Updated Series
Preliminary Data
FH series
)+6HULHVႏKLJKULSSOHFXUUHQWDWIUHTXHQF\UDQJH
Feature
ƹNew innovative electrolyte is employed to minimize ESR
ƹLong life 4000 to 10000 hours at 105ć
ƹNon solvent proof type
ƹ6.3 to 100VDC newly type
ƹRoHS compliance.
Specificatio
Item
Operating Temperature
Rated Voltage Range
capacitance range
Capacitance Tolerance
Performance Characteristics
-40 to +105ć
6.3~100V.DC
6.8~18000uF
±20% (120Hz, +20ć)
Leakage Current
(+20ć,max.)
Ḭ0.01CV or 3μA whichever is greater, with rated working voltage applied(After 2 minutes).
I= Leakage Current(μA) C= Rated Capacitance V= Rated voltage(V)
working voltage(VDC)
D.F.(%)max
Dissipation Factor
(tanδˈat 20ćˈ120Hz)
6.3
22
10
19
16
16
25
14
35
12
50
10
63
9
100
8
25
2
3
35
2
3
50
2
3
63
2
3
100
2
3
For capacitance ˚1000μF,add 2% per another 1000μF
Low Temperature
Characteristics (at 120Hz)
Impedance ratio max
Working Voltage(VDC)
Z-25ćˋZ+20ć
Z-40ćˋZ+20ć
6.3
4
8
Test conditions
Duration time:
size
voltage
Endurance
6.3~10WV
16~100WV
10
3
6
16
2
4
ΦD=8,10
6000hrs
7000hrs
φD̰6.3
4000hrs
5000hrs
φDı13
8000hrs
10000hrs
Ambient temperature
:+105ć
Applied voltage
:Rated DC working voltage
After test requirement at +20ć
Capacitance change
: within±25% of the initial measured value
Dissipation factor
:̰ 200% of the initial specified value
Leakage current
:̰ The initial specified value
Test conditions
Duration time
:1000Hrs
Ambient temperature
:+105ć
Applied voltage
:None
After test requirement at +20ć:Same limits as Endurance.
Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes.
Shelf Life
Multiplier for Ripple Current vs.
CAP(μ
CAP̰10
10˘CAP̰100
100˘CAP̰1000
1000˘CAP
50(60)
0.47
0.52
0.58
0.63
120
0.59
0.62
0.72
0.78
400
0.76
0.80
0.84
0.87
1K
0.85
0.89
0.90
0.91
10K
0.97
0.97
0.98
0.98
100K
1.00
1.00
1.00
1.00
Diagram of Dimensions:(unit:mm)
Dφ
F
P.E.T.Sleeve
dφ
α
LƲα
5
2
0.5
Dζ18
1.5
167
8
3.5
6.3
2.5
L˘20
Lı20
0.5
0.6
D=18
Lζ35.5 Ḻ35.5
1.5
2.0
10 13
5.0
16 18
7.5
0.6
0.8
Dη18
2.0
FH series
Case Size
WV
(Vdc)
Cap
(uF)
Size
mm
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
16
150
220
330
470
680
820
1000
1200
1200
1500
1800
2200
2700
3300
3900
3900
4700
5600
5600
6800
6800
6800
8200
10000
10000
12000
12000
15000
18000
100
220
330
470
680
680
820
1000
1000
1200
1500
1500
2200
2200
2200
2700
3300
3900
3900
4700
5600
5600
5600
6800
6800
8200
8200
10000
10000
12000
56
5×11
6.3×11
6.3×11
8×11.5
8×11.5
10×12.5
8×16
8×20
10×16
10×20
13×16
10×25
16×16
13×20
13×25
18×16
13×30
13×35
16×21
13×40
16×25
18×21
16×31.5
16×35.5
18×25
16×41
18×31.5
18×35.5
18×41
5×11
6.3×11
6.3×11
8×11.5
8×16
10×12.5
10×16
8×20
10×16
10×20
10×25
13×16
10×30
13×20
16×16
18×16
13×25
13×30
16×21
13×35
13×40
16×25
18×21
16×31.5
18×25
16×35.5
18×31.5
16×41
18×35.5
18×41
5×11
Rated Ripple Max ESR( Ω)
