MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
CD11GAS series
Upgrade
Miniaturized, long life
Endurance: +105 °C 8,000~10,000 hours
CD11GA
CD11GAS 105 C
1808
CD11GAS
RoHS Compliant
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-40~+105°C
Rated Voltage Range
140~500 V dc
Capacitance Tolerance
±20%(M)
(at 20°C,120Hz)
140~400 V dc
450~500 V dc
I≤0.02CV+10μA
I≤0.03CV+10μA
Leakage Current
Where, I: Max.leakage current (μA),C:Nominal capacitance (μF),
V: Rated voltage (V)
(at 20°C after 2 minutes)
Rated Voltage(V dc )
140
160
200
250
315
350
400
450
500
tanδ (max.)
0.15
0.15
0.15
0.15
0.20
0.20
0.20
0.20
0.24
140
160
200
250
315
350
400
450
500
Z(-25°C)/Z(+20°C)
3
3
3
3
5
5
5
6
6
Z(-40°C)/Z(+20°C)
6
6
6
6
6
6
6
9
15
Dissipation Factor (tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20°C,120Hz)
(at 120Hz)
The specifications listed below shall be met when the capacitors are restored to 20°C after DC voltage plus the rated ripple current
is applied for 10,000 hours at 105°C(WV:500V for 8,000 hours),the peak voltage shall not exceed the rated voltage.
Endurance
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤200% of the initial specified value
Leakage Current
≤The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20°C after leaving them under no load
at 105°C for 1,000 hours.
Shelf Life
Capacitance Change
D.F. (tanδ)
Leakage Current
DIMENSIONS[mm]
Ød
ØD'
F±0.5
L'
4min.
15min.
( Ø 6.3~ Ø 22)
ØD
6.3
Ød
0.5
F
ØD'
L'
2.5
8
0.5
0.6
3.5
10
12.5
16
18
22
0.6
0.6
0.8
0.8
0.8
5.0
5.0
7.5
7.5
10
Ø D+0.5max.
L+2max.
Radial Type
Sleeve(Violet)
PART NUMBERING SYSTEM
E
GW 2G
M 3R3 F09 O- -
T
Sleeve Code: “C” for PVC, “T” for PET
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
RATED RIPPLE CURRENT MULTIPLIERS
Frequency correction factor for ripple current
Freq.(Hz)
Rated voltage(Vdc)
140~500
120
1k
10k
100k
0.50
0.80
0.90
1.00
110
CD11GAS series
STANDARD RATINGS (Rated ripple current: mArms/105°C 100kHz)
WV
(Vdc)
140(2A)
Cap
(µF)
Size
ΦD×L(mm)
10
Rated ripple
current
PartNumber
6.3×12
115
EGW2AM100E12OT
15
6.3×12
145
EGW2AM150E12OT
22
8×12
270
EGW2AM220F12OT
33
10×12
380
EGW2AM330G12OT
47
8×20
480
EGW2AM470F20OT
68
10×20
570
EGW2AM680G20OT
100
12.5×16
710
EGW2AM101W16OT
150
12.5×25
980
EGW2AM151W25OT
220
16×20
1320
EGW2AM221L20OT
6.3×7
36
EGW2CM010E07OT
6.3×9
40
EGW2CM010E09OT
6.3×7
40
EGW2CM1R5E07OT
6.3×9
45
EGW2CM1R5E09OT
6.3×7
45
EGW2CM1R8E07OT
6.3×9
50
EGW2CM1R8E09OT
6.3×7
50
EGW2CM2R2E07OT
6.3×9
55
EGW2CM2R2E09OT
6.3×9
70
EGW2CM2R8E09OT
6.3×12
78
EGW2CM2R8E12OT
6.3×9
85
EGW2CM3R3E09OT
6.3×12
92
