CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CMLB136T-000
REVISION
: A1
PAGE
: 1 OF 4
Power Choke Coil CMLB136T type
Features
High performance (Isat) realized by metal dust core.
Low profile Thickness max. 6.0mm
Low loss realized with low DCR
Capable of corresponding high frequency (1MHz)
100% lead (Pb) free meet RoHS standard
Application
DC/DC converter for CPU in Notebook PC
Thin type on-board power supply module for exchanger
VRM for server
Outline Dimensions
L
A'
A
B
W
B'
H
T
Code
Dimensions (mm)
L
13.45 ± 0.35
W
12.6 ± 0.2
T
5.8 ± 0.2
A
2.0 ± 0.5
A’
2.5 ± 0.1
B
5.0 ± 0.5
B’
6.0 ± 0.2
H
0 ~ +0.15
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
5.5
B
8.0
C
14.5
Unit : mm
Sep., 2017
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CMLB136T-000
REVISION
: A1
PAGE
: 2 OF 4
Specifications
L0
Inductance
( µH )
@ (0A)
Typical
CMLB136T-8R2MS
8.2
13.5
16.0
11.0
10.0
16.0
13.5
CMLB136T-100MS
10.0
17.7
20.7
10.0
9.5
13.5
11.5
CMLB136T-120MS
12.0
19.8
23.0
9.0
8.0
13.0
11.0
CMLB136T-150MS
15.0
24.0
27.5
8.0
7.0
10.0
9.0
CMLB136T-220MS
22.0
33.0
39.0
7.0
6.5
7.6
6.9
CMLB136T-330MS
33.0
60.0
70.0
5.0
4.7
6.1
5.4
CMLB136T-470MS
47.0
78.0
88.0
4.5
4.0
5.7
5.2
CMLB136T-680MS
68.0
119.5
140.0
3.5
3.0
5.5
4.7
CMLB136T-101MS
100.0
178.0
198.0
3.0
2.7
4.0
3.5
CMLB136T-151MS
150.0
300.0
347.0
2.5
2.2
3.0
2.7
Part Number
Rdc ( mΩ)
Maximum
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Typical
Typical
Maximum
Maximum
*: If you require another part number please contact with us.
**:Inductance Tolerance ± 20%
Note 2.:
Note 3.:
Note 4.:
Note 5.:
Note 6.:
Note 1.
All test data is referenced to 25
℃ ambient.
Test Condition:100KHz, 1.0Vrms
Idc : DC current (A) that will cause an approximate △T of 40
Isat : DC current (A) that will cause L0 to drop approximately 30%
Operating Temperature Range -55
℃ to + 125℃
The part temperature (ambient + temp rise) should not exceed 125
℃ under the worst case operating
conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other
cooling provision all affect the part temperature. Part temperature should be verified in the end
Note 7.
application.
The rated current as listed is either the saturation current or the heating current depending on which
value is lower.
Sep., 2017
CYNTEC CO., LTD.
乾坤科技股份有限公司
REVISION
: A1
PAGE
: 3 OF 4
3.20
TEMP. RISE(
40
4
6
8
10
12
DC BIAS(Amps)
14
16
18
CMLB136T-120MS
15.0
60
INDUCTANCE(µH)
40
5.0
0.0
3
4
5
CMLB136T-220MS
27.0
TEMP. RISE(
TEMP. RISE( )
60
INDUCTANCE(µH)
13.5
40
9.0
0.0
3.0
4.5
6.0
7.5
DC BIAS(Amps)
60.0
9.0
10.5
50.0
60
INDUCTANCE(µH)
30.0
TEMP. RISE(
20.0
40
0.0
2
3
4
5
DC BIAS(Amps)
6
7
8
4
5
6 7 8 9 10 11 12 13 14 15 16
DC BIAS(Amps)
CMLB136T-150MS
100
80
60
9.0
INDUCTANCE(µH)
6.0
TEMP. RISE(
40
2
3
4
5
6
7
8
DC BIAS(Amps)
9
10
11
12
13
CMLB136T-330MS
100
35.0
80
28.0
21.0
INDUCTANCE(µH)
TEMP. RISE(
14.0
40
2
3
4
5
DC BIAS(Amps)
6
7
8
100
CMLB136T-680MS
70.0
80
56.0
42.0
28.0
60
84.0
12.0
40.0
3
0.0
100
CMLB136T-470MS
2
15.0
12.0
INDUCTANCE(µH)
0.0
42.0
80
18.0
40
22.5
2.0
DC BIAS(Amps)
INDUCTANCE(µH)
2
TEMP. RISE(
0.0
4.0
18.0
TEMP. RISE( )
10.0
INDUCTANCE(µH)
TEMP. RISE(
6.0
0.0
100
12.5
7.5
60
INDUCTANCE(µH)
TEMP. RISE( )
INDUCTANCE(µH)
80
TEMP. RISE( )
4.80
100
60
INDUCTANCE(µH)
TEMP. RISE(
40
0.0
TEMP. RISE( )
60
CMLB136T-100MS
TEMP. RISE( )
10.0
INDUCTANCE(µH)
80
TEMP. RISE( )
INDUCTANCE(µH)
12.0
6.40
0.00
INDUCTANCE(µH)
100
TEMP. RISE( )
CMLB136T-8R2MS
8.00
INDUCTANCE(µH)
: CMLB136T-000
Current Characteristic
9.60
INDUCTANCE(µH)
DOCUMENT
0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0
DC BIAS(Amps)
Sep., 2017
CYNTEC CO., LTD.
乾坤科技股份有限公司
80
150.0
80.0
60
INDUCTANCE(µH)
60.0
TEMP. RISE(
40
40.0
0.0
0.6
1.2
1.8
2.4
3.0
DC BIAS(Amps)
3.6
4.2
4.8
: CMLB136T-000
REVISION
: A1
PAGE
: 4 OF 4
CMLB136T-151MS
100
80
120.0
60
90.0
40
60.0
INDUCTANCE(µH)
30.0
TEMP. RISE(
0.5
1.0
1.5
2.0
2.5
3.0
DC BIAS(Amps)
3.5
4.0
TEMP. RISE( )
180.0
INDUCTANCE(µH)
INDUCTANCE(µH)
100.0
100
TEMP. RISE( )
CMLB136T-101MS
120.0
DOCUMENT
4.5
Sep., 2017
很抱歉,暂时无法提供与“CMLB136T-5R6MS”相匹配的价格&库存,您可以联系我们找货
