TAI-TECH
P1
SMD Power Inductor
TMPC0605HV-Series(G)-D
1. Features
1. Carbonyl Powder.
2. Compact design.
Halogen
3. High current,low DCR,high efficiency.
4. Very low acoustic noise and very low leakage flux noise.
Halogen-free
5. High reliability.
6. 100% Lead(Pb)-Free and RoHS compliant.
7. High reliability -Reliability test complied to AEC-Q200.
8. Operating temperature -55~+125℃(Including self - temperature rise)
2. Applications
Note PC power system,incl. IMVP-6
DC/DC converter .
3. Dimensions
Recommend PC Board Pattern
C
D
E
B
1R0
2019
L
H
A
G
Series
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
L(mm)
TMPC0605HV
7.3±0.3
6.6±0.3
4.8±0.2
1.8±0.3
3.0±0.3
8.4
2.5
3.5
Note: 1. The above PCB layout reference only.
2. Recommend solder paste thickness at
0.15mm and above.
4. Part Numbering
TMPC
0605
HV
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
F: Code
1R0
MG
D
E
D
F
BxC
Carbonyl Powder.vehicle.
1R0=1.00uH
K=±10%,L=±15%,M=±20%,N=±25%,Y=±30%
Marking: Black.1R0 and 2019(20 YY, 19 WW,follow production date).
G(mm)
H(mm)
TAI-TECH
P2
5. Specification
Part Number
Inductance
L0 (uH)±20%
I rms ( A )
I sat ( A )
DCR
(mΩ) Typ.
@25℃
DCR
(mΩ) Max.
@25℃
TMPC0605HV-R33MG-D
0.33
25
32
2.5
3.0
TMPC0605HV-R47MG-D
0.47
22
30
3.5
3.9
TMPC0605HV-R56MG-D
0.56
3.6
4.2
TMPC0605HV-R68MG-D
0.68
18
24
4.0
4.5
TMPC0605HV-R82MG-D
0.82
16.5
22
4.6
4.9
TMPC0605HV-1R0MG-D
1.00
15
6.5
TMPC0605HV-1R5MG-D
1.50
12
16.5
8.6
9.0
TMPC0605HV-2R2MG-D
2.20
10
14
11.2
12.0
TMPC0605HV-3R3MG-D
3.30
8
12
19
20.9
TMPC0605HV-4R7MG-D
4.70
6.5
10
28
30.8
TMPC0605HV-5R6MG-D
5.60
6.0
9.0
43.5
49
TMPC0605HV-6R8MG-D
6.80
5.5
8.5
46
51.5
TMPC0605HV-8R2MG-D
8.20
5.0
8.0
56
63
TMPC0605HV-100MG-D
10.0
4.0
7.5
60
69
TMPC0605HV-150MG-D
15.0
3.5
6.0
81
92
TMPC0605HV-220MG-D
22.0
2.5
5.5
140
170
TMPC0605HV-330MG-D
33.0
2.0
3.5
173
200
Note:
1. Test frequency : Ls : 100KHz /1.0V.
2. All test data referenced to 25℃ ambient.
3. Testing Instrument(or equ) : L: HP4284A,CH11025,CH3302,CH1320,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃
5. Saturation Current (Isat) will cause L0 to drop approximately 30%.
6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Special inquiries besides the above common used types can be met on your requirement.
TAI-TECH
6. Typical Performance Curves
P3
很抱歉,暂时无法提供与“TMPC0605HV-6R8MG-D”相匹配的价格&库存,您可以联系我们找货