EGW2CM3R3E12OT
6.3×9
92
EGW2CM4R7E09OT
6.3×12
97
EGW2CM4R7E12OT
6.3×9
96
EGW2CM5R6E09OT
6.3×12
100
EGW2CM5R6E12OT
6.3×9
100
EGW2CM6R8E09OT
6.3×12
107
EGW2CM6R8E12OT
8×9
107
EGW2CM6R8F09OT
6.3×12
150
EGW2CM8R2E12OT
8×9
150
EGW2CM8R2F09OT
8×9
190
EGW2CM100F09OT
8×12
240
EGW2CM100F12OT
8×9
270
EGW2CM150F09OT
8×12
290
EGW2CM150F12OT
8×12
390
EGW2CM220F12OT
10×12
430
EGW2CM220G12OT
33
10×16
520
EGW2CM330G16OT
47
10×16
680
56
10×20
Size
ΦD×L(mm)
PartNumber
8×9
120
EGW2DM5R6F09OT
8×12
126
EGW2DM5R6F12OT
8×9
126
EGW2DM6R8F09OT
8×12
132
EGW2DM6R8F12OT
8×9
180
EGW2DM8R2F09OT
8×12
200
EGW2DM8R2F12OT
8×9
190
EGW2DM100F09OT
8×12
230
EGW2DM100F12OT
8×16
310
EGW2DM150F16OT
10×12
310
EGW2DM150G12OT
10×16
475
EGW2DM220G16OT
10×20
650
EGW2DM330G20OT
12.5×16
650
EGW2DM330W16OT
12.5×16
880
EGW2DM470W16OT
12.5×20
980
EGW2DM470W20OT
12.5×25
1300
EGW2DM680W25OT
16×20
1380
EGW2DM820L20OT
16×20
1420
EGW2DM101L20OT
16×25
1494
EGW2DM101L25OT
16×25
1680
EGW2DM151L25OT
16×30
1989
EGW2DM151L30OT
220
18×30
2150
EGW2DM221M30OT
330
18×35
2250
EGW2DM331M35OT
6.3×7
45
EGW2EM010E07OT
6.3×9
50
EGW2EM010E09OT
6.3×7
50
EGW2EM1R2E07OT
6.3×9
55
EGW2EM1R2E09OT
6.3×7
55
EGW2EM1R5E07OT
6.3×9
60
EGW2EM1R5E09OT
6.3×7
61
EGW2EM1R8E07OT
6.3×9
70
EGW2EM1R8E09OT
6.3×9
72
EGW2EM2R2E09OT
6.3×12
81
EGW2EM2R2E12OT
6.3×9
81
EGW2EM2R8E09OT
6.3×12
88
EGW2EM2R8E12OT
6.3×9
102
EGW2EM3R3E09OT
6.3×12
112
EGW2EM3R3E12OT
EGW2CM470G16OT
6.3×9
112
EGW2EM4R7E09OT
800
EGW2CM560G20OT
6.3×12
115
EGW2EM4R7E12OT
10×20
950
EGW2CM680G20OT
8×9
115
EGW2EM4R7F09OT
12.5×16
1060
EGW2CM680W16OT
8×12
120
EGW2EM4R7F12OT
82
12.5×20
1260
EGW2CM820W20OT
8×9
120
EGW2EM5R6F09OT
100
12.5×20
1350
EGW2CM101W20OT
8×12
126
EGW2EM5R6F12OT
12.5×25
1750
EGW2CM151W25OT
8×9
145
EGW2EM6R8F09OT
16×20
1790
EGW2CM151L20OT
8×12
150
EGW2EM6R8F12OT
220
16×25
2130
EGW2CM221L25OT
8×12
200
EGW2EM8R2F12OT
330
18×30
2520
EGW2CM331M30OT
8×16
260
EGW2EM8R2F16OT
470
18×35
2880
EGW2CM471M35OT
8×12
220
EGW2EM100F12OT
6.3×7
45
EGW2DM010E07OT
8×16
275
EGW2EM100F16OT
6.3×9
50
EGW2DM010E09OT
8×16
350
EGW2EM150F16OT
6.3×7
50
EGW2DM1R2E07OT
10×12
360
EGW2EM150G12OT
6.3×9
55
EGW2DM1R2E09OT
10×16
480
EGW2EM220G16OT
6.3×7
55
EGW2DM1R5E07OT
10×20
500
EGW2EM220G20OT
6.3×9
60
EGW2DM1R5E09OT
10×20
600
EGW2EM330G20OT
6.3×7
60
EGW2DM1R8E07OT
12.5×16
600
EGW2EM330W16OT
6.3×9
66
EGW2DM1R8E09OT
12.5×20
660
EGW2EM330W20OT
6.3×9
72
EGW2DM2R2E09OT
12.5×16
880
EGW2EM470W16OT
6.3×12
81
EGW2DM2R2E12OT
12.5×20
980
EGW2EM470W20OT
6.3×9
81
EGW2DM2R8E09OT
12.5×25
1180
EGW2EM680W25OT
6.3×12
88
EGW2DM2R8E12OT
16×20
1250
EGW2EM680L20OT
6.3×9
105
EGW2DM3R3E09OT
16×20