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
220
300
350
440
650
870
850
1060
1220
1410
1460
1660
1950
1910
2240
2220
2660
2890
2540
3360
2940
2870
3460
3620
3150
4090
4180
4230
4290
220
350
450
650
850
870
950
1060
1220
1410
1560
1460
1920
1910
1950
2220
2240
2660
2540
2890
3360
2940
2870
3460
3150
3620
4180
4090
4230
4290
220
0.550
0.260
0.210
0.140
0.130
0.090
0.080
0.075
0.064
0.050
0.049
0.046
0.042
0.038
0.029
0.040
0.027
0.024
0.027
0.017
0.021
0.026
0.017
0.015
0.019
0.013
0.015
0.014
0.012
0.580
0.230
0.220
0.130
0.096
0.085
0.075
0.072
0.064
0.045
0.043
0.049
0.030
0.035
0.042
0.043
0.029
0.025
0.027
0.020
0.017
0.021
0.026
0.017
0.019
0.015
0.015
0.013
0.014
0.012
0.560
168
WV
(Vdc)
Cap
(uF)
Size
mm
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
16
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
25
100
120
220
330
470
470
470
680
680
820
1000
1000
1200
1500
1500
1500
1500
1800
1800
2200
2200
2700
2700
3300
3900
3900
3900
4700
4700
5600
5600
6800
8200
10000
47
56
100
220
330
330
470
470
470
680
680
820
1000
1000
1000
1200
1500
1800
1800
2200
2200
2200
2700
2700
3300
3300
6.3×11
6.3×11
8×11.5
8×11.5
8×11.5
8×16
10×12.5
8×20
10×16
10×20
10×20
13×16
10×25
10×25
10×30
13×20
16×16
10×25
13×25
13×25
18×16
13×30
16×21
13×35
13×40
16×25
18×21
16×31.5
18×25
16×35.5
18×31.5
16×41
18×35.5
18×41
5×11
5×11
6.3×11
8×11.5
8×16
10×12.5
8×20
10×12.5
10×16
10×20
13×16
10×25
10×30
13×20
16×16
18×16
13×25
13×30
16×21
13×30
13×35
18×21
13×40
16×25
16×31.5
18×25
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
300
350
500
650
740
850
870
1060
1220
1300
1410
1460
1660
1770
1920
1910
1950
1800
2080
2240
2220
2660
2540
2890
3360
2940
2870
3460
3150
3620
4180
4090
4230
4290
220
260
350
650
850
870
1060
1100
1220
1410
1460
1660
1920
1910
1950
2220
2240
2660
2540
2695
2890
2870
3360
2940
3460
3150
0.220
0.215
0.180
0.140
0.100
0.095
0.085
0.080
0.060
0.052
0.046
0.050
0.044
0.036
0.031
0.037
0.042
0.036
0.030
0.026
0.043
0.023
0.027
0.022
0.017
0.021
0.026
0.017
0.020
0.015
0.015
0.013
0.014
0.012
0.560
0.560
0.250
0.150
0.092
0.082
0.074
0.074
0.068
0.050
0.049
0.041
0.032
0.036
0.042
0.043
0.028
0.024
0.027
0.025
0.023
0.026
0.017
0.022
0.017
0.019
FH series
Case Size
WV
(Vdc)
Cap
(uF)
Size
mm
25
25
25
25
25
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
35
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
50
3900
3900
4700
4700
5600
33
47
56
100
150
220
220
220
270
330
470
470
560
680
680
680
1000
1000
1000
1200
1200
1500
1800
1800
1800
2200
2200
2200
2700
2700
3300
3300
3900
22
47
56
100
120
150
180
220
270
270
330
470
470
470
560
560
680
820
820
1000
1000
1000
16×35.5
18×31.5
16×41
18×35.5
18×41
5×11
5×11
6.3×11
6.3×11
8×11.5
8×11.5
8×16
10×12.5
8×20
10×16
10×20
13×16
10×25
10×30
13×20
16×16
13×20
13×25
18×16
13×30
16×21
13×35
13×40
16×25
18×21
16×31.5
