20
190
EGC2VM6R8G20OT
47
12.5×25
590
EGC2CM470W25OT
12.5×20
200
EGC2VM6R8W20OT
68
16×25
750
EGC2CM680L25OT
12.5×20
205
EGC2VM8R2W20OT
82
16×25
825
EGC2CM820L25OT
12.5×20
250
EGC2VM100W20OT
16×25
960
EGC2CM101L25OT
12.5×25
270
EGC2VM100W25OT
18×20
960
EGC2CM101M20OT
12.5×25
335
EGC2VM150W25OT
150
18×30
1050
EGC2CM151M30OT
16×20
335
EGC2VM150L20OT
220
18×35
1500
EGC2CM221M35OT
16×25
450
EGC2VM220L25OT
2.8
8×12
64
EGC2DM2R8F12OT
16×30
535
EGC2VM330L30OT
3.3
8×12
73
EGC2DM3R3F12OT
16×35
555
EGC2VM330L35OT
8×16
126
EGC2DM4R7F16OT
18×30
700
EGC2VM470M30OT
10×9
100
EGC2DM4R7G09OT
18×35
750
EGC2VM470M35OT
10×12
126
EGC2DM4R7G12OT
18×40
900
EGC2VM680M40OT
8×16
148
EGC2DM5R6F16OT
8×12
54
EGC2GM010F12OT
10×9
120
EGC2DM5R6G09OT
8×16
60
EGC2GM010F16OT
8×16
160
EGC2DM6R8F16OT
8×16
73
EGC2GM1R5F16OT
10×9
145
EGC2DM6R8G09OT
8×16
75
EGC2GM1R8F16OT
10×16
200
EGC2DM6R8G16OT
10×9
65
EGC2GM1R8G09OT
10×9
165
EGC2DM8R2G09OT
10×9
76
EGC2GM2R2G09OT
10×16
203
EGC2DM8R2G16OT
10×16
92
EGC2GM2R2G16OT
10×9
215
EGC2DM100G09OT
10×16
100
EGC2GM2R8G16OT
10×16
230
EGC2DM100G16OT
10×16
105
EGC2GM3R3G16OT
10×20
245
EGC2DM100G20OT
10×20
120
EGC2GM3R3G20OT
15
10×20
327
EGC2DM150G20OT
10×20
142
EGC2GM4R7G20OT
22
12.5×20
430
EGC2DM220W20OT
12.5×20
150
EGC2GM4R7W20OT
33
12.5×20
500
EGC2DM330W20OT
5.6
12.5×20
165
EGC2GM5R6W20OT
12.5×25
650
EGC2DM470W25OT
6.8
12.5×20
225
EGC2GM6R8W20OT
16×20
650
EGC2DM470L20OT
8.2
12.5×20
230
EGC2GM8R2W20OT
16×25
750
EGC2DM680L25OT
10
12.5×25
280
EGC2GM100W25OT
16×30
900
EGC2DM820L30OT
12.5×25
335
EGC2GM150W25OT
18×25
900
EGC2DM820M25OT
16×20
335
EGC2GM150L20OT
16×30
1100
EGC2DM101L30OT
16×25
480
EGC2GM220L25OT
18×25
1100
EGC2DM101M25OT
16×30
500
EGC2GM220L30OT
150
2.2
18×35
1350
EGC2DM151M35OT
33
18×30
635
EGC2GM330M30OT
8×12
64
EGC2EM2R2F12OT
47
18×35
750
EGC2GM470M35OT
2.8
8×12
72
EGC2EM2R8F12OT
68
18×40
900
EGC2GM680M40OT
3.3
8×12
80
EGC2EM3R3F12OT
18×50
1030
EGC2GM101M50OT
4.7
8×16
133
EGC2EM4R7F16OT
100
1.5
8×16
70
EGC2WM1R5F16OT
10×9
120
EGC2EM5R6G09OT
1.8
8×16
74
EGC2WM1R8F16OT
10×16
150
EGC2EM5R6G16OT
2.2
10×16
77
EGC2WM2R2G16OT
10×16
169
EGC2EM6R8G16OT
2.8
10×16
80
EGC2WM2R8G16OT
10×9
165
EGC2EM8R2G09OT
10×16
88
EGC2WM3R3G16OT
10×16
203
EGC2EM8R2G16OT
10×20
92
EGC2WM3R3G20OT
10×16
238
EGC2EM100G16OT
4.7
10×20
104
EGC2WM4R7G20OT
10×20
250
EGC2EM100G20OT
5.6
12.5×20
144
EGC2WM5R6W20OT
15
10×20
327
EGC2EM150G20OT
6.8
12.5×20
175
EGC2WM6R8W20OT
22
12.5×20
430
EGC2EM220W20OT
8.2
12.5×20
183
EGC2WM8R2W20OT
12.5×25
530
EGC2EM330W25OT
10
12.5×20
225
EGC2WM100W20OT
16×20
530
EGC2EM330L20OT
15
12.5×25
294
EGC2WM150W25OT
16×25
690
EGC2EM470L25OT
16×25
395
EGC2WM220L25OT
18×20
690
EGC2EM470M20OT
16×30
420
EGC2WM220L30OT
16×30
780
EGC2EM680L30OT
33
18×30
500
EGC2WM330M30OT
18×25
780
EGC2EM680M25OT
47
18×35
615
EGC2WM470M35OT
82
18×25
900
EGC2EM820M25OT
68
18×40
710
EGC2WM680M40OT
100
18×30
970
EGC2EM101M30OT
100
18×50
840
EGC2WM101M50OT
8.2
10
100
4.7
5.6
6.8
8.2
10
47
68
82
100
5.6
6.8
8.2
10
250(2E)
WV
(Vdc)
8×12
6.8
200(2D)
PartNumber
3.3
5.6
160(2C)
Size
Rated ripple
current
ΦDxL (mm)
33
47
68
1.8
2.2
5.6
350(2V)
6.8
8.2
10
15
22
33
47
68
1
1.5
1.8
2.2
2.8
3.3
400(2G)
4.7
15
22
3.3
450(2W)
22
99
很抱歉,暂时无法提供与“EGC2WM8R2W20OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.24673
- 10+0.20182
- 30+0.18258
- 100+0.12724
- 500+0.11655
- 1000+0.11013