1320
EGW2EM820L20OT
6.3×12
112
EGW2DM3R3E12OT
16×20
1360
EGW2EM101L20OT
6.3×12
115
EGW2DM4R7E12OT
16×25
1420
EGW2EM101L25OT
8×9
117
EGW2DM4R7F09OT
8×12
120
EGW2DM4R7F12OT
1.5
1.8
2.2
2.8
3.3
4.7
5.6
6.8
8.2
10
15
22
68
150
1
1.2
1.5
1.8
200(2D)
Cap
(µF)
Rated ripple
current
1
160(2C)
WV
(Vdc)
2.2
2.8
3.3
4.7
5.6
6.8
8.2
10
15
22
200(2D)
33
47
68
82
100
150
1
1.2
1.5
1.8
2.2
2.8
3.3
4.7
5.6
250(2E)
6.8
8.2
10
15
22
33
47
68
82
100
111
CD11GAS series
WV
(Vdc)
Cap
(µF)
150
250(2E)
315(2F)
Size
ΦD×L(mm)
Rated ripple
current
PartNumber
16×30
1820
EGW2EM151L30OT
WV
(Vdc)
Cap
(µF)
Size
Rated ripple
current
ΦD×L(mm)
PartNumber
6.3×12
90
EGW2GM2R8E12OT
18×25
1820
EGW2EM151M25OT
8×9
90
EGW2GM2R8F09OT
220
18×30
2150
EGW2EM221M30OT
8×12
94
EGW2GM2R8F12OT
330
18×40
2310
EGW2EM331M40OT
6.3×12
90
EGW2GM3R3E12OT
2.2
6.3×9
82
EGW2FM2R2E09OT
8×9
100
EGW2GM3R3F09OT
3.3
6.3×12
100
EGW2FM3R3E12OT
8×12
102
EGW2GM3R3F12OT
4.7
8×9
120
EGW2FM4R7F09OT
8×10
110
EGW2GM4R7F10OT
5.6
8×12
142
EGW2FM5R6F12OT
8×12
120
EGW2GM4R7F12OT
6.8
8×12
162
EGW2FM6R8F12OT
10×9
120
EGW2GM4R7G09OT
8.2
8×12
194
EGW2FM8R2F12OT
10×12
128
EGW2GM4R7G12OT
10
10×12
230
EGW2FM100G12OT
8×12
145
EGW2GM5R6F12OT
15
10×16
340
EGW2FM150G16OT
10×12
156
EGW2GM5R6G12OT
22
10×20
460
EGW2FM220G20OT
8×12
172
EGW2GM6R8F12OT
33
47
12.5×20
600
EGW2FM330W20OT
8×16
206
EGW2GM6R8F16OT
12.5×25
680
EGW2FM470W25OT
10×12
206
EGW2GM6R8G12OT
6.3×9
55
EGW2VM010E09OT
10×12
220
EGW2GM8R2G12OT
6.3×12
60
EGW2VM010E12OT
10×16
232
EGW2GM8R2G16OT
6.3×9
60
EGW2VM1R2E09OT
10×16
253
EGW2GM100G16OT
6.3×9
65
EGW2VM1R5E09OT
10×20
275
EGW2GM100G20OT
6.3×12
70
EGW2VM1R5E12OT
10×16
270
EGW2GM120G16OT
6.3×9
72
EGW2VM1R8E09OT
10×20
280
EGW2GM120G20OT
6.3×12
80
EGW2VM1R8E12OT
10×20
324
EGW2GM150G20OT
6.3×9
82
EGW2VM2R2E09OT
12.5×16
324
EGW2GM150W16OT
6.3×12
86
EGW2VM2R2E12OT
12.5×20
480
EGW2GM220W20OT
8×9
88
EGW2VM2R8F09OT
12.5×25
500
EGW2GM220W25OT
8×12
95
EGW2VM2R8F12OT
12.5×25
550
EGW2GM330W25OT
8×9
100
EGW2VM3R3F09OT
16×20
585
EGW2GM330L20OT
8×12
108
EGW2VM3R3F12OT
16×20
650
EGW2GM470L20OT
8×9
114
EGW2VM4R7F09OT
16×25
730
EGW2GM470L25OT
8×12
120
EGW2VM4R7F12OT
16×30
770
EGW2GM560L30OT
8×12
150
EGW2VM5R6F12OT
16×30
810
EGW2GM680L30OT
8×16
162
EGW2VM5R6F16OT
18×25
830
EGW2GM680M25OT
8×12
172
EGW2VM6R8F12OT
82
18×30
980
EGW2GM820M30OT
8×16
190
EGW2VM6R8F16OT
100
18×30
1025
EGW2GM101M30OT
8×16
215
EGW2VM8R2F16OT
150
18×40
1340
EGW2GM151M40OT
10×12
215
EGW2VM8R2G12OT
180
18×45
1470
EGW2GM181M45OT
8×20
260
EGW2VM100F20OT
6.3×9
76
EGW2WM010E09OT
10×12
230
EGW2VM100G12OT
6.3×12
77
EGW2WM010E12OT
15
10×16
340
EGW2VM150G16OT
