TAI-TECH
P1
SMD Power Choke Coil
TMPC0503H-Series(G)-D
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
15/09/10
新 發 行
楊祥忠
詹偉特
何秦芝
1.1
17/03/24
增加:電流 MAX 規格
楊祥忠
詹偉特
何秦芝
備
註
TAI-TECH
P2
1. Features
1. Carbonyl powder inductor.
2. Compact design.
3. High current,low DCR,high efficiency.
Halogen
Pb
Halogen-free
Pb-free
4. Very low acoustic noise and very low leakage flux noise.
5. High reliability.
6. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
2. Applications
Note PC power system,incl. IMVP-6
DC/DC converter.
3. Dimensions
Recommend PC Board Pattern
Dr. MOS application
C
L
E
B
6R8
1R0
1151
1150
D
H
A
G
Series
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
TMPC0503H
5.7±0.3
5.2±0.2
2.8±0.2
1.1±0.3
1.5±0.2
L(mm)
4. Part Numbering
TMPC
0503
H
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
F: D/C
6R8
D
MG E
G(mm)
H(mm)
6.5
2.5
1.8
Note: 1. The above PCB layout reference only.
2. Recommend solder paste thickness at
0.12mm and above.
D
F
BxC
Carbonyl powder
6R8=6.8uH
M=±20%
印字:黑色;6R8 及 D/C 1150 (D/C 前二碼是年份,後二碼是週期,依實際生產週期而定)
TAI-TECH
P3
5. Specification
Part Number
Inductance
L0 (uH)±20%
@0A
I rms (A)
I sat (A)
Typ
Max
Typ
Max
DCR(mΩ)
Typ.@25℃
DCR(mΩ)
Max.@25℃
TMPC0503H-R10YG-D
0.10±30%
23.0
20.0
27.0
24.0
2.5
3.0
TMPC0503H-R15YG-D
0.15±30%
18.0
16.0
30.0
26.0
2.3
2.7
TMPC0503H-R20YG-D
0.20±30%
16.0
14.0
25.0
21.0
2.6
3.2
TMPC0503H-R22MG-D
0.22
15.5
13.0
21.0
19.0
3.7
4.4
TMPC0503H-R25MG-D
0.25
15.0
12.0
20.0
18.0
3.7
4.1
TMPC0503H-R33MG-D
0.33
14.0
11.0
18.0
16.0
4.3
5.0
TMPC0503H-R47MG-D
0.47
12.0
10.0
16.0
14.0
6.4
7.4
TMPC0503H-R56MG-D
0.56
10.0
9.00
15.0
13.5
8.0
10
TMPC0503H-R68MG-D
0.68
8.50
7.50
14.0
12.5
10
12
TMPC0503H-R82MG-D
0.82
8.00
7.00
12.5
11.0
11.5
13
TMPC0503H-1R0MG-D
1.00
7.00
6.00
11.0
9.50
13
14
TMPC0503H-1R2MG-D
1.20
6.50
5.50
11.0
9.50
14
16
TMPC0503H-1R5MG-D
1.50
6.00
5.00
10.0
9.00
16
25
TMPC0503H-2R2MG-D
2.20
5.50
4.80
9.00
8.00
25
35
TMPC0503H-3R3MG-D
3.30
5.00
4.30
8.00
7.00
32
38
TMPC0503H-3R6MG-D
3.60
4.90
4.10
7.00
6.00
46
54
TMPC0503H-4R7MG-D
4.70
4.60
4.00
6.00
5.00
50
53
TMPC0503H-5R6MG-D
5.60
4.25
3.80
4.50
4.00
55
63
TMPC0503H-6R8MG-D
6.80
4.00
3.60
4.30
3.80
68
76.2
TMPC0503H-100MG-D
10.0
2.75
2.40
3.50
3.10
110
128
TMPC0503H-150MG-D
15.0
2.10
1.90
2.60
2.20
165
190
TMPC0503H-180MG-D
18.0
2.00
1.80
2.30
2.00
195
230
TMPC0503H-220MG-D
22.0
1.90
1.70
1.70
1.50
220
250
TMPC0503H-330MG-D
33.0
1.60
1.50
1.60
1.40
380
440
Note:
1. Test frequency : Ls : 100KHz /1.0V.
2. All test data referenced to 25℃ ambient.
3. Testing Instrument(or equ) : L: HP4284A,CH11025,CH3302,CH1320,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃
5. Saturation Current (Isat) will cause L0 to drop approximately 20%.
6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Special inquiries besides the above common used types can be met on your requirement.
TAI-TECH
P4
6. Material List
NO
Items
Materials
1
Core
Carbonyl Powder.
2
Wire
Polyester Wire or equivalent.
3
Clip
100% Pb free solder(Ni+Sn---Plating)
4
paint
Epoxy resin
5
Ink
Halogen-free ketone
7. Reliability and Test Condition
Item
Performance
Operating temperature
-40~+125℃ (Including self - temperature rise)
Storage temperature
1.-10~+40℃,50~60%RH (Product without taping)
2.-40~+125℃ (on board)
Test Condition
Electrical Performance Test
Inductance
Refer to standard electrical characteristics list.
DCR
LCR Meter.
CH16502,Agilent33420A Micro-Ohm Meter.
Approximately △L20%.
Saturation DC Current (Isat) will cause L0
to drop △L(%)
Approximately △T40℃
△T(℃).
1.Applied the allowed DC current
2.Temperature measured by digital surface thermometer
Reliability Test
Preconditioning:
Run
through
IR
times.( IPC/JEDEC
J-STD-020DClassification Reflow Profiles)
Temperature: 125±2℃(Inductor)
Life Test
reflow
for
2
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
Preconditioning:
Run
through
IR
times.( IPC/JEDEC
Humidity:85±2﹪ R.H,
Load Humidity
reflow
for
2
Temperature:85℃±2℃
Duration:1000hrs Min. with 100% rated current
Appearance:No damage.
Moisture Resistance
Inductance:within±10% of initial value
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not
Thermal
shock
Preconditioning:
Run
through
IR
reflow
for
2
times.( IPC/JEDEC J-STD-020DClassification Reflow
Profiles
1. Baked at50℃ for 25hrs, measured at room temperature
after placing for 4 hrs.
2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
keep 3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Preconditioning:
Run
through
IR
reflow
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
for
Step2:25±2℃ ≦0.5min
Step3:125±2℃ 30±5min
Number of cycles: 500
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Vibration
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
2
TAI-TECH
Item
Shock
P5
Performance
Type
Peak
value
(g’s)
Normal
duration (D)
(ms)
Wave
form
Velocity
change
(Vi)ft/sec
SMD
50
11
Half-sine
11.3
Lead
50
11
Half-sine
11.3
Bending
Solderability
Test Condition
More than 95% of the terminal electrode should
be covered with solder。
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805 inch(2012mm):40x100x1.2mm
=0805 inch(2012mm):1.2mm
0805
inch(2012mm):1kg ,
很抱歉,暂时无法提供与“TMPC0503H-R82MG-D”相匹配的价格&库存,您可以联系我们找货