18×21
18×25
16×35.5
18×31.5
16×41
18×35.5
18×41
5×11
6.3×11
6.3×11
8×11.5
8×16
10×12.5
8×20
10×16
10×20
13×16
10×25
10×30
13×20
16×16
13×25
18×16
13×30
13×35
16×21
13×35
13×40
16×25
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
3620
4180
4090
4230
4290
230
300
360
480
680
870
1000
1060
1180
1380
1800
1560
1900
2000
2100
2050
2180
2400
2220
2800
2800
3000
3360
2940
2870
3460
2930
3150
3620
4180
4090
4230
4300
220
270
300
680
760
800
1000
1300
1350
1270
1600
1800
1740
1710
1960
1940
2320
2520
2220
2650
2930
2565
0.015
0.015
0.013
0.014
0.012
0.550
0.450
0.210
0.180
0.140
0.095
0.090
0.080
0.070
0.062
0.048
0.049
0.042
0.035
0.034
0.042
0.038
0.028
0.043
0.024
0.028
0.022
0.017
0.020
0.026
0.017
0.025
0.019
0.018
0.016
0.013
0.014
0.012
0.650
0.370
0.290
0.160
0.120
0.120
0.090
0.082
0.060
0.061
0.057
0.048
0.045
0.055
0.042
0.054
0.030
0.025
0.034
0.024
0.021
0.025
169
WV
(Vdc)
Cap
(uF)
Size
mm
50
50
50
50
50
50
50
50
50
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
63
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
1000
1200
1200
1500
1800
1800
2200
2700
3300
15
33
47
56
82
82
100
120
120
180
180
220
220
270
270
270
330
390
470
470
560
560
680
680
820
820
1000
1000
1000
1200
1200
1200
1500
6.8
15
27
39
47
56
68
82
82
100
120
120
150
150
180
180
220
220
18×21
16×31.5
18×25
16×35.5
16×41
18×31.5
18×35.5
18×41
18×41
5×11
6.3×11
8×11.5
8×11.5
8×16
10×12.5
10×12.5
8×20
10×16
10×20
13×16
10×20
10×25
10×30
13×20
16×16
13×25
18×16
13×30
16×21
13×35
16×25
13×40
18×21
16×31.5
18×25
16×35.5
18*25
18×31.5
16×41
18×31.5
18×35.5
18×41
5×11
6.3×11
8×11.5
8×16
10×12.5
8×20
10×16
10×20
13×16
10×25
10×30
13×20
13×20
16×16
13×25
18×16
13×30
16×21
current
at 20ć
(Arms/105ć
/100kHz
/100KHz)
2500
3020
2750
3160
3720
3645
3690
3810
3810
65
260
360
380
460
500
640
700
760
880
800
995
1100
1200
1200
1200
1600
1610
1800
1500
2000
2000
2200
1600
2400
1800
2500
2290
2800
2920
2850
3000
3200
65
130
300
340
400
410
460
600
540
800
830
900
1000
1000
1010
1180
1210
1140
0.036
0.030
0.026
0.019
0.016
0.021
0.017
0.014
0.014
1.800
1.200
0.660
0.600
0.440
0.430
0.340
0.320
0.300
0.190
0.180
0.188
0.185
0.120
0.160
0.110
0.120
0.096
0.100
0.077
0.070
0.073
0.070
0.072
0.054
0.052
0.048
0.052
0.047
0.040
0.045
0.039
0.036
1.800
1.000
0.610
0.360
0.420
0.260
0.300
0.210
0.180
0.200
0.120
0.160
0.110
0.110
0.096
0.096
0.080
0.077
FH series
Case Size
WV
(Vdc)
Cap
(uF)
Size
mm
100
100
100
100
100
100
100
100
100
100
100
100
270
270
330
330
390
390
470
470
560
680
820
1000
13×35
16×25
13×40
18×21
16×31.5
18×25
16×35.5
18×31.5
16×41
18×35.5
18×41
18×41
current
at 20ć
/100kHz
(Arms/105ć
/100KHz)
1450
1480
1600
1400
1700
1740
1910
1730
2140
2000
2480
2580
0.070
0.073
0.071
0.072
0.055
0.054
0.047
0.047
0.036
0.042
0.040
0.038
170
很抱歉,暂时无法提供与“FH101M050F115A”相匹配的价格&库存,您可以联系我们找货