8×9
80
EGW2WM1R2F09OT
22
10×20
460
EGW2VM220G20OT
8×9
82
EGW2WM1R5F09OT
12.5×20
600
EGW2VM330W20OT
8×12
85
EGW2WM1R5F12OT
16×20
650
EGW2VM330L20OT
8×9
85
EGW2WM1R8F09OT
16×20
700
EGW2VM470L20OT
8×12
88
EGW2WM1R8F12OT
16×25
780
EGW2VM680L25OT
10×9
90
EGW2WM1R8G09OT
18×20
780
EGW2VM680M20OT
8×9
86
EGW2WM2R2F09OT
16×30
1000
EGW2VM820L30OT
8×12
92
EGW2WM2R2F12OT
18×25
1000
EGW2VM820M25OT
10×9
92
EGW2WM2R2G09OT
18×25
1120
EGW2VM101M25OT
8×12
95
EGW2WM2R8F12OT
18×30
1210
EGW2VM101M30OT
10×9
95
EGW2WM2R8G09OT
6.3×7
61
EGW2GM010E07OT
8×12
94
EGW2WM3R3F12OT
6.3×9
65
EGW2GM010E09OT
10×9
98
EGW2WM3R3G09OT
6.3×9
68
EGW2GM1R2E09OT
8×12
110
EGW2WM3R9F12OT
6.3×9
70
EGW2GM1R5E09OT
10×9
115
EGW2WM3R9G09OT
6.3×12
74
EGW2GM1R5E12OT
8×12
115
EGW2WM4R7F12OT
8×9
72
EGW2GM1R5F09OT
10×12
123
EGW2WM4R7G12OT
6.3×9
72
EGW2GM1R8E09OT
10×16
130
EGW2WM4R7G16OT
6.3×12
80
EGW2GM1R8E12OT
10×12
142
EGW2WM5R6G12OT
8×9
76
EGW2GM1R8F09OT
10×16
167
EGW2WM5R6G16OT
6.3×9
76
EGW2GM2R2E09OT
10×12
175
EGW2WM6R8G12OT
6.3×12
85
EGW2GM2R2E12OT
10×16
195
EGW2WM6R8G16OT
8×9
85
EGW2GM2R2F09OT
10×16
220
EGW2WM8R2G16OT
8×12
90
EGW2GM2R2F12OT
10×20
230
EGW2WM8R2G20OT
10×16
255
EGW2WM100G16OT
10×20
300
EGW2WM100G20OT
1
1.2
1.5
1.8
2.2
2.8
3.3
4.7
5.6
350(2V)
6.8
8.2
10
33
47
68
82
100
1
1.2
1.5
400(2G)
1.8
2.2
2.8
3.3
4.7
5.6
6.8
8.2
400(2G)
10
12
15
22
33
47
56
68
1
1.2
1.5
1.8
2.2
2.8
450(2W)
3.3
3.9
4.7
5.6
6.8
8.2
10
112
Radial Type
STANDARD RATINGS
CD11GAS series
WV
(Vdc)
Cap
(µF)
Size
ΦD×L(mm)
Rated ripple
current
PartNumber
12.5×16
365
EGW2WM150W16OT
12.5×20
410
EGW2WM150W20OT
12.5×20
480
EGW2WM220W20OT
12.5×25
530
EGW2WM220W25OT
16×20
530
EGW2WM220L20OT
16×20
600
EGW2WM330L20OT
16×25
720
EGW2WM470L25OT
16×30
800
EGW2WM470L30OT
16×30
990
EGW2WM560L30OT
18×25
1000
EGW2WM560M25OT
18×25
1150
EGW2WM680M25OT
18×30
1230
EGW2WM680M30OT
82
18×30
1320
EGW2WM820M30OT
100
18×35
1370
EGW2WM101M35OT
150
18×45
1700
EGW2WM151M45OT
12.5×20
288
EGW2HM100W20OT
12.5×25
302
EGW2HM100W25OT
12.5×25
396
EGW2HM150W25OT
16×20
396
EGW2HM150L20OT
12.5×35
504
EGW2HM220W35OT
16×25
504
EGW2HM220L25OT
33
18×25
630
EGW2HM330M25OT
47
18×30
792
EGW2HM470M30OT
56
18×30
860
EGW2HM560M30OT
18×35
1000
EGW2HM680M35OT
22×35
1070
EGW2HM680O35OT
82
22×35
1220
EGW2HM820O35OT
100
22×35
1420
EGW2HM101O35OT
15
22
33
450(2W)
47
56
68
10
15
22
500(2H)
68
113
很抱歉,暂时无法提供与“EGW2GM4R7F12OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31920
- 100+0.29070
- 500+0.26220
- 1000+0.23370
- 2000+0.21470
- 4000+0.20900
- 国内价格
- 10+0.32868
- 100+0.26696
- 500+0.23610
- 1000+0.20231
- 5000+0.18472
- 10000+0.17591
